• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » Fault ISR : Unaligned Access
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • Fault ISR : Unaligned Access
    This question is answered
    Vinoth Gunasekaran
    Posted by Vinoth Gunasekaran
    on Aug 02 2012 04:53 AM
    Prodigy60 points
    While using pointers and structures, some times i getting this Fault.
    When does this Fault occurs(Unaligned Access) ?
    Vinoth
    Fault ISR
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Kai Gossner
      Posted by Kai Gossner
      on Aug 02 2012 05:25 AM
      Intellectual830 points
      Hi Vinoth,
      unaligned access means, that the pointer you are dereferencing is pointing to a not-aligned adress.
      For best performance (to minimize the count of bus accesses) values should be aligned to their natural size, e.g. the pointer of a 16 bit value to 2-byte, 32 bit values to 4-bytes.
      Example:
      Assume there is a 32 bit value (0x12345678) in memory:
      address value
      0x00000010 0x78
      0x00000011 0x56
      0x00000012 0x34
      0x00000013 0x12
      The pointer 0x00000010 is pointing to an aligned adress, because (0x00000010 & 0x03) = 0.
      address value
      0x00000013 0x78
      0x00000014 0x56
      0x00000015 0x34
      0x00000016 0x12
      Now the 32 bit value is not aligned, because (0x00000013 & 0x03) != 0.
      Cortex M3/M4 cores are able to support unaligned memory accesses, while older ARM cores don't.
      Unaligned accesses should not be used in case speed is important (avoid using packed structs/arrays), but will save memory.
      The generation of this fault can be turned on or off (Feature of the Cortex core). By default it is disabled, so it is very likely that there is something in your code that enables these faults.
      The fault can be disabled in the Configuration Control Register.
      Kai
      Report Abuse
      • Reply
    • slandrum
      Posted by slandrum
      on Aug 02 2012 06:17 AM
      Mastermind9510 points
      The LDM, STM, LDRD and STRD instructions require aligned addresses, even on the Cortex-M3.  For some reason, the compiler may be wanting to generate these instructions - this suggests that you are probably trying to copy chunks of unaligned structures around or have unaligned 64 bit values in your structures.
      Report Abuse
      • Reply
    • Vinoth Gunasekaran
      on Aug 02 2012 06:23 AM
      Prodigy60 points
      You are right, i am copying a chunk of data that belong to a structure through pointers. How could I solve this?
      Report Abuse
      • Reply
    • slandrum
      Posted by slandrum
      on Aug 02 2012 06:31 AM
      Verified Answer
      Verified by Vinoth Gunasekaran
      Generally memcpy is written to be safe to do memory moves regardless of alignment.  Try that.
      How are your structures getting unaligned?  This usually takes extra effort.
      Report Abuse
      • Reply
      on Aug 02 2012 23:59 PM
      Prodigy60 points
      Yes, It worked. Memcpy seems to be a better way to copy chunk of memory.
      Thanks..
      Vinoth
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
