Hello, my case is as follows:
I'm using the tool DK-TM4C129 with a TFT LCD 10 " screen 640x480, the what can only operate in raster mode via the LCD driver MCU. I used the sample code "raster_example" which comes in the "TivaWare_C_Series-2.1.0 package. I've made some changes to the code to display correct information. The problem I have is that the objects sent me the screen always repeated in another position on the screen but distorted. Add source code.
I have been making changes in synchrony times to see if the problem is here but does not correct the problem. I hope you can help me see what is happening. Also I have a photo of the image you see where the error is better appreciated.
//***************************************************************************** // // raster_example.c - An example showing the use of the TM4C129x LCD // controller in raster mode. // // Copyright (c) 2012-2014 Texas Instruments Incorporated. All rights reserved. // Software License Agreement // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // // This is part of revision 2.1.0.12573 of the Tiva Firmware Development Package. // //***************************************************************************** #include <stdint.h> #include <stdbool.h> #include "inc/hw_sysctl.h" #include "inc/hw_types.h" #include "inc/hw_memmap.h" #include "inc/hw_gpio.h" #include "inc/hw_ints.h" #include "inc/hw_lcd.h" #include "driverlib/sysctl.h" #include "driverlib/gpio.h" #include "driverlib/lcd.h" #include "driverlib/interrupt.h" #include "driverlib/rom.h" #include "driverlib/rom_map.h" #include "grlib/grlib.h" #include "utils/uartstdio.h" #include "utils/ustdlib.h" #include "drivers/grlib_raster_driver_1bpp.h" #include "drivers/grlib_raster_driver_4bpp.h" #include "drivers/grlib_raster_driver_8bpp.h" #include "drivers/grlib_raster_driver_16bpp.h" #include "drivers/raster_displays.h" #include "drivers/sdram.h" #define LXD_DISPLAY #define RASTER_WIDTH 640 #define RASTER_HEIGHT 480 //***************************************************************************** // //! \addtogroup lcd_examples_list //! <h1>LCD Controller Raster Mode Example (raster_example)</h1> //! //! This application illustrates the use of the Tivaware Graphics Library //! and Tiva TM4C129x LCD controller driving an 800x480 display using raster //! (HSYNC/VSYNC/ACTIVE/DATA) mode. The display is initialized and enabled //! then a simple pattern including lines, a small image, some text and a //! circle is displayed. //! //! By default, the application is set up to support an Innolux EJ090NA-03A //! display with 800x480 resolution, refreshed at 60Hz from a 16bpp frame //! buffer stored in SDRAM. The SDRAM is attached to the MCU via the External //! Peripheral Interface (EPI) module. The file drivers/raster_displays.c //! contains timings and initialization functions for several other displays //! and the application can be easily rebuilt to support any of these by //! replacing the preprocessor define ``\b INNOLUX_DISPLAY'' with one of the //! other display labels: //! //! - \b OPTREX_DISPLAY supports an Optrex T-55226D043J-LW-A-AAN in 800x480 //! with 75Hz refresh rate. //! - \b LXD_DISPLAY supports an LXD M7170A in 640x480 with 60Hz refresh rate. //! - \b FORMIKE_DISPLAY supports at Formike KWH070KQ13 in 800x480 with 60Hz //! refresh rate. //! //! Display interface timing information and any required initialization code //! is included in the file lcd/drivers/raster_displays.c. New raster-mode //! displays can be added to this file and