• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » LM3S811 OLED DOA?
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • LM3S811 OLED DOA?
    LM3S811 OLED DOA?
    • steriana
      Posted by steriana
      on Oct 05 2006 14:09 PM
      Prodigy50 points
      Hello all,
      I just received my LM3S811 evaluation kit and the OLED is flaky. The demo application that is supposed to start showed the "splash screen" with the Luminary logo exactly once, and I can't get it to do it again. I installed the Keil tools, can compile and download programs without any trouble (hello and the qs_ev-lm3s811 projects), but the OLED is just blank.
      After 2 minutes, the USER LED starts pulsing to indicate the scren saver, so I think the rest of the board is working OK (power LED is on), but the OLED remains blank.
      Are there any settings in the uVision tool (clock frequency?) that are wrong by default? or is the board just DOA?
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • pawel48758
      Posted by pawel48758
      on Oct 06 2006 11:09 AM
      Intellectual380 points
      Looks like a bit of a bad luck. These OLEDs modules seem to be quite fragile and are just glued to the board without any support. You could try doing following (it is not a magic trick!) upload the original software, turn on the board and touch the screen with your finger and then very gently rock it just a bit back and forth. See if you get anything on the screen. You might get lucky and get it to work but in any case I would ask for replacement. Another possibility is the static discharge, any chance of that happening when you were handling the board?
      Pawel
      Report Abuse
      • Reply
    • tim_admin
      Posted by tim_admin
      on Oct 06 2006 17:38 PM
      Prodigy90 points
      Unless Pawel's wiggle suggestions work for you, it does sound as if your OLED is DOA. Those OLEDs are very cool but they are a bit fragile.
      If you bought your EKK-LM3S811 from a distributor, please contact the distributor to get an RMA number and they'll replace your kit as quickly as possible.
      If you received your EKK-LM3S811 from Circuit Cellar as part of the design contest, please contact Luminary Micro's customer service at customer.service@luminarymicro.com for an RMA number, and we'll replace your kit as quickly as possible.
      Jean Anne Booth
      Luminary Micro
      Report Abuse
      • Reply
    • steriana
      Posted by steriana
      on Oct 06 2006 18:56 PM
      Prodigy50 points
      Thanks...I have requested an RMA. Today, the OLED came on and displayed the LMI logo briefly before going (and staying) blank. This was repeated for about 5 insert-remove cycles of the USB. Then, the logo only came on (scrolling upwards) for a fraction of a second before going dark. Maybe there's a temperature dependence somewhere that arises as the parts heat up.
      It's maddening because the OLED works, but only sometimes and only for a brief second! Pawel's suggestion did not make any difference, unfortunately.
      Anyways...thanks for the support.
      Report Abuse
      • Reply
    • mtnclimb
      Posted by mtnclimb
      on Oct 14 2006 19:37 PM
      Prodigy30 points
      Mine was DOA also. I fixed it though. I used a very steady hand and my SMD tip on the soldering iron. I just touched each of the ribbon cable pads for a couple seconds to remelt the solder. This seem to fix which ever solder joints were loose, the display works great now. Good luck.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
