Other Parts Discussed in Thread: DRV8305,
I use the TI BoostXL DRV8305EVM to control a DC motor. Can you tell me why the motor driver only works under load? If I measure the output voltage, I have to use a load resistor in parallel to get the correct output signal (its not just a pull down resistor with 10KOhm, it has to be an (small) performance-resistant.
Can you tell me the reason and a possibility to solve the problem?
Thank you very much
Best regards
Tobi
