Hi there,
I have an EK-TM4C123GXL Evaluation kit which i used several times and things were going great.
Recently i was trying a new program which i downloaded to the board and was debugging it ,then suddenly the debugging crashed with no obvious reason and when i tried to modify the code and run the debugger (simulation) again the program gave me this message (could not initialize target device) and then the program crashes!!!
I googled the problem and tried everything i found but in vain.The things i tried are as follows:
1- I uninstalled keil and then installed it again on my laptop.
2-I tried to install keil on a different pc.
3-I used lm flash programmer to erase the flash of the microcontroller.
Please tell me what also should i do to be able to use my board again.
Finally,these are the screen shots of the error
Thank you for your effort :)
