• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » stellaris usb
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • stellaris usb
    stellaris usb
    This question is not answered
    tirthesh khicha
    Posted by tirthesh khicha
    on Jun 07 2012 01:19 AM
    Prodigy50 points
    what is the PID/VID no. for lm3s9b96??
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Daniel Ogilvie
      Posted by Daniel Ogilvie
      on Jun 07 2012 09:03 AM
      Prodigy565 points
      Tirthesh,
      Are you referring to DK-LM3S9D96 development kit or are you using the LM3S9B96 in your own design?
      Daniel
      Report Abuse
      • Reply
    • tirthesh khicha
      on Jun 08 2012 01:24 AM
      Prodigy50 points
      Daniel,
      I am using the LM3S9B96 in my design directly. I am trying to implement USB interface directly to program the board, can you please help me with the initial configuration for the same. I already designed the board with the end connection required for the USB only. My hardware is not recognized by PC.
      We already programmes boot_usb.bin(which is given in stellarisware/ file using LM FLASH programmer through UART.
      Tirthesh
      Report Abuse
      • Reply
    • Daniel Ogilvie
      on Jun 08 2012 10:04 AM
      Prodigy565 points
      Tirthesh,
      I'm not exactly sure what you are trying to accomplish. Could you please provide some more information? Are you trying to set up a USB bootloader or are you trying to use USB as an ICDI?  Do you have the ability to program with JTAG?
      Daniel
      Report Abuse
      • Reply
    • Tsuneo Chinzei
      Posted by Tsuneo Chinzei
      on Jun 09 2012 22:53 PM
      Expert2650 points
      tirthesh khicha
      Then, the VID/PID of boot_usb is defined in bl_config.h
      C:\StellarisWare\boards\dk-lm3s9b96\boot_usb\bl_config.h
      // The USB vendor ID published by the DFU device.  This value is the TI
      // Stellaris vendor ID.  Change this to the vendor ID you have been assigned by
      // the USB-IF.
      // Depends on: USB_ENABLE_UPDATE
      // Exclusive of: None
      // Requires: None
      #define USB_VENDOR_ID           0x1cbe
      // The USB device ID published by the DFU device.  If you are using your own
      // vendor ID, chose a device ID that is different from the ID you use in
      // non-update operation.  If you have sublicensed TI's vendor ID, you must
      // use an assigned product ID here.
      // Requires: None
      #define USB_PRODUCT_ID          0x00FF
      Tsuneo
      Report Abuse
      • Reply
    • Mahesh Bhaganagare
      Posted by Mahesh Bhaganagare
      on Jun 11 2012 06:54 AM
      Prodigy10 points
      Daniel,
      basically i want to use alone USB to program my stellaris without the use of JTAG.What i did is made the required circuit and programmed the design with stellarisware/boards/dk-lm3s9b96/boot_usb/ccs/debug/boot_usb.bin using LM FLASH programmer.Now also the board is not recognised by pc.
      Can u Suggest me which to USB driver should i use to make it recognised and is their any mistake in the steps i have taken for the same.please help me for the same.
      Mahesh&tirthesh
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
