• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » OMAP™ Applications Processors » OMAP 4 Forum » gpio irq in omap 4460
Share
  • Forums
Options
  • Subscribe via RSS
This question is answered
sunil kumar dommati
Posted by sunil kumar dommati
on Mar 27 2012 05:43 AM
Prodigy60 points
Hi ,
I want to use GPIO155 in OMAP 4460 for external interrupt.
So I configured it as input and used gpio_to_irq and request_irq to configure the interrupt.
Apart from that, i want to clear the IRQ status of this pin to make sure it is cleared.
How can I clear the IRQ status of this pin from my driver.?
Thanks in advance.
Sunil
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Israel Cepeda
    Posted by Israel Cepeda
    on Mar 27 2012 10:42 AM
    Expert5515 points
    GPIO_155 belongs to the GPIO5 submodule, so you will need to clear the irq status bit on that module. For more info look at TRM chapter 25 General-Purpose Interface
    Regards!
    ICe
    Please click the Verify Answer button on this post if it answers your question.
    Regards!
    ICe
    _______________________________________________________
    Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
    OMAP4460
    Report Abuse
    • Reply
  • sunil kumar dommati
    on Mar 28 2012 01:50 AM
    Prodigy60 points
    Hi ICe,
    Thanks for the reply.
    I am trying to use the register GPIO_IRQSTATUS_0 (0x4805 B02C) to clear the IRQ status of pin 155.
    I am not sure if I can use this register.
    When I clear the status bit like,
    irqstatus=ioremap(0x4805B02C, sizeof(unsigned int));
    iowrite32((1<<(155%32)),irqstatus);
    at the function call iowrite32 , Iam getting an exception.
    Even I tried using GPIO_IRQSTATUS_CLR_0 also.But still I am getting the following exception.
    Please let me know If I miss anything here.
    [ 1072.206115] WARNING: at arch/arm/mach-omap2/omap_l3_noc.c:135 l3_interrupt_h)
    [ 1072.215667] CUSTOM SRESP error with SOURCE:L4 PER2
    [ 1072.220916] Modules linked in: vfsspidrv [last unloaded: vfsspidrv]
    [ 1072.228179] Backtrace:
    [ 1072.231048] [<c0050980>] (dump_backtrace+0x0/0x10c) from [<c05413d4>] (dump_)
    [ 1072.240112]  r7:00000009 r6:00000087 r5:c0070094 r4:c0703de8
    [ 1072.247070] [<c05413bc>] (dump_stack+0x0/0x1c) from [<c0090974>] (warn_slowp)
    [ 1072.256774] [<c0090920>] (warn_slowpath_common+0x0/0x6c) from [<c0090a30>] ()
    [ 1072.267059]  r9:c0789a44 r8:f0834b00 r7:00080003 r6:c0730d68 r5:00000b48
    [ 1072.274810] r4:f0834000
    [ 1072.278076] [<c00909f8>] (warn_slowpath_fmt+0x0/0x40) from [<c0070094>] (l3_)
    [ 1072.288543]  r3:c0673f2c r2:c0673e30
    [ 1072.292907] [<c006fe38>] (l3_interrupt_handler+0x0/0x34c) from [<c00d3cf0>] )
    [ 1072.303833] [<c00d3c9c>] (handle_irq_event_percpu+0x0/0x188) from [<c00d3e68)
    [ 1072.314422] [<c00d3e24>] (handle_irq_event+0x0/0x64) from [<c00d662c>] (hand)
    [ 1072.324523]  r7:0000002a r6:c0702000 r5:c0705b8c r4:c0705b40
    [ 1072.331359] [<c00d658c>] (handle_fasteoi_irq+0x0/0x10c) from [<c00d3858>] (g)
    [ 1072.341705]  r5:c0044e80 r4:c0714568
    [ 1072.345977] [<c00d381c>] (generic_handle_irq+0x0/0x48) from [<c0046054>] (as)
    [ 1072.355468] [<c0046000>] (asm_do_IRQ+0x0/0xb4) from [<c004c4c8>] (__irq_svc+)
    [ 1072.363952] Exception stack(0xc0703ee0 to 0xc0703f28)
    [ 1072.369567] 3ee0: c0703f28 3b9aca00 466fcd5b 00000000 c0edf100 c0703f28 a2e69
    [ 1072.378387] 3f00: a302e35b 000000f9 00000000 c0703f5c fffffff1 c0703f28 c0070
    [ 1072.387329] 3f20: 90000113 ffffffff
    [ 1072.391265]  r9:c0702000 r8:00000001 r7:00000002 r6:0000002a r5:fa240100
    [ 1072.398986] r4:ffffffff
    [ 1072.402252] [<c00637f0>] (omap4_enter_idle_wfi+0x0/0xdc) from [<c035b0d8>] ()
    [ 1072.412689]  r9:412fc09a r8:8000406a r7:c071be14 r6:c07ccc44 r5:c0edf110
    [ 1072.420440] r4:c0edf100
    [ 1072.423706] [<c035b03c>] (cpuidle_idle_call+0x0/0x130) from [<c004dfb0>] (cp)
    [ 1072.433105]  r9:412fc09a r8:8000406a r6:c054ae44 r5:c07619c4 r4:c0702000
    [ 1072.441009] [<c004deec>] (cpu_idle+0x0/0x104) from [<c0537304>] (rest_init+0)
    [ 1072.449554]  r7:00000000 r6:c003955c r5:00000000 r4:c0702000
    [ 1072.456451] [<c0537264>] (rest_init+0x0/0xa4) from [<c000896c>] (start_kerne)
    [ 1072.465301]  r5:00000000 r4:c07143dc
    [ 1072.469696] [<c00086c4>] (start_kernel+0x0/0x2fc) from [<8000803c>] (0x80008)
    [ 1072.477691] ---[ end trace 4dab73311341e9a5 ]---
    Thanks in advance.
