Hi all
Would you mind if we ask DRV8306?
Please refer to the attachment file.
20190219_DRV8306.pdf
Could you give us advice?
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Adam Sidelsky san
Thank you for your support alwasy!
The customer doesn't have a differential probe.
So, they caluculate it with oscilloscope's MATH function.
20190220_DRV8306.pdf
As our assumption, VM is more than ABS maximum ratings.
So, we assume that it is difficult to decide whether this wave form is normal operation or abnormal operation.
Kind regards,
Hirotaka Matsumoto
Adam san
Thank you so much for your cooperation always!
Are you using the braking feature? Have you tried slowing down the rate at which the speeed is reduced?
->The customer will try it. We informed the customer to use brake function.
Just in case, we would like to know nBRAKE=high. In this case(nBRAKE=high), will the device be Fast Decay mode(all FET's(high side and low side) turns off)?
Kind regards,
Hirotaka Matsumoto
