  • Resolved
How start Android Gingerbread on TI OMAP4 (4430)
I followed : http://www.omappedia.org/wiki/L27.G.2_OMAP4_GingerBread_Release_Notes and when I save bootargs in minicom, it print out :Type 'y' or 'Y' to Save Environment to NOWHERE.. .
why?
If I ignore this and run bootcmd :
OMAP44XX SDP # run bootcmd
The message below will print out:
mmc read: Invalid size
3371148 bytes read
## Booting image at 80000000 ...
   Image Name:   Linux-2.6.35.7-00367-g5db5e8f
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3371084 Bytes =  3.2 MB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
OK
I2C read: I/O error
Blaze/SDP Board.
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 2.6.35.7-00367-g5db5e8f (eoollo@eoollo-HP-ProBook-4520s) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Mon Jul 25 12:51:12 CST 2011
CPU: ARMv7 Processor [411fc092] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP4430
Memory policy: ECC disabled, Data cache writealloc
OMAP4430 ES2.0 type(GP)
id-code  (1b85202f)
Die-id   (21980001-00000000-0A6CAD10-1301800A)
Prod-id  (0001B852-000100F0)
SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0x100000
FIXME: omap44xx_sram_init not implemented
Reserving 10485760 bytes SDRAM for VRAM
SMC: Running on a GP device, SMC disabled
PERCPU: Embedded 7 pages/cpu @c19af000 s5696 r8192 d14784 u65536
pcpu-alloc: s5696 r8192 d14784 u65536 alloc=16*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 245760
Kernel command line: androidboot.console=ttyO2 console=ttyO2,115200n8 mem=456M@0x80000000 mem=512M@0xA0000000 root=/dev/mmcblk1p2 rw rootdelay=2 init=/init vram="10M" omapfb.vram="0:4M"
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 456MB 256MB 256MB = 968MB total
Memory: 964576k/964576k available, 26656k reserved, 262144K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xf0800000 - 0xf8000000   ( 120 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0045000   ( 244 kB)
      .text : 0xc0045000 - 0xc0693000   (6456 kB)
      .data : 0xc0694000 - 0xc06f5f40   ( 392 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:394
omap_hwmod: sys_32k_ck: missing clockdomain for sys_32k_ck.
omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
omap_hwmod: dmic: resetting
omap_hwmod: dss_dsi1: cannot be enabled (3)
omap_hwmod: dss_dsi2: cannot be enabled (3)
omap_hwmod: dss_hdmi: cannot be enabled (3)
omap_hwmod: dss_rfbi: cannot be enabled (3)
omap_hwmod: dss_venc: cannot be enabled (3)
omap_hwmod: mailbox: resetting
omap_hwmod: omap-mcpdm-dai: cannot be enabled (3)
omap_hwmod: mcspi1: resetting
omap_hwmod: mcspi2: resetting
omap_hwmod: mcspi3: resetting
omap_hwmod: mcspi4: resetting
omap_hwmod: mmc1: resetting
omap_hwmod: mmc2: resetting
omap_hwmod: mmc3: resetting
omap_hwmod: mmc4: resetting
omap_hwmod: mmc5: resetting
omap_hwmod: timer3: resetting
omap_hwmod: timer4: resetting
omap_hwmod: timer5: resetting
omap_hwmod: timer6: resetting
omap_hwmod: timer7: resetting
omap_hwmod: timer8: resetting
omap_hwmod: timer9: resetting
omap_hwmod: timer11: resetting
GPMC revision 6.0
SmartReflex CLASS3 initialized
OMAP clockevent source: GPTIMER1 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 2013.49 BogoMIPS (lpj=7864320)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
Calibrating local timer...
50.00MHz.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x1e470000
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (4010.18 BogoMIPS).
devtmpfs: initialized
regulator: core version 0.5
NET: Registered protocol family 16
EMIF0 is enabled with IRQ142
EMIF1 is enabled with IRQ143
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 2
omap_mux_init: Add partition: #2: wkup, flags: 2
Reprogramming LPDDR2 timingsto 200000000 Hz
_omap_mux_init_signal: Could not set signal fref_clk0_out.gpio_wk6
omap_disp_led_init: Configuring as one display LED
Configured modem_ipc: n/a
Modem HSI not detected
res->start = 49022000
res->start = 49024000
res->start = 49026000
res->start = 48096000
OMAP DMA hardware revision 0.0
dma dma.0: System DMA registered
HSI: device registered as omap_hwmod: hsi
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev4.0 at 400 kHz
Skipping twl internal clock init and using bootloader value (unknown osc rate)
twl6030: PIH (irq 39) chaining IRQs 368..387
regulator: VUSB: 3300 mV normal standby
twl6030_usb twl6030_usb: Initialized TWL6030 USB module
regulator: VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
regulator: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
regulator: VUSIM: 1200 <--> 2900 mV at 1800 mV normal standby
regulator: VANA: 2100 mV normal standby
regulator: VCXIO: 1800 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normal standby
regulator: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
regulator: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
regulator: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
tps6130x 1-0033: Revision 5
i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
i2c_omap i2c_omap.3: bus 3 rev4.0 at 400 kHz
i2c_omap i2c_omap.4: bus 4 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Sangoma WANPIPE Router v1.1 (c) 1995-2000 Sangoma Technologies Inc.