    Sunil.
    Report Abuse
    • Reply
  • Israel Cepeda
    on Mar 28 2012 09:35 AM
    Expert5515 points
    Hi Sunil,
    Are you sure it crash when cleaning the bit?, it seems to me that it fails when it is interrupting.
    L3 is detecting an error on L4 PER, I am not sure what it could be without the code.
    Tip: Make sure the GPIO5 module has a clock running
    Regards!
    ICe
    Report Abuse
    • Reply
  • Israel Cepeda
    on Mar 28 2012 10:10 AM
    Expert5515 points
    Also checking with some partners with more experience on irq, they said that the ioremap shouldn't be inside the isr, it is preferable to store the value in the probe on somewhere else before irq.
    Also maybe you would prefer to use an easy framework: drivers/gpio/gpio-omap.c
    Regards!
    ICe
    Report Abuse
    • Reply
  • Gina Glaser
    Posted by Gina Glaser
    on Mar 28 2012 11:12 AM
    Expert8055 points
    Sunil,
    Per the message you are getting:
    See the post http://e2e.ti.com/support/omap/f/849/t/176367.aspx
    Please ensure that you are using a recent x-loader matched to your particular release.
    Gina
    Report Abuse
    • Reply
    on Mar 29 2012 05:57 AM
    Prodigy60 points
    Hi ICe,
    Thanks for the response.
    Its giving exception when I am writing into that register. If I comment it , it works fine.
    I already enabled the GPIO5 clock as,
    clkenable=ioremap(0x4A009478,sizeof(unsigned int));   // CM_L4PER_GPIO5_CLKCTRL.MODULEMODE set to 1
    *clkenable &=0xFFFFFFFD;
    I am not using this clearing of IRQ status in the ISR. It is in probe function , I am clearing  the IRQ  status just to make sure.
    So only when I insert my module it is called.
    I tried using the gpio-omap.c API's.
    There is an API " _clear_gpio_irqstatus(struct gpio_bank *bank,int gpio)"
    But I am not sure of the first argument struct gpio_bank *bank  to pass from my driver.
    Sunil
    Report Abuse
    • Reply
  • Israel Cepeda
    on Mar 29 2012 10:30 AM
    Verified Answer
    Verified by Magdalena Iovescu
    Expert5515 points
    Hi Sunil,
    Seems like the problem indeed is the clock, check the bits 17:16  IDLEST:
    Module idle status. [warm reset insensitive]
    Address Offset 0x3
    Read 0x0: Module is fully functional, including
    INTRCONN
    Read 0x1: Module is performing transition: wakeup, or
    sleep, or sleep abortion
    Read 0x2: Module is in idle mode (only INTRCONN part).
    It is functional if using separate functional clock
    Read 0x3: Module is disabled and cannot be accessed
    if you set 0xFFFFFFFD module will continue disabled, try 0xFFFCFFFD and let me know what happen
    Regards!
    ICe
    Report Abuse
    • Reply
    on Mar 30 2012 05:14 AM
    Prodigy60 points
    Hi ICe,
    I have changed the register setting as you suggested, but without any success.
    Still I am getting the same exception.
    Actually I am not getting any interrupt on GPIO 155 if I load my release mode driver.
    If I load Debug mode driver and remove it and then insert Release mode driver, the interrupt is working fine.
    So I am just thinking if any status is cleared in debug mode.
    Sunil.
    Report Abuse
    • Reply
  • Israel Cepeda
    on Apr 05 2012 11:29 AM
    Expert5515 points
    Hi Sunil,
    What do you mean by driver in debug mode?, what are the differences on the driver?
    Regards!
    ICe
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
