Stellaris® ARM® Microcontrollers
Forum
Options
Subscribe via RSS
Helpful Stellaris® LM4F Series Links
LM4F Series
Stellaris PinMux Utility
Stellaris® LM4F120 LaunchPad
LM4F MCU Applications
LM4F MCU Video
ARM Cortex-M4F Whitepaper
Stellaris MCU Brochure
LM4F232 Eval Kit
LM3S6965 beginner
LM3S6965 beginner
Posted by
accacca48908
on
Jul 30 2008 09:34 AM
Prodigy
110
points
I am starting new application prject with Luminary ARM
I use the EKK eval board and KEIL limited compiler
Is first time I use ARM and I have some problems installing development tools
I describe all my problems...and solutions I hope help other beginners
First I have installed Keil IDE from CD but when I start the Keil IDE the compiler crash and an error message appear Read this disccussion in keil forum
http://www.keil.com/forum/docs/thread10980.asp
and solve first problem (download new keil version and replace first installed)
Next I have programmed my board with sample program Blinky. Be careful in KEILARMBOARDSLuminary directory
you can found ek-LM3S6965 and ek-lm3s6965_revc
use the appropriate sample for your eval board
When project is loaded open the project options and select DEBUG tab select debug option with "Luminary eval board" next select Utilities tab and change to "Luminary eval board"
Ok ready to program select flash menu and program All work ok (I hope) If no remove and replug eval board usb cable before next flash reprogramming.
If all ok start debug but debug can't work !!
Read this link
http://www.keil.com/support/docs/3411.htm
update TLM.DLL and all is ok!!
Post edited by: accacca, at: 2008/07/30 09:47
Report Abuse
Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
