• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » LM3S8962 USB/Development Board distress
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • LM3S8962 USB/Development Board distress
    This question is not answered
    Michael Cooke
    Posted by Michael Cooke
    on May 29 2012 11:45 AM
    Prodigy20 points
    I am currently in a senior design group at UCF and need help with my PCB design which will have the Stellaris 8962 on it. We are not allowed to use the development board in the final project (or else we would just us that), so we need to put the pieces needed to program the Stellaris on the PCB. I am trying to follow the schematic on the Development Board data sheet, but still require assistance in finding the eagle files for certain parts.  I was wondering if anyone had any suggestions, or had files for Eagle that would aid us in this endeavor.
    Mike
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Rebecca Ringhof
      Posted by Rebecca Ringhof
      on May 29 2012 17:48 PM
      Expert6435 points
      Michael,
      We do not have Eagle files for the LM3S8962.  The footprints available for the LM3S8962 can be found on the product page under Footprint and Symbols.  The part dimensions and pin outputs are available in the datasheet.  As for the other parts on the evaluation kit, these footprints may be available on the respective product pages and datasheets for those devices.
      -Rebecca
      Report Abuse
      • Reply
    • Michael Cooke
      on May 29 2012 19:56 PM
      Prodigy20 points
      Rebecca,
       Thank you for your timely reply.
      I have the footprint for the LM3S8962 from the BDST file on the product page. The issue I am having is how do I program the Stellaris MCU, once it is on my PCB. My professor suggested that I take the pieces from the schematic of the development board and place it on my PCB. I am having a difficult time in doing this, because most of the parts, I would have to make from scratch in Eagle. Unfortunately, because of time constraints this is very difficult. I was wondering if you had a tangible schematic/footprint for the development board in Eagle. I looked on the page for the development board and could not locate the footprint for Eagle. I noticed that another TI employee posted on March 15, 2012 about having PCB files on a different development board.
      If you do not have any information about his, maybe you can rate my idea for trying to program it. My other idea was to put a pin socket on my PCB board and match up the pins to my Stellaris on the PCB. I could then take a ribbon cable from the development board to the PCB and program it that way.
       As I said, I'm just having the issue with programming the Stellaris once it is on the PCB. Any help is appreciated. I would like your input on this matter. Thank you for your assistance.
      -Mike
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on May 29 2012 20:26 PM
      Mastermind9110 points
      Surely the vaunted Senior Design group from UCF can scrape together 50 USD - and purchase an LM3S811 EVK - ideal for program AND debug of any Stellaris MCU.  If you read Ms. Cozart's "All about JTAG" post (atop this forum) - many tips from myself/others are included.  You should pull-up all 4 of the JTAG pins - keep leads short - and route directly to a header/connector.  You do not require all 20 of the pins in place on the 3S811 EVK - to save space you may well consider TI's "20 to 10 pin, 0.050" pitch adapter JTAG board."  You would then interpose this 20 to 10 pin adapter between the 3S811 EVK's 20 pin cable - exiting the TI Adapter board with a 10 pin ribbon which plugs-in to your custom board.  (Sometimes PB7 serves a JTAG-like role - your MCU datasheet will reveal.)
      You - your group really do need to read the MCU datasheet and intensely study similar MCU Eval Boards - steal every technique/method - not tied down!  You need many bypass caps - located very close to MCU VDD pins - on all 4 sides of the MCU.  VLDO (if this exists) requires very special treatment - again the datasheet and very similar MCU Eval Board treatments will clue you nicely.  You're obsessing upon the JTAG for programming - yet most any serious MCU board design deals with A-D, serial commo of some sort, outside world to MCU signals - each/every signal destined for the MCU bears thought/consideration - MCUs react poorly to unbounded, out-of-range signal levels - even brief ones.  You may wish to spend some time/effort here - as well...
      You may consider the quick purchase of any low-cost Stellaris based Eval boards you can find - even very basic ones from 3rd parties.  You can learn much from the success of others...   Of course - like so many - your design group started this project way late - mais non?  Allez!
      Report Abuse
      • Reply
    • Rebecca Ringhof
      on May 30 2012 10:17 AM
      Expert6435 points
      Mike,
      Unfortunately, we do not have any footprints for the evaluation kit or parts for Eagle.  Regarding the programming dilemma, cb1's post is very useful.  In addition to that, you may find this application note helpful.
      -Rebecca
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
