• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » LM3S9B96 (C5) Flash programming issue
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • LM3S9B96 (C5) Flash programming issue
    This question is answered
    Alexander Chuikov
    Posted by Alexander Chuikov
    on May 23 2012 10:18 AM
    Prodigy60 points
    I've question relates flash programming for LM3S9B96 (rev. C5XD). Let me explain step-by-step:
    1.  I've a custom board (no external memory and crystal 16MHz) and I create a very simple application which blink LED on E2 (pin 95 for 100-Pin LQFP package). I've been used the "blinky" example from Stellaris library as template (include linker's script)
    2. I use arm-none-eabi GCC based compiler. The compiler works perfectly with LM3S8962, LM3S6965 and some other similar LMxxxx
    3. I use LM3S8962 Evolution Board (Ethernet + CAN) as JTAG to connect host PC with target board (with LM3S9B96)
    4. I use two different kind of flash programming tools but both give same result:
    • OpenOCD 0.5.0 (2011-12-16-08:17) and 0.5.0-dev-00956-ge7269e3 (2012-05-15-00:27) both for Fedora 16x64 (Linux)
    • LM Flasher (Latest version from TI) for Windows 7x64
    Result: I can program the chip only one time for LM Flasher or one or two times for OpenOCD. I don't unplug JTAG and power in both case. I could unlock device via LM Flasher but you could understand this is very difficult to debug and test
    Could you please help me how to burn flash correctly?
    Some additional information:
    1. I've two boards with same chips with same behavior
    2. I use GCC to build application
    3. I tried to burn uIP example (my custom board has Ethernet like reference) but it doesn't work too
    4. Sorry for my broken English
    Alexander
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jonathan Guy
      Posted by Jonathan Guy
      on May 23 2012 10:42 AM
      Expert5630 points
      Hi Alexander,
      This sort of issue is usually due to something in the user code that interfers with subsequent programming operations.  Examples include incorrect clock settings, selecting a clock source that does not exist, and reconfiguring GPIO that are required for the JTAG interface.  Please review your code for any of these conditions.
      Can you program and re-program the blinky binary (unmodified) that comes with StellarisWare?
      Please report the error message provided by the programming tools.  That might provide additional clues.
      Jonathan Guy
      Report Abuse
      • Reply
    • Alexander Chuikov
      on May 23 2012 10:59 AM
      Prodigy60 points
      Hi Jonathan,
      Let me add more information about issue.
      The JTAG pins connected to JTAG pins only (directly to MCU)!
      Yes, I've been tried "blinky" (pre-built by keil). The same bad result.
      Alexander
      Report Abuse
      • Reply
    • Jonathan Guy
      on May 23 2012 16:01 PM
      Expert5630 points
      A couple of questions:
      When the programming is successful (the first time), does the application run correctly and are you able to see the LED flashing?
      Does the application still run correctly after you attempt to re-program your target board?
      Jonathan Guy
      Report Abuse
      • Reply
    • Alexander Chuikov
      on May 24 2012 01:42 AM
      Prodigy60 points
      Hi Jonathan,
      I've done some experiments. Summarize:
      1. The "blinky" working correctly (sorry for wrong message in previous post, I missed pin when I checked blinks by scope)
      2. All other examples are failed.
      3. If I add SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |  SYSCTL_XTAL_16MHZ); or other combination for SysCtlClockSet( ... ) I will receive the error: no re-write and application doesn't work.
      So, I've troubles with PLL initialization. I'll try to check (solid another one) crystal and post result.
      Alexander
      Report Abuse
      • Reply
    • Alexander Chuikov
      on May 24 2012 03:03 AM
      Prodigy60 points
      Hi Jonathan,
      Here is the update fore previous post.
      I solid another one crystal (but 8Mhz instead of 16MHz) and it works! I try to solid another 16MHz when I'll find it.
      However I've a few questions relates this topic.
      1. Why broken crystal can block firmware update and "hardware reset" via JTAG?
      2. Why OpenOCD can not verify the firmware (you could find script below)?
      source [find interface/luminary.cfg]
      set WORKAREASIZE 0x4000
      set CHIPNAME lm3s9b9x
      source [find target/stellaris.cfg]
      proc program_device () {
          # halt the processor
          halt
          #wait_halt
          # write file to flash memory
          cortex_m3 maskisr on
          flash write_image erase "./gcc/pnp_eth_can.bin" 0
          verify_image "./gcc/pnp_eth_can.bin"
          cortex_m3 maskisr off
          sleep 10
          #start execution of the program just downladed
          reset run
          sleep 10
          #exit OpenOCD
          shutdown
      init
      reset init
      program_device ()
      The errors look like:
      Error: checksum mismatch - attempting binary compare
      diff 0 address 0x00000001. Was 0x08 instead of 0x01
      diff 1 address 0x00000004. Was 0x4d instead of 0xe1
      Could you please help me how to modify script to verify image?
      Alexander
      Report Abuse
      • Reply
    • Jonathan Guy
      on May 25 2012 16:28 PM
      Expert5630 points
      Hi Alexander,
      Alexander Chuikov
      • Why broken crystal can block firmware update and "hardware reset" via JTAG?
      When your code runs, it's selecting and configuring the clock circuit.  If the clock is broken (a static level, or very wrong frequency) the MCU will not function until a power on reset.  The user code runs quickly before the programming tool can intercept the clock configuration.
      I'm not familiar with OpenOCD, but I will ask others here about your script question.
      Jonathan Guy
      Report Abuse
      • Reply
    • Alexander Chuikov
      on May 28 2012 15:11 PM
      Prodigy60 points
      Hi Jonathan,
      Thank you for detailed explanation. I'll wait instructions for OpenOCD.
      Alexander
      Report Abuse
      • Reply
    • Jonathan Guy
      on May 29 2012 15:11 PM
      Verified Answer
      Verified by Alexander Chuikov
      Expert5630 points
      Alexander,
      I checked with one of our regular openOCD user's and he provided the following information.
      The only additional config items I have in mine are:
      jtag_khz 3000
      jtag_nsrst_delay 100
      reset_config srst_only
      These would go into his script after the second "source" line. The "jtag_khz" probably needs to be lower in order to meet our TCLK <=SYSCLK/8 requirement. Going really slow (like 500) is probably a really good idea in order to just get things working...then bump up the speed to SYSCLK/8 (if it stops working, you know that it is a speed issue and not a connection issue).
      The OpenOCD user mailing list is an excellent resource for assistance with OpenOCD:
      http://openocd.sourceforge.net/discussion/mailing-lists/
      Jonathan Guy
      Report Abuse
      • Reply
    • Alexander Chuikov
      on May 31 2012 03:41 AM
      Prodigy60 points
      Hi Jonathan,
      Thank you very much!
      Alexander
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
