Hi
I am trying to configure UART6 p on Launchpad kit (pins 118 an 119 as U6 Rx and Tx). But the program crashes on trying to set baud rate. On commenting out, no data is seen on the pins 119 and 118.
I am attaching the program
The define switch #deifine UART6_LAUNCHPAD chooses U6
if this is commented out, the original UART0 operates in console mode with serial port.
Pavitra
//***************************************************************************** // // uart_echo.c - Example for reading data from and writing data to the UART in // an interrupt driven fashion. // // Copyright (c) 2013-2016 Texas Instruments Incorporated. All rights reserved. // Software License Agreement // // Texas Instruments (TI) is supplying this software for use solely and // exclusively on TI's microcontroller products. The software is owned by // TI and/or its suppliers, and is protected under applicable copyright // laws. You may not combine this software with "viral" open-source // software in order to form a larger program. // // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS. // NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT // NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY // CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL // DAMAGES, FOR ANY REASON WHATSOEVER. // // This is part of revision 2.1.3.156 of the EK-TM4C1294XL Firmware Package. // //***************************************************************************** #include <stdint.h> #include <stdbool.h> #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "driverlib/debug.h" #include "driverlib/gpio.h" #include "driverlib/interrupt.h" #include "driverlib/pin_map.h" #include "driverlib/rom.h" #include "driverlib/rom_map.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "inc/hw_types.h" //***************************************************************************** // //! \addtogroup example_list //! <h1>UART Echo (uart_echo)</h1> //! //! This example application utilizes the UART to echo text. The first UART //! (connected to the USB debug virtual serial port on the evaluation board) //! will be configured in 115,200 baud, 8-n-1 mode. All characters received on //! the UART are transmitted back to the UART. // //***************************************************************************** #define UART6_LAUNCHPAD //**************************************************************************** // // System clock rate in Hz. // //**************************************************************************** uint32_t g_ui32SysClock; //***************************************************************************** // // The error routine that is called if the driver library encounters an error. // //***************************************************************************** #ifdef DEBUG void __error__(char *pcFilename, uint32_t ui32Line) { } #endif //***************************************************************************** // // The UART interrupt handler. // //***************************************************************************** void UARTIntHandler(void) { uint32_t ui32Status; // // Get the interrrupt status. // ui32Status = ROM_UARTIntStatus(UART0_BASE, true); // // Clear the asserted interrupts. // ROM_UARTIntClear(UART0_BASE, ui32Status); // // Loop while there are characters in the receive FIFO. // while(ROM_UARTCharsAvail(UART0_BASE)) { // // Read the next character from the UART and write it back to the UART. // ROM_UARTCharPutNonBlocking(UART0_BASE, ROM_UARTCharGetNonBlocking(UART0_BASE)); // // Blink the LED to show a character transfer is occuring. // GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_0, GPIO_PIN_0); // // Delay for 1 millisecond. Each SysCtlDelay is about 3 clocks. // SysCtlDelay(g_ui32SysClock / (1000 * 3)); // // Turn off the LED // GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_0, 0); } } //***************************************************************************** // // Send a string to the UART. // //***************************************************************************** void UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count) { // // Loop while there are more characters to send. // while(ui32Count--) { // // Write the next character to the UART. // ROM_UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++); } } //***************************************************************************** // // This example demonstrates how to send a string of data to the UART. // //***************************************************************************** int main(void) { // // Set the clocking to run directly from the crystal at 120MHz. // g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000); // // Enable the GPIO port that is used for the on-board LED. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION); // // Enable the GPIO pins for the LED (PN0). // ROM_GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_0); #ifndef UART6_LAUNCHPAD // Enable the peripherals used by this example. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // Enable processor interrupts. // ROM_IntMasterEnable(); // // Set GPIO A0 and A1 as UART0 pins. // GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // Configure the UART for 115,200, 8-N-1 operation. // ROM_UARTConfigSetExpClk(UART0_BASE, g_ui32SysClock, 115200, (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE)); // Enable the UART interrupt. ROM_IntEnable(INT_UART0); ROM_UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT); #endif #ifdef UART6_LAUNCHPAD ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART6); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP); // Enable processor interrupts. // ROM_IntMasterEnable(); // set up PP0 and PP1 as UART6 pins GPIOPinConfigure(GPIO_PP0_U6RX); GPIOPinConfigure(GPIO_PP1_U6TX); ROM_GPIOPinTypeUART(GPIO_PORTP_BASE, GPIO_PIN_0 | GPIO_PIN_1); // Configure the UART for 115,200, 8-N-1 operation. ROM_UARTConfigSetExpClk(UART6_BASE, g_ui32SysClock, 115200,0); // (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | // UART_CONFIG_PAR_NONE)); // Enable the UART interrupt. ROM_IntEnable(INT_UART6); ROM_UARTIntEnable(UART6_BASE, UART_INT_RX | UART_INT_RT); #endif // Prompt for text to be entered. // #ifndef UART6_LAUNCHPAD UARTSend((uint8_t *)"\033[2JEnter text: ", 16); #endif // // Loop forever echoing data through the UART. // while(1) { #ifdef UART6_LAUNCHPAD HWREG(UART6_BASE + 0) = '|'; #endif #ifndef UART6_LAUNCHPAD HWREG(UART0_BASE + 0) = '|'; #endif SysCtlDelay(1000000); } }
