• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » PCB Layout Guidlines for Ethernet?
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • PCB Layout Guidlines for Ethernet?
    • rocksoft
      Posted by rocksoft
      on Sep 18 2007 04:18 AM
      Prodigy220 points
      Any PCB layout guidlines exist for the LM3S6965, specifically the connections and layout for connecting the PHY to the magnetics?
      In fact any PCB related hardware documentation at all? Lots of good documents from the software point of view here but not an awful lot "obviously" available for hardware design... schematic symbols, chip footprints etc...
      Liam Redmond.
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • Omer Peleg
      Posted by Omer Peleg
      on Feb 09 2008 06:31 AM
      Intellectual610 points
      I'm looking for PCB guidelines as well, such as Board type, recommended trace width, etc...
      Report Abuse
      • Reply
    • Lamont Lucas
      Posted by Lamont Lucas
      on Feb 21 2008 20:24 PM
      Prodigy30 points
      I'd like to third the request. I'm looking for any reference designs for the 3s811, but I'd take general schematic suggestions or layout suggestions.
      Report Abuse
      • Reply
    • CaptainSC59
      Posted by CaptainSC59
      on Feb 23 2008 13:26 PM
      Prodigy10 points
      I'd like to add my voice to this. EVB schematics are nice, but don't offer the necessary detail.
      Report Abuse
      • Reply
    • TI - Eric Hewing
      Posted by TI - Eric Hewing
      on Mar 03 2008 09:18 AM
      Expert4160 points
      We have an application note planned for board layout recommendations. When it is ready, I will post a message indicating it can be downloaded.
      Report Abuse
      • Reply
    • Dean
      Posted by Dean
      on Mar 24 2008 16:57 PM
      Prodigy30 points
      We also need some more information regarding the selection of the ethernet magnetics. There are a lot of choices out there and virtually no guidance with respect to the particular needs of the Luminary PHY.
      Put another way... Can anyone tell me what factors were used in the selection of the part used on the LM36965 Evalutation Board? It uses a Pulse J3011G21DNL - See http://www.pulseeng.com/products/datasheets/J409.pdf
      Here is one source of info. See the curious comments on slide 46 of http://www.scvemc.org/files/Ethernet_Magnetics_EMI.pdf
      (his diagram seems reversed, however)
      Is there a better choice of information out there?
      Report Abuse
      • Reply
    • matten
      Posted by matten
      on Jun 26 2008 08:04 AM
      Prodigy195 points
      His diagram isn't reversed, it's just a different kind of magnetics design. The Pulse J3011G21DNL is of the "2-Line CM Choke on the Cable Side" kind, as shown on slide 63 of the presentation.
      Still waiting for that application note, Luminary...
      Post edited by: matten, at: 2008/06/26 08:04
      Report Abuse
      • Reply
    • mpathma
      Posted by mpathma
      on Sep 25 2008 05:02 AM
      Prodigy230 points
      This is my 1st post, so, excuse if it sound stupid...
      we are ready to develop PCB board using LM3S6911.
      I could not find enough information to complete the schematic.
      I planing to use the EKT-LM3S6955 to program/debug my 'going to be developed board'
      My development tool will be Code-Red.
      My question,
      Can anyone please provide example schematic which has the following;
      1. programmable via EKT-LM3S6955 evaluation kit
      2. UART Port(Rs-232, 115Kbps)
      3. Interface to SD card (micro)
      4. I2C line connected to DS1307+ (RTC chip)
      5. LAN Interface (recommended suitable magnetic)
      6. 10-GPIO
      I can take care the regulator, reset, crystal, 232 line interface and other external module.
      I need support on which pin/port need to be used on the above requirement.
      I know what I am asking to a lot, you assistance is highly appreciated and when you are in Malaysia, I take you for beer... ;-)
      Report Abuse
      • Reply
    • Dave Wilson
      Posted by Dave Wilson
      on Sep 25 2008 08:14 AM
      Mastermind22830 points
      The full schematic for the EKB-LM3S6965 eval kit is actually in the user manual. As far as I can tell, this board contains everything on your list with the exception of the I2C RTC module but the I2C is not used on the board so it should be very straightforward to add it yourself.
      If you want to download the manual, you can find it on this page. It's also on the CD that comes with the 6965 board.
      Please post a reply if there is anything else you need.
      Report Abuse
      • Reply
    • jrmymllr
      Posted by jrmymllr
      on Sep 02 2010 11:32 AM
      Expert1180 points
      TI - Eric Hewing
      I figured after 2.5 years this would be done.  Is there an app note?
      Report Abuse
      • Reply
    • antoker
      Posted by antoker
      on Nov 07 2010 05:25 AM
      Intellectual310 points
      When it comes to routing  differential eth lines standard rules apply (short tracks, continious return path and controlled impedances)
      for a standard 1.6mm FR4 four layer pcb an adequate trace width of 0.22mm with 0.2mm spacing will result in
      approximate Zdiff of 100 (5-10% tolerances depending on your manufacturer) for a differential microstrip. What
      I usually do is to make a rough estimate of the single ended impedance of the track and use it to make a plot
      of resulting differential impedance versus track separation, then I pick a width space ratio that looks sane. After the
      layout is done and I'm about to send my odb/gerbers into production I specify the parameters of the stackup and
      impedances (frequency range as well), so the pcb manufacturer can refine my design (if necessary) since they know their
      production capabilities much better, they also run an impedance test on the produced pcb to verify the target impedance.
      Hope this helps.
      Taking a look at the datasheet for any ethernet enabled uC tells you that the following Isolation transformers will work (and Jacks with magnetics):
      ■ Isolation Transformers
      – TDK TLA-6T103
      – TDK TLA-6T118
      – Bel-Fuse S558-5999-46
      – Halo TG22-3506ND
      – Halo TG110-S050
      – PCA EPF8023G
      – Pulse PE-68515
      – Valor ST6118
      – YCL 20PMT04
      ■ Isolation transformers with integrated RJ45 connector
      – TDK TLA-6T704
      – Delta RJS-1A08T089A
      ■ Isolation transformers with integrated RJ45 connector, LEDs and termination resistors
      – Pulse J0011D21B/E
      – Pulse J3011G21DNL
      Report Abuse
      • Reply
    • sanchayan maity
      Posted by sanchayan maity
      on May 05 2011 01:01 AM
      Expert1690 points
      No App note  still!! Wow! Great!  More than 2 years gone.
      Report Abuse
      • Reply
    • glennsky
      Posted by glennsky
      on Sep 29 2011 20:12 PM
      Intellectual300 points
      Amazing!  I just stumbled upon what looks like the appnote many people have been waiting for - AN01283 - System Design Guidelines for Stellaris Microcontrollers.   Seems incredible that basic info like this is only now coming out.
      http://www.ti.com/litv/pdf/spma036
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