raster_displays.h very easily and //! used by the application merely by adding another display label and //! appropriate code to set the tRasterDisplayInfo timing structure for that //! display at the top of raster_example.c. //! //! Once appropriate display timings have been determined, the display can be //! used by the TivaWare Graphics Library via one of the supplied raster mode //! display drivers. Four distinct drivers are supplied in the lcd/drivers //! directory, each supporting a different color depth for the frame buffer: //! //! - \b grlib_raster_driver_1bpp.c supports a monochrome (2 color) display //! buffer. //! - \b grlib_raster_driver_4bpp.c supports a 4 bit per pixel (16 color) frame //! buffer. //! - \b grlib_raster_driver_8bpp supports an 8 bit per pixel (256 color) frame //! buffer. //! - \b grlib_raster_driver_16bpp supports a 16 bit per pixel (65536 color) //! frame buffer. //! //! The size of frame buffer required varies with the resolution of the LCD //! display in use and the desired frame buffer color depth. Note that the //! frame buffer color depth may be lower than the native color resolution of //! the LCD panel - the LCD controller makes use of a color lookup table or //! palette to convert the pixels in the frame buffer to the correct color //! format for the LCD's hardware interface. //! //! The size of frame buffer, in bytes, can be determined using the following //! formula: //! //! Buffer Size = X * Y * (BPP / 8) + (Header Size) //! //! where: //! //! - X is the horizontal pixel resolution of the LCD panel //! - Y is the vertical pixel resolution of the LCD panel //! - BPP is the desired number of bits per pixel for the frame buffer //! - Header Size is 512 for 8bpp frame buffers or 32 for all other color //! resolutions. //! //! The frame buffer header contains information informing the LCD controller //! of the pixel format in the frame buffer and also the color lookup table //! used for 1, 4 and 8bpp cases. Note that a 32 byte header is still required //! even when using 16bpp frame buffers which do not require a color lookup //! table. //! //! For large panels such as those described in raster_displays.h, a frame //! buffer supporting more than two colors is likely to be too large to fit //! in the internal memory of a TM4C129x device and would, therefore, require //! the use of external, EPI-connected SDRAM. The 16bpp 800x480 frame buffer //! used in this application requires almost 940KB of RAM for example. For lower //! resolution displays or lower color depths, internal SRAM may be suitable //! for use as the frame buffer. For example, a 16bpp QVGA (320x240) frame //! buffer occupies about 150KB of storage and a monochrome (1bpp) 800x480 //! frame buffer needs only 48KB. // //***************************************************************************** //***************************************************************************** // // Pointer to EPI SDRAM if available. // //***************************************************************************** uint16_t *g_pui16SDRAM; //***************************************************************************** // // Frame buffer and palette size. // //***************************************************************************** #ifdef OPTREX_DISPLAY const tRasterDisplayInfo *g_psDisplayMode = &g_sOptrex800x480x75Hz; #define SCREEN_BPP 16 #else #ifdef LXD_DISPLAY const tRasterDisplayInfo *g_psDisplayMode = &g_sLXD640x480x60Hz; #define SCREEN_BPP 16 #else #ifdef FORMIKE_DISPLAY const tRasterDisplayInfo *g_psDisplayMode = &g_sFormike800x480x60Hz; #define SCREEN_BPP 16 #else #ifdef INNOLUX_DISPLAY const tRasterDisplayInfo *g_psDisplayMode = &g_sInnoLux800x480x60Hz; #define SCREEN_BPP 16 #else #error Target display type is not defined! #endif #endif #endif #endif #define SIZE_BUFFER ((RASTER_WIDTH * RASTER_HEIGHT * SCREEN_BPP) / 8) #define SIZE_PALETTE ((SCREEN_BPP == 8) ? (256 * 2) : (16 * 2)) //***************************************************************************** // // Pointers to the frame buffer into SDRAM. // //***************************************************************************** uint32_t *g_pui32DisplayBuffer; uint16_t *g_pui16Palette; #if SCREEN_BPP == 8 #define NUM_PAL_ENTRIES 256 #else #define NUM_PAL_ENTRIES 16 #endif const uint32_t g_pulSrcPalette[NUM_PAL_ENTRIES] = { ClrBlack, ClrWhite, ClrRed, 0x00FF00, ClrBlue, ClrYellow, ClrMagenta, ClrCyan, ClrOrange, ClrDarkBlue, ClrGold, ClrOrange, ClrCrimson, ClrDarkTurquoise, ClrDarkGray, ClrSilver, }; //***************************************************************************** // // A couple of macros used to extract the dimensions from an image. // //***************************************************************************** #define IMAGE_WIDTH(ptr) ((*(uint16_t *)((uint8_t *)(ptr) + 1))) #define IMAGE_HEIGHT(ptr) ((*(uint16_t *)((uint8_t *)(ptr) + 3))) //***************************************************************************** // // Graphics context used to show text on the QVGA display. // //***************************************************************************** tContext g_sContext; //***************************************************************************** // // Global interrupt status flags. // //***************************************************************************** static volatile uint32_t g_ui32Flags; static volatile uint32_t g_ui32FrameCounter; static volatile uint32_t g_ui32UnderflowCount; //***************************************************************************** // // The image of the TI logo. // //***************************************************************************** const unsigned char g_pucLogo[] = { IMAGE_FMT_4BPP_COMP, 80, 0, 75, 0, 15, 0x00, 0x00, 0x00, 0x02, 0x02, 0x0f, 0x06, 0x05, 0x27, 0x09, 0x07, 0x3b, 0x0c, 0x09, 0x4c, 0x0d, 0x0a, 0x56, 0x10, 0x0c, 0x68, 0x13, 0x0f, 0x7a, 0x15, 0x10, 0x89, 0x17, 0x11, 0x95, 0x19, 0x14, 0xa5, 0x1c, 0x16, 0xb6, 0x1e, 0x18, 0xc7, 0x22, 0x1a, 0xdc, 0x22, 0x1b, 0xe3, 0x24, 0x1c, 0xed, 0xfc, 0x07, 0x07, 0x07, 0x07, 0x07, 0x03, 0x04, 0xfe, 0x13, 0xee, 0xee, 0xee, 0xe9, 0xef, 0xd1, 0x07, 0x07, 0xc2, 0x77, 0x29, 0x04, 0xff, 0xff, 0xff, 0xe9, 0xff, 0x3c, 0xff, 0xd1, 0x07, 0x07, 0x77, 0x29, 0x04, 0xff, 0x23, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x07, 0x07, 0xc2, 0x77, 0x29, 0x04, 0xff, 0xff, 0xff, 0xe9, 0xff, 0x2e, 0xff, 0xd1, 0x05, 0x01, 0x07, 0xbf, 0x32, 0x04, 0x11, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x02, 0x0e, 0x6f, 0xdc, 0xdc, 0xf7, 0x07, 0xbf, 0x32, 0x04, 0x11, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x02, 0x0e, 0xaf, 0xff, 0xff, 0xf5, 0x07, 0xbf, 0x32, 0x04, 0x11, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x02, 0x0e, 0xdf, 0xff, 0xff, 0xf2, 0x07, 0xbf, 0x32, 0x04, 0x11, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x01, 0x73, 0x01, 0xc5, 0x07, 0xa7, 0x00, 0x04, 0x29, 0x11, 0xae, 0x04, 0x03, 0x99, 0xa0, 0x07, 0xbf, 0x72, 0x04, 0xc5, 0x29, 0x11, 0xff, 0xff, 0xd1, 0x01, 0x08, 0x99, 0x76, 0x70, 0x07, 0xbf, 0x72, 0x04, 0x29, 0x11, 0xff, 0x20, 0xff, 0xd1, 0x01, 0x07, 0xcb, 