  • TI Thinks Resolved
Low side driver with 2A inductive load
Prodigy 50 points
I am looking for low side driver to drive 2A inductive load, with short circuit protection and diagnostics.
  • Hi KDN Vihang,
    Thanks for reaching out to the High Power Driver's group, my name is Mamadou, I will you find a driver.
    Can you tell me a little bit more about your requirement or possibly share a block diagram? Applications, Supply range, etc?
    Our low side drivers' portfolio does not currently have a driver with a short-circuit protection feature.
    Have you considered our isolated drivers like ISO5852S and ISO5452? Both found on ti.com/gatedrivers.
    Thanks.
    Mamadou
    I would like to get a little more information.
    What is the input voltage and range?
    What is the output voltage if there is one or is this just driving an inductor? What is the inductive load?
    What diagnostics are you interested in?
    By low side drive are you looking for a low side referenced MOSFET or are you looking to connect the inductor to the low side?
  • In reply to Irwin Nederbragt:
    I haven’t heard back from you, I’m assuming you were able to resolve your issue.
    If not, just post a reply below (or create a new thread if the thread has locked due to time-out)
