• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » [Errata???]about the limit of Bit Rate of Synchronous Serial Interface(SSI)
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • [Errata???]about the limit of Bit Rate of Synchronous Serial Interface(SSI)
    This question is answered
    huangzhechen
    Posted by huangzhechen
    on May 01 2012 01:30 AM
    Prodigy60 points
    The datasheet of LM3S811 says :
    Bit rates are supported to 1.5 MHz and higher, although maximum bit rate is determined by
    peripheral devices.
    For master mode, the system clock must be at least two times faster than the SSIClk. For
    slave mode, the system clock must be at least 12 times faster than the SSIClk.
    that is,
    2*SSIClk<=sysclk(Master mode)
    12*SSIClk<=sysclk(Slave mode)
    While on the PDL-LM3S-UG-3416.pdf:
    FSSI >= 2 bit rate (master mode)
    FSSI >= 12 bit rate (slave modes)
    FSSI should be equal to SSIClk. Seemingly there is something wrong with the datasheet.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Stellaris Dave
      Posted by Stellaris Dave
      on May 01 2012 18:27 PM
      Verified Answer
      Verified by huangzhechen
      Expert5260 points
      huangzhechen,
      The FSSI is referring to the frequency of the clock supplied to the SSI module.
      For example:
      If the Stellaris is operating in master mode and the slave provides a clock of 10kHz, then the internal clock of the SSI peripheral on the Stellaris (FSSI) needs to be:
      FSSI >= 2 bit rate
      in this case FSSI >= 2 * (10kHz)
      Therefore the SSI peripheral must have an internal clock of at least 20kHz. Make sense?
      Also the document you are referring to (PDL-LM3S-UG-3416.pdf) is outdated. Please refer to the DriverLib doc that installed with StellarisWare.
      "<StellarisWare install directory>\docs\ SW-DRL-UG-xxxx.pdf"
      -Dave
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
