i have purchased "Stellaris EKK-LM3S9B92 Evaluation Kit". i have developed the projects by using keil Compiler.
Now i want to buy a programmer/debugger separately.
i have choose "Mikro Prog" programmer and debugger.
My question is can i use this programmer/debugger with Keil compiler?
if so what are the options i have to select in the keil compiler?
otherwise please suggest me what are the cheep & best programmers & debuggers (which can work with keil compiler) available for LM3S9B92 microcontroller.
thanks in advance for ur valuable suggestions.
RajaRao.
This is a question that would need to be answered by Keil in their support forums. I know that they have the ULink series of programmer/debuggers. I also know that they support connecting directly to the EKK-LM3S9B92 kit as well. I am not certain what other devices that they support.
Is there a specific reason that you do not continue using the ICDI board that comes with the EKK that you purchased for your continued programming/debugging requirements?
--Bobby
Hi Bobby,
we are still using ICDI board but we are 4 people working on the projects which are designed based on LM3S9B92 microcontroller.
we require two more ICDI boards but not EKK-LM3S9B92 Evaluation board.
Is it possible to buy ICDI board only with out EKK. if possible could u please tell me how to order ICDI board only.
if not please suggest me what are the cheep & best programmers & debuggers (which can work with keil compiler) available for LM3S9B92 microcontroller.
thanks and regards
..Raj
I would recommend posting this quesiton in the Keil support forums. They would be in a better position to answer your questions about which programmers and debuggers would work with their tools.
We do not sell the ICDI board separately, but I believe you may find that the kit price for the EKK-LM3S9B92 may be competive with most debuggers available for the Keil tools, and will also allow you to continue to use LM Flash Programmer.
For a long time the EKK-LM3S811 has been LMI/TI's lowest cost board with debug & programming capability...