0xbb, 0xbc, 0x40, 0xe1, 0x07, 0xbf, 0x72, 0x04, 0xff, 0xff, 0xff, 0xe9, 0x1e, 0xff, 0xff, 0xd1, 0x07, 0x07, 0x77, 0x29, 0x04, 0x11, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xff, 0xd1, 0x07, 0xe1, 0x07, 0x77, 0x29, 0x04, 0xff, 0xff, 0xff, 0xe9, 0x00, 0xff, 0xff, 0xe6, 0x45, 0x63, 0x00, 0x26, 0x55, 0x2b, 0x55, 0x64, 0xda, 0x55, 0xe9, 0x51, 0x04, 0xd4, 0x03, 0x00, 0x00, 0x04, 0xff, 0xff, 0xff, 0xe9, 0xd2, 0x03, 0xf7, 0x00, 0x6f, 0xff, 0xff, 0xf9, 0xda, 0x62, 0x63, 0xf2, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x54, 0x22, 0x00, 0xf3, 0x00, 0x9f, 0xff, 0xff, 0xf6, 0x00, 0x8f, 0xb1, 0x74, 0xf2, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x54, 0x8e, 0x22, 0xd1, 0x00, 0xcf, 0x0a, 0xd9, 0x62, 0xf2, 0xc6, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x54, 0x22, 0xc0, 0x45, 0x01, 0x01, 0xd1, 0x01, 0xef, 0x74, 0xf2, 0x04, 0x8c, 0xd4, 0x00, 0x00, 0x04, 0x54, 0x22, 0x90, 0x03, 0xb6, 0x01, 0xb0, 0xda, 0x62, 0xf2, 0x04, 0xd4, 0x00, 0x32, 0x00, 0x04, 0x4d, 0x11, 0x60, 0x06, 0x01, 0x90, 0xd8, 0xda, 0x62, 0xf2, 0x04, 0xd4, 0x00, 0x00, 0x04, 0xcb, 0x4d, 0x11, 0x30, 0x09, 0x01, 0x50, 0xda, 0x62, 0x62, 0xf2, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x4d, 0xff, 0x0b, 0xff, 0xfe, 0x10, 0x0c, 0x01, 0x30, 0xda, 0x62, 0x62, 0xf2, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x4d, 0xda, 0x00, 0xaa, 0xb9, 0x00, 0x1e, 0xff, 0xff, 0xfe, 0x10, 0x0b, 0x1a, 0xba, 0xaa, 0xdf, 0x62, 0xf2, 0x04, 0xd4, 0x1a, 0x00, 0x00, 0x04, 0x62, 0x41, 0x80, 0x49, 0x2f, 0x12, 0xff, 0xff, 0xfb, 0x11, 0x01, 0xef, 0x62, 0xf3, 0xc6, 0x04, 0xd4, 0x00, 0x00, 0x04, 0x62, 0x41, 0x60, 0x85, 0x49, 0x6f, 0xff, 0xff, 0xf8, 0x6f, 0xf4, 0x04, 0xc4, 0xd4, 0x5e, 0xff, 0xff, 0x30, 0x49, 0x9f, 0xff, 0x2b, 0xff, 0xf6, 0x11, 0x06, 0x6b, 0xf7, 0x04, 0xd4, 0x11, 0x00, 0x00, 0x04, 0x5b, 0xff, 0xfe, 0x10, 0x49, 0x0a, 0xbf, 0xff, 0xff, 0xf3, 0x11, 0x09, 0x6b, 0xfc, 0x86, 0x02, 0x05, 0x55, 0x55, 0x55, 0xe9, 0xd1, 0x38, 0x90, 0x5b, 0xff, 0xfb, 0x01, 0x01, 0xef, 0xff, 0xff, 0x55, 0xd1, 0x11, 0x0c, 0x6c, 0x40, 0x69, 0x0d, 0x14, 0xd5, 0x7c, 0x4a, 0xf9, 0x01, 0x03, 0x01, 0xb0, 0x19, 0x56, 0x1f, 0x1c, 0xc0, 0x69, 0x09, 0x06, 0xc6, 0xf6, 0xaa, 0x01, 0x06, 0x01, 0x80, 0x19, 0x3f, 0x1c, 0xfa, 0xb0, 0x69, 0x05, 0x06, 0xc6, 0xf4, 0x02, 0x22, 0x00, 0x41, 0x08, 0x01, 0x50, 0x01, 0x22, 0x20, 0x7f, 0x1d, 0x06, 0xb4, 0x00, 0x00, 0x00, 0xcf, 0x05, 0x6d, 0xff, 0x04, 0xfe, 0xff, 0xfe, 0x10, 0x0b, 0x01, 0x20, 0x0c, 0x81, 0x3f, 0xff, 0xf9, 0x00, 0x00, 0x00, 0x5f, 0x8f, 0x80, 0x46, 0xfc, 0x00, 0x1f, 0xff, 0xff, 0xfe, 0x10, 0x40, 0x1e, 0x3f, 0xff, 0xf9, 0x00, 0x00, 0x00, 0x08, 0xc0, 0x8f, 0x46, 0xfa, 0x00, 0x3f, 0xff, 0xff, 0xfb, 0xc0, 0xda, 0x2e, 0xf9, 0x00, 0x00, 0x00, 0x00, 0x9f, 0xc0, 0x87, 0x3d, 0xf6, 0x00, 0x5f, 0xff, 0xff, 0xf8, 0x20, 0x00, 0x6f, 0x47, 0xff, 0xf9, 0x00, 0x00, 0x00, 0x30, 0x00, 0x08, 0x87, 0x3d, 0xf3, 0x00, 0x9f, 0xff, 0x30, 0xff, 0xf6, 0xda, 0x36, 0xf9, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x6f, 0x7f, 0x34, 0xf1, 0x00, 0xcf, 0x18, 0xff, 0xff, 0xf3, 0xda, 0x3e, 0xf9, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x05, 0x7f, 0x34, 0xc0, 0x01, 0x0c, 0xef, 0xff, 0xff, 0xd0, 0xda, 0x3e, 0xf9, 0x00, 0x2c, 0x00, 0x00, 0xe9, 0x6f, 0x77, 0x2b, 0x90, 0x02, 0x90, 0x01, 0xb0, 0x03, 0x5f, 0xff, 0xff, 0xf9, 0x00, 0x2c, 0x00, 0x00, 0xe9, 0x09, 0x6f, 0x23, 0x60, 0x06, 0xb0, 0x01, 0x80, 0xda, 0x46, 0xf9, 0x00, 0x00, 0x00, 0x99, 0xe9, 0x01, 0xdf, 0x67, 0x1a, 0x30, 0x09, 0x01, 0x61, 0x50, 0xda, 0x4e, 0xf9, 0x00, 0x00, 0x00, 0xe9, 0x31, 0x00, 0x7f, 0x67, 0x19, 0xfe, 0x10, 0x0b, 0x01, 0x61, 0x20, 0xda, 