• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » ARM CORTEX M3
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • ARM CORTEX M3
    ARM CORTEX M3
    This question is answered
     stellaris dinesh
    Posted by stellaris dinesh
    on Aug 09 2012 23:48 PM
    Intellectual605 points
    hi geeks,thank you in advance i have doubt in lm3s6965 evaluation kit. can i change the freqency and voltage of the processor and  peripheral dynamically in run time.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • cb1_mobile
      Posted by cb1_mobile
      on Aug 10 2012 08:36 AM
      Guru21740 points
      Do you care to - perhaps - "lift the curtain" a bit so that, "change the voltage of the processor" is made somewhat clear?
      Suspect that, "System Frequency" change is possible - provided that you obey the crucial linkage to MCU on-board xtal matching its mated parameter w/in "SysCtlClockSet()."  We have - 3-4 years past - employed this in the attempt to reduce power draw and/or achieve slight "performance tweaks" during mission-critical code segments.  (Very briefly)  This may be Stellaris device sensitive - suggest that you not try this on an, "unrecoverable Stellaris MCU."  (i.e. Sandstorm)
      Report Abuse
      • Reply
    •  stellaris dinesh
      on Aug 11 2012 03:57 AM
      cb1_mobile thank you for reply. i am beginner of  TI microcontroller. so please can you give me detail information about my question and your reply
      Report Abuse
      • Reply
    • cb1_mobile
      on Aug 11 2012 09:58 AM
      Guru21740 points
      dinesh arunachalam
      Both questions you ask seem very unusual for a "beginner" - unless you're migrating from another MCU - and have encountered just such issues.  Should that be the case - one suspects that you've developed test/verify protocols - and should be able to adapt these for use w/Stellaris.
      Remains unclear to myself/others as to "why" you've chosen those specific questions...
      Report Abuse
      • Reply
    • Andy Neil
      Posted by Andy Neil
      on Aug 11 2012 10:30 AM
      Guru31975 points
      cb1_mobile
      Indeed!
      http://www.catb.org/~esr/faqs/smart-questions.html#goal
      Describe the goal not the step
      Report Abuse
      • Reply
    •  stellaris dinesh
      on Aug 11 2012 12:38 PM
      cb1_mobile thank you. i am migrating from NXP to TI MCU. i am going to do my Post graduate project in power efficient embedded web server. for saving the power consumption i should use DVFS algorithm. Could it be posibble?? help me!!
      Report Abuse
      • Reply
    • cb1_mobile
      on Aug 11 2012 13:10 PM
      Guru21740 points
      Aha - curtain at last opened - now some, "reachable target" revealed!  Might it make sense to include such detail - from your very first post?  Vagueness and nature of 1st post drew me in - but I am, "out of my league" re: your issue.   At least - with new detail provided - others should be better able to assist.  Good luck...
      Report Abuse
      • Reply
    •  stellaris dinesh
      on Aug 11 2012 13:38 PM
      cb1_mobile :) :)!!!... i have this idea to do and i also do not have comlpete figure. now only i started  with lm3s6965 ADC peripheral.
      Report Abuse
      • Reply
    • cb1_mobile
      on Aug 11 2012 14:36 PM
      Guru21740 points
      Forgive me - your task appears large - very ambitious - and much outside my limited expertise/competence.  (if any)  Myself/others here may be able to guide you w/basics of Stellaris set-up/operation - but detailed help you likely require - beyond my pay-grade.
      Do suggest that you allow plenty of time to explore w/your Stellaris - rush most always leads to unpleasant results - will set you back in the long run.  ADC peripheral you mention is one of the more complex ones - I'd suggest that you start w/simple GPIO and then progress to simple Timer, then perhaps UART.  After mastering those - believe you'll be stronger/more confident with your MCU and IDE - thus better able to do battle w/ Stellaris ADC.  ADC is powerful - but trades performance for quick understanding/mastery - really not an ideal "first learning" choice.
      Wish you well - you may wish to follow my guide and then prepare fresh post - with much more focused/clear topic - to receive further assistance.  Bon chance mon ami...
      Report Abuse
      • Reply
    •  stellaris dinesh
      on Aug 11 2012 14:57 PM
      Verified Answer
      Verified by stellaris dinesh
      cb1_mobile :) :) thank you :)... i do  hope for improvement
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