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Switching to clocksource timer-32k
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc musb_hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
omap_voltage_get_voltdata: Unable to match the current voltage 1350000 with the voltagetable for vdd_mpu
omap4_vdd_data_configure: Unable to get volt table for vdd_mpu at init
vp_latch_vsel: unable to find current voltage for vdd_mpu
omap_voltage_get_voltdata: Unable to match the current voltage 1100000 with the voltagetable for vdd_iva
omap4_vdd_data_configure: Unable to get volt table for vdd_iva at init
vp_latch_vsel: unable to find current voltage for vdd_iva
omap_voltage_get_voltdata: Unable to match the current voltage 1100000 with the voltagetable for vdd_core
omap4_vdd_data_configure: Unable to get volt table for vdd_core at init
vp_latch_vsel: unable to find current voltage for vdd_core
ipu-power ipu0: Test of writing to the device message log,done from ipu_pm_init
ipu-power initialized ipu, major: 251, minor: 0
sdp4430_wifi_init: start
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: tesla registered
iovmm-omap initialized ducati, major: 250, base-minor: 0
iovmm-omap initialized tesla, major: 250, base-minor: 1
omap-remoteproc omap-remoteproc.0: omap_rproc_probe: adding rproc tesla
omap-remoteproc omap-remoteproc.0: omap-rproc initialized tesla, major: 249, base-minor: 0
omap-remoteproc omap-remoteproc.1: omap_rproc_probe: adding rproc ducati-proc0
omap-remoteproc omap-remoteproc.1: omap-rproc initialized ducati-proc0, major: 249, base-minor: 1
omap-remoteproc omap-remoteproc.2: omap_rproc_probe: adding rproc ducati-proc1
omap-remoteproc omap-remoteproc.2: omap-rproc initialized ducati-proc1, major: 249, base-minor: 2
highmem bounce pool size: 64 pages
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 1371
Registering char device tf_driver (122:0)
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 4.0
OMAP DISPC rev 4.0
OMAP DSI rev 3.0
OMAP DSI2 rev 3.0
Enter hdmi_init()
hdmi_panel_probe x_res= 1920 y_res = 1080
pico DLP probe called
misc dsscomp: found 4 displays and 4 overlays
omap_smartreflex_disable_reset_volt: omap_sr struct for sr_core not found
vp_forceupdate_scale_voltage: bad target data
omap_smartreflex_enable: omap_sr struct for sr_core not found
omap_voltage_get_voltdata: Unable to match the current voltage 930000 with the voltagetable for vdd_core
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap-hsuart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
omap-hsuart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
omap-hsuart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
console [ttyO2] enabled
omap-hsuart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
brd: module loaded
loop: module loaded
(stk) :sysfs entries created
(stk) : debugfs entries created
ks8851 spi1.0: message enable is 0
ks8851 spi1.0: eth0: revision 0, MAC 08:00:28:01:51:68, IRQ 194, has EEPROM
usbcore: registered new interface driver zd1201
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
android init
android_probe pdata: c06bb648
android_bind
android_usb gadget: android_usb ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.35.7-00367-g5db5e8f musb-hcd
usb usb1: SerialNumber: musb_hdrc
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
PC detected
f_adb init
android_register_function adb
f_mass_storage init
fsg_probe pdev: c06bb390, pdata: c06bb638
android_register_function usb_mass_storage
f_rndis init
android_register_function rndis
rndis_function_bind_config MAC: 02:02:31:38:38:30
android_usb gadget: using random self ethernet address
android_usb gadget: using random host ethernet address
usb0: MAC de:46:f1:69:b9:40
usb0: HOST MAC 42:33:3c:57:f6:a2
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
 lun0: LUN: removable file: (no medium)
adb_bind_config
