• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Tiva™ ARM® Microcontrollers » Tiva™ ARM® C Series Microcontrollers Forum » Apertures in EKI-LM4F232 board
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Alexander Uvarov
Posted by Alexander Uvarov
on Apr 27 2012 07:55 AM
Prodigy250 points
Hello!
On the photo at EKI-LM4F232 page (http://www.ti.com/tool/eki-lm4f232) there are 4 apertures in the board corners. But in the actual device, that I use there are not. So my question is could I drill it without any damage for the board?
Thanks, Alex.
LM4F232 aperture board EKI-LM4F232
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Stellaris Ken
    Posted by Stellaris Ken
    on Apr 27 2012 10:13 AM
    Verified Answer
    Verified by Alexander Uvarov
    Expert3265 points
    Hi Alex,
      This is a multi layer board.  You risk shorting out the internal layers of the board if you drill in the corners.  I do not recommend drilling the board.
    - Ken
    Report Abuse
    • Reply
  • Alexander Uvarov
    on Apr 27 2012 22:10 PM
    Prodigy250 points
    Thanx for quick answer, Ken!
    I know that this board is multi layer, but anyway TI's engineers did it according to the photo. So that is why I supposed that it's possible without any damage. All I want to know is there any hidden layer in board corners.
    Alex.
    Report Abuse
    • Reply
  • Andy Neil
    Posted by Andy Neil
    on Apr 28 2012 00:19 AM
    Verified Answer
    Guru32055 points
    Alexander Uvarov
    I think that is highly unlikely!
    I very much doubt that TI engineers actually drilled the holes themselves!
    Almost certainly, the photo shows a (slightly) different revision of the boad - which was manufactured with the holes in it.
    Report Abuse
    • Reply
  • cb1-
    Posted by cb1-
    on Apr 28 2012 03:35 AM
    Verified Answer
    Mastermind9430 points
    Alexander Uvarov
    Suspect that poster/interested others really seek method to: "Safely/easily mount" this "mounting-hole free," relatively expensive pcb.  (who/where pcb drilled was unfortunate word choice by non-native English speaker - "seized" (by follow-up) as means to state the obvious - yet without significant thought/merit.)   Proposed instead - several "safe/real" solutions with added benefits...
    Here's what's worked for our group: inserted male, single row headers, from the top of M4F Eval board.  This provided greatest use of the Eval bd.  Second board (our custom,  general application board) - inserted precisely mating, female, single row sockets, from the bottom of our 2nd/application bd.  Thus the Eval board mounts firmly beneath our application board - held by the friction of >80 header/socket joints.  (while enabling fast board to board disconnect - or the creation of different, application boards.)   Note that each/every edge pin from the Eval board is accessible from our (top) application board (we used female sockets with longer male pins - these pins enable easy connection (just as they do on the Eval board with male pins inserted from top) but with the added benefit of our including signal identification on the top, Ap board's silk screen.  (unfortunately "missed" on M4F QFP Eval - but included on earlier M4F BGA Eval - this proves both an enormous "time-saver" and serves to provide some protection against signal "mis-routing" - caused by the abundance of heretofore, "unmarked" pins.
    Those still interested/awake note mounting info still awol...  Our application pcbs include, "mounting tabs" - which include the "over-looked" mounting holes.  These tabs are pre-scored (enabling easy "separation") - projecting both from each side and top/bottom of the Ap board.   Standard hardware (plastic spacers) then pass just beyond (i.e. wider or longer than) the Eval board to enable our 2-board "assembly" to mount to a chassis/enclosure.
    Note - method described won't soon fly on the Shuttle (BTW - Shuttle RIP) nor work "issue-free" in other high vibration environments.  (not really the intention of an Eval board)
    Those not adding custom circuitry (i.e. larger, more legible display, mini-joystick, keypad, audio transducer etc) may velcro small pcb "squares" (which hold pre-mounted, "headless" screws) to the bottom of the Eval board - "maintaining" the Eval board's footprint and eliminating any 2nd board addition.  May also insert Eval board's "edges" into mated slots of non-conductive, "stand-off slabs."  These add to Eval's footprint - but immobilize it - and of course include the "missing" mounting holes...
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 01 2012 22:54 PM
    Prodigy250 points
    Thanks a lot!
    I already have a solution with connection by row sockets. It was just the attempt to find a way for stronger joining.
    And sorry for my English, I'll try to improve it :)
    Regards, Alex.
    Report Abuse
    • Reply
  • cb1_mobile
    Posted by cb1_mobile
    on May 02 2012 09:18 AM
    Guru23760 points
    Alex-
    You need not apologize - your English quite good - it is very tough, inconsistent language - with strange rules.  And you're using technical terms - not likely to appear on TV or movies (how many learn language).
    We've performed, "Shake/Bake" chamber testing with 4F Eval Board mounted via mating sockets (as I outlined).  So far has passed - quality of sockets may be large factor.  Good luck...
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 14 2012 03:27 AM
    Prodigy250 points
    Thanks!
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