0x4e, 0xf9, 0x00, 0x00, 0x00, 0xe9, 0x30, 0x00, 0x2f, 0x67, 0x19, 0xfc, 0x00, 0x1e, 0xff, 0x08, 0xff, 0xfd, 0x10, 0x0c, 0x67, 0xff, 0xff, 0xf9, 0x13, 0x00, 0x00, 0x00, 0xe9, 0x00, 0x0a, 0x67, 0x5b, 0x00, 0x3f, 0xee, 0xee, 0xfb, 0x00, 0x05, 0xee, 0xed, 0x84, 0x6f, 0xf9, 0x00, 0x00, 0x00, 0xe9, 0x00, 0x05, 0xc0, 0x77, 0x29, 0xf6, 0x00, 0x11, 0x11, 0x11, 0x11, 0x08, 0x00, 0x00, 0x01, 0x04, 0x57, 0xf9, 0x00, 0x00, 0x44, 0x00, 0xe9, 0x00, 0x00, 0xcf, 0x6f, 0xff, 0xff, 0x52, 0xf2, 0x5e, 0x06, 0x5e, 0xc8, 0x42, 0x6e, 0x6f, 0x85, 0x6a, 0xfc, 0x42, 0x25, 0xdf, 0x29, 0xe1, 0x5e, 0x42, 0x0a, 0x5a, 0xff, 0xff, 0xfd, 0x72, 0x7e, 0x00, 0x21, 0x00, 0x0c, 0x6a, 0x90, 0x00, 0x00, 0x1c, 0x29, 0x63, 0xc0, 0x5f, 0x5a, 0xff, 0xfc, 0x40, 0x86, 0x41, 0x50, 0x02, 0x01, 0xf8, 0x01, 0x01, 0xef, 0xff, 0xff, 0x51, 0xc0, 0x46, 0x1e, 0x59, 0xff, 0xfb, 0x20, 0x8e, 0x84, 0x4b, 0x3f, 0xff, 0xff, 0x90, 0x02, 0x5f, 0xff, 0x20, 0xff, 0xe1, 0x3e, 0x4f, 0xff, 0xff, 0xff, 0xfd, 0x62, 0x30, 0x96, 0x54, 0x01, 0x6b, 0xb5, 0x0b, 0x0b, 0x10, 0xff, 0xff, 0xf6, 0x36, 0x7f, 0xff, 0xff, 0xff, 0x74, 0x70, 0x9e, 0x5e, 0x1d, 0x03, 0x27, 0x00, 0x00, 0x0e, 0x9f, 0xff, 0xff, 0xd2, 0x07, 0xbf, 0x1d, 0xbf, 0x00, 0xff, 0xff, 0xfd, 0x96, 0x54, 0x33, 0x33, 0x33, 0x03, 0x33, 0x32, 0xcf, 0xff, 0xfc, 0x10, 0x07, 0xbf, 0x86, 0x75, 0x4f, 0xff, 0xff, 0xff, 0xe9, 0xd4, 0xb0, 0xee, 0x07, 0x07, 0x76, 0x0b, 0x02, 0xe2, 0xc1, 0xfc, 0xee, 0x07, 0x07, 0x77, 0x05, 0x01, 0xe9, 0xd3, 0xe1, 0xe0, 0x07, 0x07, 0x77, 0x00, 0xcf, 0xff, 0xff, 0xff, 0xdc, 0xe9, 0xd2, 0x40, 0x07, 0x07, 0x77, 0x00, 0x6f, 0x1b, 0xff, 0xff, 0xff, 0xe9, 0xd1, 0xf9, 0x07, 0x07, 0x81, 0x77, 0x00, 0x00, 0x1d, 0xff, 0xff, 0xff, 0xe9, 0xb8, 0xd1, 0xf2, 0x07, 0x07, 0x77, 0x00, 0x00, 0x06, 0x1b, 0xff, 0xff, 0xff, 0xe9, 0xd1, 0x90, 0x07, 0x07, 0x80, 0x77, 0x00, 0x00, 0x01, 0xdf, 0xff, 0xff, 0xff, 0x8f, 0xe9, 0xff, 0xff, 0x40, 0x07, 0x07, 0x77, 0x29, 0x08, 0x6f, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xfe, 0x10, 0xf0, 0x07, 0x07, 0x77, 0x29, 0x0c, 0xff, 0xff, 0xff, 0x9e, 0xe9, 0xff, 0xfb, 0x07, 0x07, 0x77, 0x2a, 0x03, 0x13, 0xff, 0xff, 0xff, 0xe9, 0xff, 0xfb, 0x07, 0x07, 0xc2, 0x77, 0x2b, 0x8f, 0xff, 0xff, 0xff, 0xe9, 0xfb, 0xf0, 0x07, 0x07, 0x77, 0x2b, 0x0a, 0xff, 0xff, 0xff, 0xbc, 0xe9, 0xfc, 0x07, 0x07, 0x77, 0x2c, 0xcf, 0xff, 0x03, 0xff, 0xff, 0xff, 0xff, 0xfd, 0x10, 0x07, 0x07, 0xc2, 0x77, 0x2b, 0x0c, 0xff, 0xff, 0xff, 0xe9, 0x30, 0xf0, 0x07, 0x07, 0x77, 0x2c, 0xaf, 0xff, 0xff, 0xff, 0x1e, 0xff, 0xff, 0x60, 0x07, 0x07, 0x77, 0x2c, 0x05, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0x07, 0xc0, 0x77, 0x2d, 0x18, 0xff, 0xff, 0xff, 0xff, 0xf2, 0xf0, 0x07, 0x07, 0x77, 0x2e, 0x14, 0x79, 0xa9, 0x86, 0x7f, 0x20, 0x07, 0x07, 0x77, 0x2f, 0x07, 0x07, 0x07, 0xf0, 0x07, 0x07, 0x07, 0x07, }; //***************************************************************************** // // The error routine that is called if the driver library encounters an error. // //***************************************************************************** void __error__(char *pcFilename, unsigned long ulLine) { // // A runtime error was detected so stop here to allow debug. // while(1) { // // Hang. // } } //***************************************************************************** // // The interrupt handler for the LCD controller. This function merely // flags error or status interrupts as they are received. // //***************************************************************************** void LCDIntHandler(void) { uint32_t ui32Status; // // Get the current interrupt status and clear any active