It can be programmed an TM4C1230H6PMI using an EK-LM4F120XL kit?
Ale.
Ale.
Hi Ronie,
Thank you.
There is a scheme that can be used as a guide for the connection?
Ale.
Ale,
Tiva C Launchpad Guide manual has Launchpad schemetic.
http://www.ti.com/lit/ug/spmu296/spmu296.pdf
And as you can see, there are some holes for adding extra pins.
You can solder for connecting external MCU chip. ( At that time, you should care about the power switch . You must turn off power switch for Launchpad main MCU chip. )
Thank you.
Ronie