input: omap-keypad as /devices/platform/omap-keypad/input/input0
tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
tm12xx_ts 2-004b: resetting device (reg 0x62)
tm12xx_ts 2-004b: no button capabilities found
tm12xx_ts: product ID: TM1217 family:1 fw:9
input: syn_tm12xx_ts_1 as /devices/platform/i2c_omap.2/i2c-2/2-004b/input/input1
tm12xx_ts 2-004b: device status: 0x0, no error
tm12xx_ts 3-004b: resetting device (reg 0x62)
twl6030_pwrbutton_probe: Enter
input: twl6030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-0049/twl6030_pwrbutton/input/input2
sfh7741_probe: Proximity sensor
input: sfh7741 as /devices/platform/sfh7741.1/input/input3
tm12xx_ts 3-004b: no button capabilities found
CMA3000 Acclerometer : Revision 10
input: syn_tm12xx_ts_2 as /devices/platform/i2c_omap.3/i2c-3/3-004b/input/input4
tm12xx_ts 3-004b: device status: 0x0, no error
input: cma3000-acclerometer as /devices/virtual/input/input5
android_usb gadget: high speed config #1: android
bh1780 3-0029: Ambient Light Sensor, Rev : 1
input: bh1780gli as /devices/virtual/input/input6
input: hmc5843 as /devices/virtual/input/input7
bmp085 4-0077: BMP085 ver. 1.0 found.
input: bmp085 as /devices/virtual/input/input8
bmp085 4-0077: Succesfully initialized bmp085!
using rtc device, twl_rtc, for alarms
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
Linux video capture interface: v2.00
twl6030_bci twl6030_bci: Battery Voltage at Bootup is 3681 mV
lm75 3-0048: hwmon0: sensor 'tmp105'
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
cpuidle: using governor ladder
cpuidle: using governor menu
omap4430_sdp_display_probe:Enter
omap4430_sdp_display_probe:Exit
omap4430_keypad_led_probe:Enter
omap4430_keypad_led_probe:Exit
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
logger: created 64K log 'log_system'
OMAP HSI: HSI DRIVER Version 0.4.1
omap_hsi omap_hsi.0: Registering IRQ hsi_p1_mpu (99)
omap_hsi omap_hsi.0: Registering IRQ hsi_dma_mpu (103)
omap_hsi omap_hsi.0: HSI Hardware REVISION 0x50043101
omap_smartreflex_disable: omap_sr struct for sr_mpu not found
omap_smartreflex_disable: omap_sr struct for sr_iva not found
omap_smartreflex_disable: omap_sr struct for sr_core not found
omap_smartreflex_enable: omap_sr struct for sr_mpu not found
omap_smartreflex_enable: omap_sr struct for sr_iva not found
proc4430_drv_initializeModule
omap-devicehandler omap-devicehandler.0: omap_devh_probe: adding devh Tesla
omap-devh initialized Tesla, major: 240, base-minor: 0
omap-devicehandler omap-devicehandler.1: omap_devh_probe: adding devh SysM3
omap-devh initialized SysM3, major: 240, base-minor: 1
omap-devicehandler omap-devicehandler.2: omap_devh_probe: adding devh AppM3
omap-devh initialized AppM3, major: 240, base-minor: 2
usbcore: registered new interface driver snd-usb-audio
hdmi_lib already initialized
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.39 GiB
 mmcblk0:
SDP4430 SoC init
asoc: null-codec-dai <-> MultiMedia1 mapping ok
asoc: null-codec-dai <-> MultiMedia2 mapping ok
asoc: null-codec-dai <-> Voice mapping ok
asoc: null-codec-dai <-> Tones mapping ok
asoc: null-codec-dai <-> Vibra mapping ok
 unknown partition table
asoc: null-codec-dai <-> MODEM mapping ok
asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
asoc: HDMI <-> hdmi-dai mapping ok
asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
asoc: twl6040-vib <-> mcpdm-vib mapping ok
asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
input: SDP4430 Headset Jack as /devices/platform/soc-audio/sound/card0/input9
ALSA device list:
  #0: TI OMAP4 SDP4430 Board
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (15071 buckets, 60284 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
Mobile IPv6
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.14
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
ThumbEE CPU extension supported.
omap_hwmod: Initialize debugfs support
Power Management for TI OMAP4.