interrupts. // ui32Status = LCDIntStatus(LCD0_BASE, true); LCDIntClear(LCD0_BASE, ui32Status); // // Increment the frame counter if necessary. // if(ui32Status & LCD_INT_EOF0) { g_ui32FrameCounter++; } // // If we saw an underflow interrupt, restart the raster. // if(ui32Status & LCD_INT_UNDERFLOW) { g_ui32UnderflowCount++; LCDRasterEnable(LCD0_BASE); } // // Update our global flags with the new interrupt status. // g_ui32Flags |= ui32Status; } //***************************************************************************** // // Initialize the LCD controller to drive the raster display. // //***************************************************************************** static void DisplayInit(uint32_t ui32SysClkHz) { // // Enable the GPIO peripherals used to interface to the LCD panel. // MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_LCD0); MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ); //MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION); MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOR); MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOS); //MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOT); // // Configure all the LCD controller pins for hardware control. // GPIOPinTypeLCD(GPIO_PORTF_BASE, 0x80); //ok se�al LCDDATA2 //GPIOPinTypeLCD(GPIO_PORTJ_BASE, 0x7C); //ok, se�al LCDDATA14, LCDDATA15, LCDDATA16, LCDDATA17, LCDAC GPIOPinTypeLCD(GPIO_PORTJ_BASE, 0x7C); //ok, se�al LCDAC //GPIOPinTypeLCD(GPIO_PORTN_BASE, 0xC0); //ok, LCDDATA12 y LCDDATA13 #ifdef INNOLUX_DISPLAY GPIOPinTypeLCD(GPIO_PORTR_BASE, 0xF9); // #else GPIOPinTypeLCD(GPIO_PORTR_BASE, 0xFF); //ok, CK, , VSYNC, HSYNC, LCDDATA3, LCDDATA0, LCDDATA1, LCDDATA4, LCDDATA5 #endif //GPIOPinTypeLCD(GPIO_PORTS_BASE, 0xF9); // GPIOPinTypeLCD(GPIO_PORTS_BASE, 0x30); //ok, LCDDATA6, LCDDATA7 //GPIOPinTypeLCD(GPIO_PORTT_BASE, 0x0F); // // // Set the pin muxing to ensure that LCD signals appear on the required // pins. Note that we take advantage of the fact that we know the mux // selector is F here to allow us to OR the value without first masking // off anything that may have been there before. // // //Activar al multiplexor de pines para activar las se�ales de control como sean requeridas HWREG(GPIO_PORTF_BASE + GPIO_O_PCTL) |= 0xF0000000; //HWREG(GPIO_PORTJ_BASE + GPIO_O_PCTL) |= 0x0FFFFF00; //comentado para pruebas HWREG(GPIO_PORTJ_BASE + GPIO_O_PCTL) |= 0x0F000000; //HWREG(GPIO_PORTN_BASE + GPIO_O_PCTL) |= 0xFF000000; //comentado para pruebas #ifdef INNOLUX_DISPLAY HWREG(GPIO_PORTR_BASE + GPIO_O_PCTL) |= 0xFFFFF00F; #else HWREG(GPIO_PORTR_BASE + GPIO_O_PCTL) |= 0xFFFFFFFF; #endif //HWREG(GPIO_PORTS_BASE + GPIO_O_PCTL) |= 0xFFFFF00F; //comentado para pruebas HWREG(GPIO_PORTS_BASE + GPIO_O_PCTL) |= 0x00FF0000; //HWREG(GPIO_PORTT_BASE + GPIO_O_PCTL) |= 0x0000FFFF; //comentado para pruebas // // Configure the LCD controller for raster operation with a pixel clock // as close to the requested pixel clock as possible. // MAP_LCDModeSet(LCD0_BASE, (LCD_MODE_RASTER | LCD_MODE_AUTO_UFLOW_RESTART), g_psDisplayMode->ui32PixClock, ui32SysClkHz); // // Set the output format for the raster interface. // /* MAP_LCDRasterConfigSet(LCD0_BASE, (RASTER_FMT_ACTIVE_PALETTIZED_16BIT | RASTER_NIBBLE_MODE_ENABLED | RASTER_READ_ORDER_REVERSED), 0);*/ MAP_LCDRasterConfigSet(LCD0_BASE, (RASTER_FMT_ACTIVE_PALETTIZED_16BIT | RASTER_LOAD_DATA_ONLY /*RASTER_NIBBLE_MODE_ENABLED | RASTER_READ_ORDER_REVERSED*/ ), 0); MAP_LCDRasterTimingSet(LCD0_BASE, &(g_psDisplayMode->sTiming)); // // Configure DMA-related