Compiler/TIDM-TM4C129XNFC: TI-RTOS 2.16 Project Upgrade Procedure
Part Number: TIDM-TM4C129XNFC
I'm trying to get the http://www.ti.com/tool/TIDM-TM4C129XNFC
Once I switch from TI-RTOS 2.14 to 2.16, I get the following errors. I guessed some functionality has moved into the framework, so I tried removing the CC3100 board code (however this didn't help).
Any ideas on a way forward?
Thanks in advance,
Tim
Errors were:
error #10056: symbol "registerInterruptHandler" redefined: first defined in "./CC3100_board.obj"; redefined in "C:/ti/tirtos_tivac_2_16_01_14/products/tidrivers_tivac_2_16_01_13/packages/ti/drivers/lib/drivers_wifi_tivaware.aem4f<WiFiCC3100.oem4f>"
error #10056: symbol "spi_Read" redefined: first defined in "./CC3100_spi.obj"; redefined in "C:/ti/tirtos_tivac_2_16_01_14/products/tidrivers_tivac_2_16_01_13/packages/ti/drivers/lib/drivers_wifi_tivaware.aem4f<WiFiCC3100.oem4f>"
error #10056: symbol "spi_Close" redefined: first defined in "./CC3100_spi.obj"; redefined in "C:/ti/tirtos_tivac_2_16_01_14/products/tidrivers_tivac_2_16_01_13/packages/ti/drivers/lib/drivers_wifi_tivaware.aem4f<WiFiCC3100.oem4f>"
error #10056: symbol "spi_Write" redefined: first defined in "./CC3100_spi.obj"; redefined in "C:/ti/tirtos_tivac_2_16_01_14/products/tidrivers_tivac_2_16_01_13/packages/ti/drivers/lib/drivers_wifi_tivaware.aem4f<WiFiCC3100.oem4f>"
error #10056: symbol "spi_Open" redefined: first defined in "./CC3100_spi.obj"; redefined in "C:/ti/tirtos_tivac_2_16_01_14/products/tidrivers_tivac_2_16_01_13/packages/ti/drivers/lib/drivers_wifi_tivaware.aem4f<WiFiCC3100.oem4f>"
error #10010: errors encountered during linking;
>> Compilation failure
**** Build Finished ****