prcm_clear_statdep_regs: Clearing static depndencies
CPUidle for CPU0 registered
CPUidle for CPU1 registered
sr_init: No PMIC hook to init smartreflex
smartreflex smartreflex.0: omap_smartreflex_probe: SmartReflex driver initialized
smartreflex smartreflex.1: omap_smartreflex_probe: SmartReflex driver initialized
smartreflex smartreflex.2: omap_smartreflex_probe: SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 1
omapdss DSI error: Warning: hs_mode_timing not defined
taal display0: taal panel revision e3.85.7d
mmc1: host does not support reading read-only switch. assuming write-enable.
mmc1: new high speed SD card at address 0007
mmcblk1: mmc1:0007 SD02G 1.90 GiB
 mmcblk1: p1 p2
twl_rtc twl_rtc: setting system clock to 2000-01-01 20:58:58 UTC (946760338)
omap_vout omap_vout: : registered and initialized video device 0
omap_vout omap_vout: : registered and initialized video device 1
omap_wb: registered and initialized wb device 3 [v4l2]
Waiting 2sec before mounting root device...
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk1p2): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (mmcblk1p2): using internal journal
EXT3-fs (mmcblk1p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:18.
devtmpfs: mounted
Freeing init memory: 244K
init: cannot open '/initlogo.rle'
smartreflex smartreflex.0: sr_enable: Unable to get voltage table for nominal voltage
smartreflex smartreflex.1: sr_enable: Unable to get voltage table for nominal voltage
smartreflex smartreflex.2: sr_enable: Unable to get voltage table for nominal voltage
omapdss HDMI: powerchg (a=0,v=0,s=0/0)->(a=0,v=1,s=0) = (1:A)
omapdss HDMI: Enable HDMI_PHY_48MHz clock
omapdss HDMI: Set L3-200Mhz constraint
omapdss HDMI: pwrchanged => (1,A) = 0
omapdss HDMI: Disable HDMI_PHY_48MHz clock
omapdss HDMI: Release L3-200Mhz constraint
init: Unable to open persistent property directory /data/property errno: 2
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
enabling adb
adb_open
$ Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
fm_drv: module is from the staging directory, the quality is unknown, you have been warned.
gps_drv: module is from the staging directory, the quality is unknown, you have been warned.
FM Radio: V4L2 FM Driver for TI WiLink - Version 0.10
omap_voltage_get_voltdata: Unable to match the current voltage 930000 with the voltagetable for vdd_iva
Unable to handle kernel paging request at virtual address ffffffd5
pgd = ef1f4000
[ffffffd5] *pgd=80fa9021, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP
last sysfs file: /sys/power/state
Modules linked in: fm_v4l2_drv gps_drv(C) fm_drv(C) btwilink
CPU: 0    Tainted: G         C   (2.6.35.7-00367-g5db5e8f #1)
PC is at omap_abb_notify_voltage+0x1c/0x88
LR is at notifier_call_chain+0x40/0x70
pc : [<c005cb54>]    lr : [<c00aa19c>]    psr: a0000093
sp : ef11db08  ip : ef11db20  fp : ef11db1c
r10: 00000000  r9 : c06a9d38  r8 : ef11dba4
r7 : 00000000  r6 : ffffffff  r5 : 00000000  r4 : ef11dba4
r3 : 00000000  r2 : ffffffc3  r1 : 00000000  r0 : ffffffc3
Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: af1f404a  DAC: 00000015
