Other Parts Discussed in Thread: MOTORWARE, C2000WARE, DRV8353
In the DRV 8353 RH - EVM quick start method, it is only an error.
Could you give me an error-free project folder?
Hi Hayaoki,
I ran through the guide and noticed numerous changes were required. I followed the new steps and correctly built the code. Please, can you restart your process and run the steps outlined in the attached PDF? Thank you.
It does not improve by PDF procedure.
By the way, motorwear has to put similar files here and there
It is very troublesome to think that it can not be used.
Would you please provide samples on a c2000wear basis?
Thank you
In the procedure of STEP the installation directory of motorwear
There are several.
I want you to see whether there is a red part.
1. Copy folder drv8353 from
"InstallDirectory":¥ti¥DRV8353Rx1.0.0¥DRV8353Rx_InstaspinFOC_FW¥drv8353Rx_instaspinFOC_FW¥drv83xx_foc¥drvic¥ to "InstallDirectory":¥ti¥motorware¥motorware_1_01_00_18¥sw¥drivers¥drvic¥
2. Copy folder drv8353 from
"InstallDirectory":¥ti¥DRV8353Rx1.0.0¥DRV8353Rx_InstaspinFOC_FW¥drv8353Rx_instaspinFOC_FW¥drv83xx_foc¥hal¥boards to "Install Directory":¥ti¥motorware¥motorware_1_01_00_18¥sw¥modules¥hal¥boards
3. Copy folder src from
"InstallDirectory":¥ti¥DRV8353Rx1.0.0¥DRV8353Rx_InstaspinFOC_FW¥drv8353Rx_instaspinFOC_FW¥drv83xx_foc¥instaspin_foc¥ to "InstallDirectory":¥ti¥motorware_drv8353¥motorware_1_01_00_18¥sw¥modules¥hal
4. Copy folder drv8353 from
"InstallDirectory':¥ti¥DRV8353Rx1.0.0¥DRV8353Rx_InstaspinFOC_FW¥drv8353Rx_instaspinFOC_FW¥drv83xx_foc¥instaspin_foc¥boards¥ to"InstallDirectory":¥ti¥motorware_drv8353¥motorware_1_01_00_18¥sw¥solutions¥instaspin_foc¥boards
5. Copy contents of folder src at
"InstallDirectory:¥ti¥motorware_drv8353¥motorware_1_01_00_18¥sw¥solutions¥instaspin_foc¥s
rc
Thank you
Hi Hayaoki,
Thank you. Currently, we successfully ran a newly modified import procedure but we are sorting through technicalities. I will keep you informed on any updates available to be shared with you.
