• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » SDK USBMSC
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • SDK USBMSC
    SDK USBMSC
    This question is not answered
    Ed Hillen
    Posted by Ed Hillen
    on Aug 06 2012 15:21 PM
    Prodigy200 points
    I am trying to get USB MSC Host (from SDK) working.  I copied sections of their example which copies from SDCard to USB.
    My call to wait for connect (below) never returns (time out or success).  I make this call after all the other obligatory init calls and after I start BIOS.
    if (!USBMSCHFatFs_waitForConnect(usbmschfatfsHandle, 10000)) {return;}
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 06 2012 15:23 PM
      Prodigy200 points
      Forgot to mention, it only hangs if I have a USB memory stick plugged in.  If not, it times out (as I'd expect).
      Report Abuse
      • Reply
    • Dave Wilson
      Posted by Dave Wilson
      on Aug 06 2012 15:43 PM
      Mastermind22830 points
      Ed,
        Please could you provide a bit more information? I presume you are using MCU SDK and SysBios rather than the examples shipped with StellarisWare? If that's true, I'll have to get hold of someone who knows about that product since I have no experience with MCU SDK as things stand. Which hardware are you running this software on - is it one of our evaluation or development kits or your own board?
        If you are running on one of our eval or development boards, please could you run the usb_host_msc example from the relevant release of StelarisWare and confirm that it works correctly with the USB stick you are using (this ensures that the problem isn't with your hardware). If this example also hangs, please try a different USB stick. We've found many, many sticks that don't comply with the USB standard and this causes problems in our host driver which makes the reasonable assumption that a USB stick won't draw enough current to pull Vbus down and will respond to queries the way it is supposed to!
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 06 2012 16:02 PM
      Prodigy200 points
      I am using an LM3S9D92 with MCU SDK 1.0.0.68.  I am using sys bios.  I am running on cusomt hardware.
      Report Abuse
      • Reply
    • Dave Wilson
      on Aug 06 2012 16:09 PM
      Ed,
        I'll have to figure out who to speak to in the MCU SDK organization or try to set up a development system here with that tool and see if I can reproduce your problem. In the meantime, if you can try building and running usb_host_msc from the ek-lm3s9d92 release of StellarisWare to confirm whether it shows the same problem, that would be enormously helpful. If it shows the same problem, that gives us a far easier debug platform since the example doesn't use any OS and since I have access to all the people who wrote that code and should be able to help you out very quickly. Our lm3s9d92 evaluation kit board is very simple so I imagine that porting the code to your platform will involve very little other than ensuring that the clock configuration (ROM_SysCtlClockSet or SysCtlClockSet) matches your crystal choice and, possibly, removing UART use if your board doesn't use UART0 on PA0 & PA1.
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 06 2012 16:15 PM
      Prodigy200 points
      Pin
      70 USBODM
      71 USBODP
      73 USBORBIAS
      65 USBPFLT
      66 USBOID
      67 USB0VBUS
      72 USB0EPE
      My init code (before bios starts):
          /* Enable the USB peripheral and PLL */
          SysCtlPeripheralEnable(SYSCTL_PERIPH_USB0);
          SysCtlUSBPLLEnable();
          /* Setup pins for USB operation */
          GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
          /* Additional configurations for Host mode */
          if (usbMode == USBHOST) {                 // this is TRUE since I’m dedicated host
              /* Configure the pins needed */
              GPIOPinConfigure(GPIO_PB2_USB0EPEN);
              GPIOPinConfigure(GPIO_PB3_USB0PFLT);
              GPIOPinTypeUSBDigital(GPIO_PORTB_BASE, GPIO_PIN_2 | GPIO_PIN_3);
      My code to mount USB (after bios):
          /* Mount and register the USB Drive */
          USBMSCHFatFs_Params_init(&usbmschfatfsParams);
          usbmschfatfsHandle = USBMSCHFatFs_open(USBMSCHFatFs0, USB_DRIVE_NUM, &usbmschfatfsParams);
          if (usbmschfatfsHandle == NULL) {
              System_abort("Error starting the USB Drive\n");
          else {
              System_printf("Drive %u is mounted\n", USB_DRIVE_NUM);
          /* Need to block until a USB Drive has been enumerated */
            return;
      Report Abuse
      • Reply
    • Andy Neil
      Posted by Andy Neil
      on Aug 06 2012 18:12 PM
      Guru31975 points
      Ed Hillen
      it ... hangs if I have a USB memory stick plugged in
      Can you step into the function to see where, exactly, it is "hanging" ?
      Report Abuse
      • Reply
    • Dave Wilson
      on Aug 07 2012 07:52 AM
      It would be enormously helpful if you would try running the usb_host_msc application. I see you are using PB2/3 for USB0EPEN and USB0PFLT so you would have to modify the example source to move these from PH3/4 as used on our ek-lm3s9d96 board but, other than this, I think you should be able to run the code pretty much as it is. As I mentioned, this takes the OS out of the equation and would allow me to help you out a lot quicker since all the code in that application came from within 2 offices of where I sit.
      The code you posted doesn't tell me the full initialization story. I don't see any SysCtlPeripheralEnable() call for GPIO port B (though you must be making this since, otherwise, the GPIOPinConfig() calls for the port would be faulting) and I can't tell how your system clock and SysTick are configured. These may be important.
      As Andy Neil asked, it would also be helpful if you could tell us what debug steps you have taken already and what you have found. Is the hang caused by something blocking on a semaphore or mutex, something stuck in a polling loop, a fault (if so, which fault and where is it?), etc. ,etc.