PC: 0xc005cad4:
cad4  e3a05000 e5943064 e3a00001 e3a01000 e1d426b0 e1a00310 ebffe4b7 e3a00000
caf4  e1d416b0 ebffe4d1 e5943068 e0100003 089da830 e59f001c e2855001 eb06e3bb
cb14  e355001e 1affffee e59f0010 eb128600 e3e0000f e89da830 000218de c05faffd
cb34  c05fb031 e1a0c00d e92dd818 e24cb004 e1a04002 e5922008 e5940004 e1a03001
cb54  e5d22012 e5d00012 e1500002 03a00000 089da818 e3510000 1a000005 e3520000
cb74  02822c1b 05943000 03a00003 0a000007 ea00000b e3510001 1a000009 e3520001
cb94  1a000007 e5943000 e3a00003 e3a02c1b e1d335fe ebffe4c3 e5940000 ebffff9f
cbb4  e89da818 e3e00015 e89da818 e1a0c00d e92dd878 e24cb004 e2504000 0a000001
LR: 0xc00aa11c:
a11c  e92dd800 e24cb004 ea000007 e1530001 1a000004 f57ff05f e5913004 e5803000
a13c  e3a00000 e89da800 e2830004 e5903000 e3530000 1afffff4 e3e00001 e89da800
a15c  e1a0c00d e92dd9f8 e24cb004 e1a08002 e1a04001 e5902000 e1a06003 e59b5004
a17c  e3a00000 ea00000d e5923000 e1a00002 e5927004 e1a01004 e1a02008 e12fff33
a19c  e3550000 15953000 12833001 15853000 e3100902 189da9f8 e2466001 e1a02007
a1bc  e3560000 13520000 1affffee e89da9f8 e1a0c00d e92dd800 e24cb004 ebffffbd
a1dc  e89da800 e1a0c00d e92dd800 e24cb004 ebffffc9 e89da800 e1a0c00d e92dd800
a1fc  e24cb004 e24dd008 e59bc004 e58dc000 ebffffd2 e24bd00c e89da800 e1a0c00d
SP: 0xef11da88:
da88  ef11c000 00006730 00006798 c0700784 c06a9d38 c06bca58 ffffffff ef11daf4
daa8  ffffffff 00000000 ef11db1c ef11dac0 c0045c6c c0045484 ffffffc3 00000000
dac8  ffffffc3 00000000 ef11dba4 00000000 ffffffff 00000000 ef11dba4 c06a9d38
dae8  00000000 ef11db1c ef11db20 ef11db08 c00aa19c c005cb54 a0000093 ffffffff
db08  c005cb38 00000000 ef11db44 ef11db20 c00aa19c c005cb44 ffffffff c06a9d68
db28  c06a9d50 ffffffff ef11dba4 00000000 ef11db74 ef11db48 c00aa2d4 c00aa168
db48  00000000 00000001 c06a9d08 c06a9cb0 ffffffc3 000e30d0 00000001 00000001
db68  ef11db8c ef11db78 c00aa310 c00aa294 00000000 00000000 ef11dbdc ef11db90
IP: 0xef11daa0:
daa0  ffffffff ef11daf4 ffffffff 00000000 ef11db1c ef11dac0 c0045c6c c0045484
dac0  ffffffc3 00000000 ffffffc3 00000000 ef11dba4 00000000 ffffffff 00000000
dae0  ef11dba4 c06a9d38 00000000 ef11db1c ef11db20 ef11db08 c00aa19c c005cb54
db00  a0000093 ffffffff c005cb38 00000000 ef11db44 ef11db20 c00aa19c c005cb44
db20  ffffffff c06a9d68 c06a9d50 ffffffff ef11dba4 00000000 ef11db74 ef11db48
db40  c00aa2d4 c00aa168 00000000 00000001 c06a9d08 c06a9cb0 ffffffc3 000e30d0
db60  00000001 00000001 ef11db8c ef11db78 c00aa310 c00aa294 00000000 00000000
db80  ef11dbdc ef11db90 c005cf18 c00aa2fc ef11dbb4 ef11dba0 c04fe34c c06a9d50
FP: 0xef11da9c:
da9c  c06bca58 ffffffff ef11daf4 ffffffff 00000000 ef11db1c ef11dac0 c0045c6c
dabc  c0045484 ffffffc3 00000000 ffffffc3 00000000 ef11dba4 00000000 ffffffff
dadc  00000000 ef11dba4 c06a9d38 00000000 ef11db1c ef11db20 ef11db08 c00aa19c
dafc  c005cb54 a0000093 ffffffff c005cb38 00000000 ef11db44 ef11db20 c00aa19c
db1c  c005cb44 ffffffff c06a9d68 c06a9d50 ffffffff ef11dba4 00000000 ef11db74
db3c  ef11db48 c00aa2d4 c00aa168 00000000 00000001 c06a9d08 c06a9cb0 ffffffc3
