For a customer of mine I received this question:
Could you tell me whether there is a minimum fall/rise time on the SCL/SDA line?
They are facing some I2C issues between FPGA used as master and the driver.
When decreasing the current strength of the FPGA outputs on the SCL/SDA lines the problem seems to be fixed.
By doing this the fall time is going from 1.62ns to 7.5ns
Thanks in advance for you help
