Specifically I have an touchscreen LCD boosterpack with micro SD.
It uses one SSI with 3 chip selects.
I would like to use hardware control as this is a multi-tasking, multi-processor, soft real-time system I am building and I like a buffer.
When I attempt to configure the fss pin as GPIO output and call
SSIDataPutNonBlocking(SSI2_BASE, command);
I get a fault. Is there anyway I can toggle my own chip select pins and use the hardware, or am I stuck bit banging it?
Michael Kadie
SSI-Racing.com
Green is as sexy as you build it.