db5c  000e30d0 00000001 00000001 ef11db8c ef11db78 c00aa310 c00aa294 00000000
db7c  00000000 ef11dbdc ef11db90 c005cf18 c00aa2fc ef11dbb4 ef11dba0 c04fe34c
R4: 0xef11db24:
db24  c06a9d68 c06a9d50 ffffffff ef11dba4 00000000 ef11db74 ef11db48 c00aa2d4
db44  c00aa168 00000000 00000001 c06a9d08 c06a9cb0 ffffffc3 000e30d0 00000001
db64  00000001 ef11db8c ef11db78 c00aa310 c00aa294 00000000 00000000 ef11dbdc
db84  ef11db90 c005cf18 c00aa2fc ef11dbb4 ef11dba0 c04fe34c c06a9d50 ef11dbbc
dba4  c06a9cb0 ffffffc3 ffffffc3 c005c4ec c06a9cb0 c06a9d08 00000000 000e30d0
dbc4  00000001 c06a9d38 00000001 ef11dc24 ef11dbe0 c005d480 c005cec8 ef1b0ab0
dbe4  c06a9d38 efd94210 ef1b0aa0 ef11dc24 ef11dc00 c005d3a8 00000000 60000013
dc04  efd94210 c06a9d08 efcfd400 efdd6800 c06ea3f8 ef11dc54 ef11dc28 c0071994
R8: 0xef11db24:
R9: 0xc06a9cb8:
9cb8  00007c74 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9cd8  00000000 00000000 00000000 00000000 00000000 00000000 002d000a 00000000
9cf8  00000000 20000000 c06ad3dc efd7fa10 c05fb380 00dc00d8 00000010 0000001f
9d18  80000000 c06aa354 00000000 00000000 ef1b0aa8 ef1b0aa8 ef1b0ab0 ef1b0ab0
9d38  00000000 00000000 00000000 c06a9d44 c06a9d44 ef11c000 00000001 00000000
9d58  00000000 c06a9d5c c06a9d5c 00000000 00000000 c00480a0 00000001 00000000
9d78  00000000 c06a9d7c c06a9d7c 00000000 c06aa11c 00000004 00000001 efcec120
9d98  00000003 ffffffc3 ffffffc3 00005b9c 00000010 c06b9224 00000000 00000000
Process mediaserver (pid: 1545, stack limit = 0xef11c2f8)
Stack: (0xef11db08 to 0xef11e000)
db00:                   c005cb38 00000000 ef11db44 ef11db20 c00aa19c c005cb44
db20: ffffffff c06a9d68 c06a9d50 ffffffff ef11dba4 00000000 ef11db74 ef11db48
db40: c00aa2d4 c00aa168 00000000 00000001 c06a9d08 c06a9cb0 ffffffc3 000e30d0
db60: 00000001 00000001 ef11db8c ef11db78 c00aa310 c00aa294 00000000 00000000
db80: ef11dbdc ef11db90 c005cf18 c00aa2fc ef11dbb4 ef11dba0 c04fe34c c06a9d50
dba0: ef11dbbc c06a9cb0 ffffffc3 ffffffc3 c005c4ec c06a9cb0 c06a9d08 00000000
dbc0: 000e30d0 00000001 c06a9d38 00000001 ef11dc24 ef11dbe0 c005d480 c005cec8
dbe0: ef1b0ab0 c06a9d38 efd94210 ef1b0aa0 ef11dc24 ef11dc00 c005d3a8 00000000
dc00: 60000013 efd94210 c06a9d08 efcfd400 efdd6800 c06ea3f8 ef11dc54 ef11dc28
dc20: c0071994 c005d3cc 0bb80000 02ee0000 05dc0000 000e30d0 efd8e800 efdd6800
dc40: efd94210 efd25ae0 ef11dc7c ef11dc58 c03c9cfc c0071840 c03c9c80 ef645c08
dc60: efd7b720 efd25ae0 00000000 c06e9510 ef11dcbc ef11dc80 c03bfb44 c03c9c8c
dc80: c03c3194 ef645d40 efdcf880 00000000 c03c1fa0 00000000 efc664e0 efd25300
dca0: 00000000 efd88100 ef644e88 ef644cf0 ef11dcfc ef11dcc0 c03c6ba0 c03bf9f0
dcc0: ef646d48 c06eb898 00000015 c065e4c0 efd25300 ef644cf0 efc664e0 efd25300
dce0: ef02dc00 c06e9118 efd88100 c06e9af8 ef11dd3c ef11dd00 c03bfb08 c03c6b14
dd00: 000f4240 ef644e28 efdcf880 00000001 c03a3d58 ef11dd74 00000000 ef11c000
dd20: ef656ae0 ef656af8 00000000 00000000 ef11dd5c ef11dd40 c03a7280 c03bf9f0
dd40: c008b180 efd88100 ef656a00 ef19fc80 ef11dda4 ef11dd60 c03a73e8 c03a7230
dd60: 00000000 ef21f520 c008b180 ef656b00 ef656b00 c0218ea4 00000003 ef19fc80
dd80: ef14f7a8 ef14f7a8 00000000 ef63f160 ef9937f8 00000000 ef11ddbc ef11dda8
