Hello everyone,
I have a bit general question before I start to modify my code with this new method for PWM signal generation. I have on two pins requirement for PWM signal which should be modifiable by frequency and duty cycle with frequency in the range of 1-200 Hz. Since I have problems with generating that signal with wide timer, and do not have PWM module on connected pins I plan to generate PWM signal using pin as GPIO and some timers for counting when the GPIO should be on and off. Can it be achieved that way?
Thank you!