      As I mentioned before, we have seen quite a few problems with bad flash sticks so it would also be great if you could verify that you've tried running with multiple USB flash sticks including at least one from a premium brand (which is more likely to be spec-compliant). If the problem turns out to follow the flash stick, we may ask you for more details or a sample of the problem device so we can see what it is doing and try to work around whatever problem it is causing.
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 07 2012 08:19 AM
      Prodigy200 points
      When I pause code, it seems to be in the USBHHubMain routine inside the following loop:
      for(ucPort = 0; ucPort <= g_pRootHub->ucNumPortsInUse; ucPort++)
      The ucNumPortsInUse variable is 0xFF ?
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 07 2012 08:53 AM
      Prodigy200 points
      It appears (to me) that example DK uses PA6 and PA7 (not PH 3/4)... but anyhow, I think I changed (see below).
      GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);GPIOPinConfigure(GPIO_PB2_USB0EPEN);
      You also mention, "I don't see any SysCtlPeripheralEnable() call for GPIO port B (though you must be making this since, otherwise, the GPIOPinConfig() calls for the port would be faulting) and I can't tell how your system clock and SysTick are configured. These may be important."
      I have the following lines, is this what you are referring to?
      Where can I find the usb_host_msc application in the SDK?
      Report Abuse
      • Reply
    • Dave Wilson
      on Aug 07 2012 09:21 AM
      Ed,
        You are looking at a different version of usb_host_msc. The version from the dk-lm3s9b96 or dk-lm3s9d96 release of StellarisWare contains a bunch of graphics code and is for a board that is rather different from yours (I suspect). The one in the ek-lm3s9d92 kit will be a lot easier to port since that is a far simpler board and since it doesn't assume the presence of a QVGA touchscreen.
        As I mentioned, I have no experience of the MCU SDK so don't know if this example exists. I would love it if you could try the version from the base StellarisWare package (which you can download from here) and see if it shows the same problem. If the problem is still seen there, that rules out the OS or the port as culprits and we can debug using the simpler app. If the problem goes away, that tells us that something in the SysBios port or in the OS-dependent sections of the application are to blame.
        Once you download and install the StellarisWare package, look in C:\StellarisWare\boards\ek-lm3s9d96\usb_host_msc for the example. You will find read-made CCS project files for all the examples so these can be imported into a clean CCS workspace to allow you to build and debug the code easily.
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 07 2012 09:42 AM
      Prodigy200 points
      Dave,
      I know the project you're referring to; I had it running on the DK.  My problem is that I have customer hardware and my project (for my board) uses sysbios.  I can try and run that example outside sys bios but I'm not sure how to configure the fatfs and usb stuff in the midst of other parts of my project using sys bios.  Ideas?
      Do I un-select fatfs and usb msc host from my config and then use snippets from the non-sysbios example?  What drivers/libs do I need to include?
      Report Abuse
      • Reply
    • Dave Wilson
      on Aug 07 2012 09:56 AM
      We've reached a point where I can't offer any help since I know nothing about SysBios. Let me try to find someone round here who has used it to see if they can offer any assistance. I was hoping we could narrow down the problem area without having to use the full application with the OS. The basic question I am trying to answer (and which you definitely need to figure out) is whether your custom board's USB implementation is up and running correctly. To verify this, I strongly suggest using smaller, simpler testcases. Once you are 100% sure the base USB is rock-solid, then move on to the larger, more complex applications.
        While I'm looking for SysBios help, could you verify that you have thoroughly checked out your USB host hardware and can enumerate simple devices successfully using variations on some of the usb_host_xxx applications included in StellarisWare or your own testcases?
        More later...
      Report Abuse
      • Reply
    • ToddMullanix
      Posted by ToddMullanix
      on Aug 07 2012 15:55 PM
      Genius15600 points
      Hi Ed,
      Can you attach your board source files (e.g. DK_LM3S9D92.c, DK_LM3S9D92.h and DK_LM3S9D92.cmd). Are the rest of the project files similar to the mcusdk's fatsdusbcopy example?
      Todd
      Report Abuse
      • Reply
    • Tom Kopriva
      Posted by Tom Kopriva
      on Aug 07 2012 17:34 PM
      Expert6440 points
      Hi Ed,
      also check your project's predefined symbols option. Make sure you update it for your part.
      Tom
      Report Abuse
      • Reply
    • Ed Hillen
      Posted by Ed Hillen
      on Aug 08 2012 08:54 AM
      Prodigy200 points
      Please see my previous posts for my code.   Below you'll find my data declarations.  My project has numerous other (non-usb) related io drivers.  I've copied the code (posted) from the example and changed the USB IO for the two pins (pen and flt) that are different for my target.  FYI, my usb host (A cnctr) is powering device.
      USBMSCHFatFs_Object USBMSCHFatFsObjects[USBMSCHFatFsCOUNT];
      /* USBMSCHFatFs configuration structure, describing which pins are to be used */
      const USBMSCHFatFs_HWAttrs USBMSCHFatFsHWAttrs[USBMSCHFatFsCOUNT] = {{INT_USB0}};
      const USBMSCHFatFs_Config USBMSCHFatFs_config = {USBMSCHFatFsCOUNT, USBMSCHFatFsObjects, USBMSCHFatFsHWAttrs};
      USBMSCHFatFs_Handle usbmschfatfsHandle;
      USBMSCHFatFs_Params usbmschfatfsParams;
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