dda0: c03a7578 c03a72dc c053198c ef19fc80 ef11dde4 ef11ddc0 c039ac7c c03a7540
ddc0: c039aadc ef14f7a8 00000000 ef19fc80 efc73640 00000000 ef11de14 ef11dde8
dde0: c00fe5f4 c039aae8 c0501304 00000017 ef11de14 ef64f780 ef9967f8 ef19fc80
de00: ef14f7a8 c00fe454 ef11de3c ef11de18 c00f9e80 c00fe460 ef19fc80 00000000
de20: 000a0802 00000026 00000000 00000000 ef11de5c ef11de40 c00fa078 c00f9cf8
de40: ef0d8e40 ef11dec8 00000000 ef11dec8 ef11de94 ef11de60 c0105938 c00fa038
de60: 00000000 00000026 ef11de94 000a0802 00000026 ef11c000 00000000 00000026
de80: ef11c000 ef170000 ef11df5c ef11de98 c0107480 c01054f0 00000000 ef170000
dea0: ef22d0c0 efd8ed7c ef11dec4 ef11deb8 ffffff9c 00000000 00000000 40045532
dec0: 000a0803 00000000 ef64f780 ef9967f8 c42578c2 00000008 ef170009 ef64f700
dee0: ef91c660 00000101 00000000 00000000 ef11df7c ef11df00 c0109048 c0108994
df00: 00000000 ef011468 ef011460 ef0114a0 00000000 000a0803 00000000 ef19fc80
df20: c0110ebc c0500db8 ef64f780 ef9967f8 ef11df5c 00000000 00000012 000a0802
df40: 00000000 ef170000 ef11c000 ffffff9c ef11df94 ef11df60 c00f9bd8 c0107324
df60: 00000000 00000011 c00463a8 8008c8bc 00000001 ffffffff 00000005 c00463a8
df80: ef11c000 00000000 ef11dfa4 ef11df98 c00f9ccc c00f9b80 00000000 ef11dfa8
dfa0: c0046200 c00f9cb0 8008c8bc 00000001 bec448fc 000a0802 00000000 bec447a4
dfc0: 8008c8bc 00000001 ffffffff 00000005 00000001 bec448fc bec447dc 00000802
dfe0: 8008c96c bec447a0 afd16ffd afd0b4fc 60000010 bec448fc c06a3f20 00200200
Backtrace:
[<c005cb38>] (omap_abb_notify_voltage+0x0/0x88) from [<c00aa19c>] (notifier_call_chain+0x40/0x70)
 r4:00000000 r3:c005cb38
[<c00aa15c>] (notifier_call_chain+0x0/0x70) from [<c00aa2d4>] (__srcu_notifier_call_chain+0x4c/0x68)
 r8:00000000 r7:ef11dba4 r6:ffffffff r5:c06a9d50 r4:c06a9d68
r3:ffffffff
[<c00aa288>] (__srcu_notifier_call_chain+0x0/0x68) from [<c00aa310>] (srcu_notifier_call_chain+0x20/0x28)
[<c00aa2f0>] (srcu_notifier_call_chain+0x0/0x28) from [<c005cf18>] (omap_voltage_scale_vdd+0x5c/0x378)
[<c005cebc>] (omap_voltage_scale_vdd+0x0/0x378) from [<c005d480>] (omap_voltage_scale+0xc0/0x2e4)
[<c005d3c0>] (omap_voltage_scale+0x0/0x2e4) from [<c0071994>] (omap_device_set_rate+0x160/0x1a4)
[<c0071834>] (omap_device_set_rate+0x0/0x1a4) from [<c03c9cfc>] (aess_open+0x7c/0x2dc)
 r7:efd25ae0 r6:efd94210 r5:efdd6800 r4:efd8e800
[<c03c9c80>] (aess_open+0x0/0x2dc) from [<c03bfb44>] (snd_soc_pcm_open+0x160/0x598)
 r8:c06e9510 r7:00000000 r6:efd25ae0 r5:efd7b720 r4:ef645c08
r3:c03c9c80
[<c03bf9e4>] (snd_soc_pcm_open+0x0/0x598) from [<c03c6ba0>] (omap_abe_dai_startup+0x98/0x2d8)
[<c03c6b08>] (omap_abe_dai_startup+0x0/0x2d8) from [<c03bfb08>] (snd_soc_pcm_open+0x124/0x598)
[<c03bf9e4>] (snd_soc_pcm_open+0x0/0x598) from [<c03a7280>] (snd_pcm_open_substream+0x5c/0xac)
[<c03a7224>] (snd_pcm_open_substream+0x0/0xac) from [<c03a73e8>] (snd_pcm_open+0x118/0x21c)
 r5:ef19fc80 r4:ef656a00
[<c03a72d0>] (snd_pcm_open+0x0/0x21c) from [<c03a7578>] (snd_pcm_playback_open+0x44/0x48)
[<c03a7534>] (snd_pcm_playback_open+0x0/0x48) from [<c039ac7c>] (snd_open+0x1a0/0x280)
