  • Resolved
DRV8830: Inquiry of RDSON and duty control
Intellectual 2175 points
Part Number: DRV8830
Hi Team,
Would you support my customer's inquiry below because
there was no description on the data sheet.
■ DRV8830
・ Iout vs MDOUT1 / MDOUT2
      * I want to know how much the drop by Rds changes.
      * I want to know the behavior of Vcc = 3.5v / 4.0v / 4.5v (because Rds changes with Vcc)
・ When Vout is set to 5V, What is the behavior when Vcc is changed to lower than 5V?
      * I want to check the behavior when Vcc < set voltage
     * Does it Keep 100% duty for example?
Shidara
  • Hi Shidara-san,
    Can you clarify the following questions?
    HH -> Can you confirm if you are asking how much Rds drops as what parameter(s) changes?
    HH -> The behavior of Rds as Vcc is set to those three values?
    HH -> To what minimum Vcc value do you want confirmation?
    Hector Hernandez
    Motor Applications Team
  • In reply to Hector Hernandez Luque:
    Hi Shidara-san,
    Do you have an update here? Thank you.
    Hector Hernandez
    Hi Shidara-san,
    I will close this e2e for now. Please, reply to this thread or open a new one with your inputs. Thank you.
    Hector Hernandez
    Hi Hector-san
    I'm sorry to reply late.
    Would you refer the answer below?
      → Change parameter is Iout(0A to 1A)when Vcc=3.5V, 4.0V, 4.5V
    >(because Rds changes with Vcc) HH -> The behavior of Rds as Vcc is set to those three values?
      → yes
    >     * I want to check the behavior when Vcc < set voltage HH -> To
      → when Vcc=4.0V and 4.5V
    Shidara
  • In reply to K.Shidara:
    Hi Shidara-san,
    We are on holidays until next Monday. Please, expect a response early next week.
    Hector Hernandez
    Hi Shidara-san,
    It will require more time to provide these answers. I expect to have a response for you by end of this week.
    Hector Hernandez
    Hi Shidara-san,
    We do not have Rds(on) data across current range you have indicated. We have data on datasheet, which is Rds(on) changes across Vcc and three temperature points. Please, see the graph below:
    Hector Hernandez
    Hi Hector-san
    Thank you very much for your answer.
    I understood.
    Shidara