parameters. // MAP_LCDDMAConfigSet(LCD0_BASE, LCD_DMA_BURST_16 | LCD_DMA_FIFORDY_64_WORDS); // // If the chosen display has an initialization function, call it now. // /* if(g_psDisplayMode->pfnInitDisplay) { g_psDisplayMode->pfnInitDisplay(ui32SysClkHz); }*/ // // Set up the frame buffer. Note that we allow this buffer to extend // outside the available SRAM. This allows us to easily test modes where // we can't fit the whole frame in memory, realizing, of course, that // part of the display will contain crud. // MAP_LCDRasterFrameBufferSet(LCD0_BASE, 0, g_pui32DisplayBuffer, SIZE_PALETTE + SIZE_BUFFER); // // Write the palette to the frame buffer. // MAP_LCDRasterPaletteSet(LCD0_BASE, #if SCREEN_BPP == 1 LCD_PALETTE_SRC_24BIT |LCD_PALETTE_TYPE_1BPP, #else #if SCREEN_BPP == 4 LCD_PALETTE_SRC_24BIT | LCD_PALETTE_TYPE_4BPP, #else #if SCREEN_BPP == 8 LCD_PALETTE_SRC_24BIT | LCD_PALETTE_TYPE_8BPP, #else #if SCREEN_BPP == 16 LCD_PALETTE_SRC_24BIT| LCD_PALETTE_TYPE_DIRECT, #endif #endif #endif #endif (uint32_t *)g_pui16Palette, g_pulSrcPalette, 0, (SIZE_PALETTE / 2)); // // Enable the LCD interrupts. // MAP_LCDIntEnable(LCD0_BASE, (LCD_INT_DMA_DONE | LCD_INT_SYNC_LOST | LCD_INT_UNDERFLOW | LCD_INT_EOF0)); MAP_IntEnable(INT_LCD0); // // Enable the raster output. // MAP_LCDRasterEnable(LCD0_BASE); } //***************************************************************************** // // This function fills the whole display with a given color. // //***************************************************************************** void FillScreen(uint32_t ui32Color) { tRectangle sRect; // // Fill the frame buffer with the desired color. // sRect.i16XMin = 0; sRect.i16XMax = GrContextDpyWidthGet(&g_sContext) - 1; sRect.i16YMin = 0; sRect.i16YMax = GrContextDpyHeightGet(&g_sContext) - 1; GrContextForegroundSet(&g_sContext, ui32Color); GrRectFill(&g_sContext, &sRect); } //***************************************************************************** // // This function draws a pattern of diagonal lines on the display. // //***************************************************************************** void DrawLinePattern(uint32_t ui32Color) { int32_t i32Loop, i32XInc, i32YInc; tRectangle sRect; // // Set the foreground color. // GrContextForegroundSet(&g_sContext, ui32Color); // // Draw a rectangle around the whole display. // sRect.i16XMin = 0; sRect.i16YMin = 0; sRect.i16XMax = GrContextDpyWidthGet(&g_sContext) - 1; sRect.i16YMax = GrContextDpyHeightGet(&g_sContext) - 1; GrRectDraw(&g_sContext, &sRect); // // Determine the spacing of the diagonal lines. // i32XInc = GrContextDpyWidthGet(&g_sContext) / 20; i32YInc = GrContextDpyHeightGet(&g_sContext) / 20; // // Draw a pattern of lines. // for(i32Loop = 0; i32Loop < 20; i32Loop++) { GrLineDraw(&g_sContext, 0, i32YInc * i32Loop, i32XInc * i32Loop, (GrContextDpyHeightGet(&g_sContext) - 1)); GrLineDraw(&g_sContext, (GrContextDpyWidthGet(&g_sContext) - 1), (GrContextDpyHeightGet(&g_sContext) - (i32YInc * i32Loop + 1)), (GrContextDpyWidthGet(&g_sContext) - (i32XInc * i32Loop + 1)), 0); } } //***************************************************************************** // // A simple example using a raster-mode LCD panel to display graphics. // //***************************************************************************** int main(void) { uint32_t ui32Val; uint32_t ui32SysClk; uint32_t ui32X, ui32Y; // // Set the PLL and system clock to the frequencies needed to allow // generation of the required pixel clock. // ui32SysClk = SysCtlClockFreqSet((SYSCTL_OSC_INT | SYSCTL_USE_PLL | g_psDisplayMode->ui32VCOFrequency), g_psDisplayMode->ui32SysClockFrequency); // // Enable GPIOA for the UART. // MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // // Set GPIO A0 and A1 as UART pins. // ui32Val = HWREG(GPIO_PORTA_BASE + GPIO_O_PCTL); ui32Val &= 0xFFFFFF00; ui32Val |= 0x00000011; HWREG(GPIO_PORTA_BASE + GPIO_O_PCTL) = ui32Val; // // Set GPIO A0 and A1 as UART. // MAP_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // // Initialize the UART as a console for text I/O. // UARTStdioConfig(0, 115200, ui32SysClk); // // Enable interrupts. // MAP_IntMasterEnable(); // // Print hello message to user. // UARTprintf("\n\nLCD Raster Mode Example\n\n"); UARTprintf("Display configured for %dx%d at %dbpp.\n", RASTER_WIDTH, RASTER_HEIGHT, SCREEN_BPP); UARTprintf("System clock is %dMHz\n", ui32SysClk / 1000000); // // Initialize the SDRAM. // g_pui16SDRAM = SDRAMInit(ui32SysClk); // // Was the SDRAM found? // if(!g_pui16SDRAM) { UARTprintf("Application requires SDRAM but this is not present!\n"); while(1); } // // Set the frame buffer pointers as required. // g_pui32DisplayBuffer = (uint32_t *)g_pui16SDRAM; g_pui16Palette = (uint16_t *)g_pui16SDRAM; // // Initialize the display. // DisplayInit(ui32SysClk); // // Initialize the display driver and graphics context. // #if SCREEN_BPP == 1 GrRaster1BppDriverInit(g_pui32DisplayBuffer); GrContextInit(&g_sContext, &g_sGrRaster1BppDriver); #endif #if SCREEN_BPP == 4 GrRaster4BppDriverInit(g_pui32DisplayBuffer); GrContextInit(&g_sContext, &g_sGrRaster4BppDriver); #endif #if SCREEN_BPP == 8 GrRaster8BppDriverInit(g_pui32DisplayBuffer); GrContextInit(&g_sContext, &g_sGrRaster8BppDriver); #endif #if SCREEN_BPP == 16 GrRaster16BppDriverInit(g_pui32DisplayBuffer); GrContextInit(&g_sContext, &g_sGrRaster16BppDriver); #endif //-------------------------------------------------------------------------- //Fill the frame buffer with black. FillScreen(ClrBlack); // //Draw a pattern of red lines on the display. //DrawLinePattern(ClrRed); //comentado s�lo para pruebas // //Draw a yellow circle GrContextForegroundSet(&g_sContext, ClrYellow); //GrContextForegroundSet(&g_sContext, ClrChocolate); /*GrCircleDraw(&g_sContext, GrContextDpyWidthGet(&g_sContext) / 2, GrContextDpyHeightGet(&g_sContext) / 2, GrContextDpyWidthGet(&g_sContext) / 5);*/ GrCircleDraw(&g_sContext, 20, 21, 20); // //Determina donde se colocar� la im�gen del logo ui32X = (GrContextDpyWidthGet(&g_sContext) - IMAGE_WIDTH(g_pucLogo)) / 2; ui32Y = (GrContextDpyHeightGet(&g_sContext) - IMAGE_HEIGHT(g_pucLogo)) / 2; //ui32X = (GrContextDpyWidthGet(&g_sContext)); //ui32Y = (GrContextDpyHeightGet(&g_sContext)); ui32Y+= 40; // //Preparar la superficie en la que se colocar� el logo GrContextForegroundSet(&g_sContext, ClrRed); GrContextBackgroundSet(&g_sContext, ClrBlack); // //Draw the TI logo GrImageDraw(&g_sContext, g_pucLogo, ui32X, ui32Y); //Display some text. GrContextFontSet(&g_sContext, g_psFontCmss22); GrContextForegroundSet(&g_sContext, ClrBlue); GrStringDrawCentered(&g_sContext, "MCU & DSP", -1, 60, 200, false); GrLineDrawH(&g_sContext, 1, 3, 1); GrLineDrawH(&g_sContext, 1, 3, 50); GrLineDrawH(&g_sContext, 1, 3, 479); GrContextForegroundSet(&g_sContext, ClrGold); GrLineDrawH(&g_sContext, 637, 639, 1); // //Esta funci�n hace m�s portable en caso de reemplazar al manejador de gr�ficos GrFlush(&g_sContext); // //Lazo infinito while(1) { // //entra al modo de bajo consumo SysCtlSleep(); } //-------------------------------------------------------------------------- }
