Stellaris® ARM® Microcontrollers
Forum
Options
Subscribe via RSS
Helpful Stellaris® LM4F Series Links
LM4F Series
Stellaris PinMux Utility
Stellaris® LM4F120 LaunchPad
LM4F MCU Applications
LM4F MCU Video
ARM Cortex-M4F Whitepaper
Stellaris MCU Brochure
LM4F232 Eval Kit
Some helpful hints
Some helpful hints
Posted by
dfowler7437
on
Oct 28 2006 18:21 PM
Prodigy
30
points
The Stellaris Driver Library Users Guide PDF is located at
C:KeilARMRV30LIBLuminary sw02034uvision-852.pdf
The library is installed with the Keil tools and is used by the sample projects. It has functions for just about everything as far as I can tell with a first look. The stuff I read did not mention the documentation so I hunted around a bit.
Install sockets in the test points and mount the evaluation board to a large electronics breadboard. The sockets make it easy to run jumper wires and do experiments. You can see my version of this at:
http://www.uchobby.com/index.php/2006/10/28/super-microcontroller-breadboard/
David Fowler
http://www.uCHobby.com
Report Abuse
Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
