I need to connect External Ethernet Phy to the TM4C129NCPDT Microcontroller. I cant find MDIO and MDC pins in the PIN diagram given in the Datasheet (www.ti.com/.../tm4c1294ncpdt.pdf)
The option to connect the External Ethernet Phy is given in the Development board Schematic (http://www.ti.com/lit/ug/spmu360a/spmu360a.pdf )(Snapshot attached) . But cant find the same pins in my Part.
Suggest a solution for the same. The requirement is that using the same pins I need to program and configure the Ethernet phy.
