Hello together,
I´m using a stellaris eks-lm3s8962 evaluation kit and I have a problem to read the internal temperature...always when I try to build the code it show´s me an error code in the Console..
>> Compilation failuregmake: *** [temperature_sensor.obj] Error 1gmake: Target `all' not remade because of errors.**** Build Finished ****
Because of that I´m not able to debug it..if I try it an error pops up
CORTEX_M3_0: GEL: Encountered a problem loading file: C:\Users\Brauni\workspace_v5_1\temperatur\Debug\temperatur.out Could not open file
What can I do? Thank´s for your help!
Hey dude,
I have exactly the same problem usik the stellaris eks-lm3s8962 Ev - kit -> reading the temperature
Somebody can help ?
regards
Hi
You should get an compiler error message in the console. Please post this message.
Hey Andre
That´s the complete error message in the Console...I think the problem is not in the programm, it´in the settings...but I have no idea where...
**** Build of configuration Debug for project temperatur ****C:\Tools\TexasInstruments\ccsv5\ccsv5\utils\bin\gmake -k all 'Building file: ../temperature_sensor.c''Invoking: ARM Compiler'"C:/Tools/TexasInstruments/ccsv5/ccsv5/tools/compiler/tms470/bin/cl470" -mv7M3 --code_state=16 --abi=eabi -me -g --preinclude="C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib" --include_path="C:/Tools/TexasInstruments/StellarisWare-8555" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="temperature_sensor.pp" "../temperature_sensor.c""C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 1: error #171: expected a declaration"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 2: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #915: invalid character in input line"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized token"C:/Tools/TexasInstruments/StellarisWare-8555/driverlib/ccs-cm3/Debug/driverlib-cm3.lib", line 3: error #7: unrecognized tokenError limit reached.100 errors detected in the compilation of "../temperature_sensor.c".Compilation terminated.>> Compilation failuregmake: *** [temperature_sensor.obj] Error 1gmake: Target `all' not remade because of errors.**** Build Finished ****