 r5:ef19fc80 r4:c053198c
[<c039aadc>] (snd_open+0x0/0x280) from [<c00fe5f4>] (chrdev_open+0x1a0/0x1c4)
 r8:00000000 r7:efc73640 r6:ef19fc80 r5:00000000 r4:ef14f7a8
r3:c039aadc
[<c00fe454>] (chrdev_open+0x0/0x1c4) from [<c00f9e80>] (__dentry_open+0x194/0x2b0)
 r8:c00fe454 r7:ef14f7a8 r6:ef19fc80 r5:ef9967f8 r4:ef64f780
[<c00f9cec>] (__dentry_open+0x0/0x2b0) from [<c00fa078>] (nameidata_to_filp+0x4c/0x64)
[<c00fa02c>] (nameidata_to_filp+0x0/0x64) from [<c0105938>] (do_last+0x454/0x57c)
 r4:ef11dec8
[<c01054e4>] (do_last+0x0/0x57c) from [<c0107480>] (do_filp_open+0x168/0x4cc)
[<c0107318>] (do_filp_open+0x0/0x4cc) from [<c00f9bd8>] (do_sys_open+0x64/0x11c)
[<c00f9b74>] (do_sys_open+0x0/0x11c) from [<c00f9ccc>] (sys_open+0x28/0x2c)
[<c00f9ca4>] (sys_open+0x0/0x2c) from [<c0046200>] (ret_fast_syscall+0x0/0x30)
Code: e1a04002 e5922008 e5940004 e1a03001 (e5d22012)
---[ end trace 55125e000102a22d ]---
Kernel panic - not syncing: Fatal exception
CPU1: stopping
Backtrace:
[<c004a420>] (dump_backtrace+0x0/0x110) from [<c04fe238>] (dump_stack+0x18/0x1c)
 r6:00000001 r5:00000010 r4:c19bf040 r3:00000000
[<c04fe220>] (dump_stack+0x0/0x1c) from [<c00452d8>] (do_IPI+0xe0/0x158)
[<c00451f8>] (do_IPI+0x0/0x158) from [<c0045cc8>] (__irq_svc+0x48/0xe0)
Exception stack(0xef653e10 to 0xef653e58)
3e00:                                     ef638960 00000000 ef668598 00000000
3e20: ef021410 ef017800 ef638960 00000000 ef63896c 00000000 00000000 ef653e64
3e40: ef653e68 ef653e58 c035c24c c0500d30 60000113 ffffffff
 r8:00000001 r7:00000002 r6:00000001 r5:fa240100 r4:ffffffff
r3:60000113
[<c0500d0c>] (_raw_spin_unlock_irq+0x0/0x50) from [<c035c24c>] (mmc_blk_issue_rq+0x408/0x500)
[<c035be44>] (mmc_blk_issue_rq+0x0/0x500) from [<c035cc38>] (mmc_queue_thread+0xf4/0xf8)
[<c035cb44>] (mmc_queue_thread+0x0/0xf8) from [<c00a4af8>] (kthread+0x84/0x8c)
[<c00a4a74>] (kthread+0x0/0x8c) from [<c00924d4>] (do_exit+0x0/0x5f0)
 r7:00000013 r6:c00924d4 r5:c00a4a74 r4:efe4bd68
Why and how to solve this problem?
Thanks.
  • OMAP4 SDP is not supported in TI Android DevKit. Suggest you to look for answers at omappedia or with your TI rep.
    I am not familiar with the OMAP4 kernel, but from the logs it appears that some userspace component is not compatible with the kernel.
    Please click the Verify Answer button on this post if it answers your question.
  • In reply to Vishveshwar Bhat:
    Thanks for  your comment.
    I think that TI OMAP4 SDP is supported by Android, at least http://www.omappedia.org/wiki/L27.INC1.10.2-P1_OMAP4_Froyo_ES2_Release_Notes is good for my omap4430.
    I don't understand that why IT Tested Android GingerBread pre-built_binaries cannot run on my omap4(http://www.omappedia.org/wiki/Android:_Working_with_pre-built_binaries L27.12.1-P1).
    Hey I am getting the error while I am initializing the ethernet controller for OMAP4430 panda board. Its not able to read the chip id form there.
    So any one can confirm that whether 0x15000000 is correct address for ethernet or not.
    And also tell which ethernet chip ontroller we are using in OAMP443 panda board.
