• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » OMAP™ Applications Processors » OMAP 4 Forum » What's the GPIO number of GPIO_WK3?
Share
  • Forums
Options
  • Subscribe via RSS
This question is answered
Connie Kuang
Posted by Connie Kuang
on Apr 17 2012 03:53 AM
Intellectual370 points
Dear sir,
I seems that the gpio number of gpio_wkn is n, So the gpio number of "sim_sd.gpio_wk3"  should be 3.  But I found another pin of "KPD_ROW2" whose GPIO number is 3 . If the gpio number of "sim_sd.gpio_wk3" is also be 3, it will be confused when invoking GPIO APIs. So what's the GPIO number of GPIO_WK3?
Thanks!
Connie kuang
GPIO
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Connie Kuang
    on Apr 17 2012 03:57 AM
    Sorry, it is "sim_cd.gpio_wk3", not "sim_sd.gpio_wk3" .
    GPIO
    Report Abuse
    • Reply
  • Gina Glaser
    Posted by Gina Glaser
    on Apr 17 2012 08:40 AM
    Verified Answer
    Verified by Connie Kuang
    Expert8055 points
    Connie,
    You do use the value "n" when invoking the GPIO API's for gpio_wkn.  You can find several examples in the Blaze Tablet board file (/arch/arm/mach-omap2/board-44xx-tablet.c, in the 4AI.1.3 release, for example):
     omap_mux_init_signal("fref_clk0_out.gpio_wk6", OMAP_PIN_OUTPUT);
    gpio_request(6, "msecure");
    gpio_direction_output(6, 1);
    #define GPIO_WK30     30
     omap_mux_init_signal("fref_clk3_req.gpio_wk30", \
    OMAP_PIN_OUTPUT | \
    OMAP_PIN_OFF_NONE | OMAP_PULL_ENA);
    /* Enable 5V,1A USB power on external HS-USB ports */
    if (gpio_is_valid(GPIO_WK30)) {
    gpio_request(GPIO_WK30, "USB POWER GPIO");
    gpio_direction_output(GPIO_WK30, 1);
    gpio_set_value(GPIO_WK30, 0);
    In the case that you mentioned, there should not be an issue since you can only use gpio_wk3 or gpio_3 at once.
    See section 25.2.2 in the TRM:
    NOTE: Users must not use a GPIO channel through two device pads simultaneously. Channels that
    can be mapped on two different device pads are:
    • GPIO[3:0] of the GPIO1 module (signals gpio_[3:0] or gpio_wk[3:0]; each can be routed
    to a different device pad). See Figure 25-4.
    • GPIO[8:4] of the GPIO4 module (signals gpio_[104:100]; each can be routed to two
    different device pads)
    Therefore, appropriate configuration must be done through the pad configuration registers.
    See Section 18.4.8, Pad Functional Multiplexing and Configuration, in Chapter 18, Control
    Module.
    Gina
    Please click the Verify Answer button on this post if it answers your question
    _______________________________________________________
    Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
    Report Abuse
    • Reply
  • Israel Cepeda
    Posted by Israel Cepeda
    on Apr 17 2012 08:45 AM
    Expert5515 points
    Hi Connie,
    Can you provide more info on where are you seeing that?, I am only seeing one gpio_wk3 in OMAP 4430 TRM.
    Regards!
    ICe
    Report Abuse
    • Reply
  • Connie Kuang
    on Apr 17 2012 20:46 PM
    Thanks, Gina!
    GPIO
    Report Abuse
    • Reply
  • Connie Kuang
    on Apr 17 2012 20:53 PM
    Hi Israel
    The two device pad I mentioned above are "sim_sd.gpio_wk3" and "kpd_row2.gpio_3". Thanks!
    Connie Kuang
    GPIO
    Report Abuse
    • Reply
  • Egor Rumjantsev
    Posted by Egor Rumjantsev
    on May 19 2012 02:38 AM
    Intellectual630 points
    Hello, Gina.
    What settings i have to use for gpio_wk1 line  if i want to use this gpio as wakeup source?
    Let's suppose that i don't need gpio_1 but i need gpio_wk1...so i configure gpio_wk1 as following:
    omap_mux_init_signal("sim_clk.gpio_wk1", OMAP_PIN_INPUT | OMAP_WAKEUP_EN |
                            OMAP_WAKEUP_EVENT); /* gpio_wk1 */
    and what mux settings i have to set to gpio_1 pad to switch off it and activate gpio_wk1?
    WBR,
    Report Abuse
    • Reply
  • Gina Glaser
    on May 21 2012 08:29 AM
    Expert8055 points
    Hi Egor,
    I will address these questions on your other thread for this topic, here: http://e2e.ti.com/support/omap/f/849/p/189398/680385.aspx#680385
    Gina
    Report Abuse
    • Reply
  • lipoh Chen
    Posted by lipoh Chen
    on Mar 04 2013 02:00 AM
    Prodigy80 points
    hi,
    i am using gpio_wk3 as one of the input pin in my project. i tried to execute the following commands:
    echo 3 > /sys/class/gpio/export
    echo in > /sys/class/gpio/gpio3/direction
    but i cannot see gpio3 class is created. May i know what is the proper way to do this?
    Thanks a lot.
    Report Abuse
    • Reply
  • Egor Rumjantsev
    on Mar 04 2013 02:53 AM
    Hi.
    All this commands correct but first you have to set up pinmux.
    You can write it some driver or board platform file.
    For example i set pinmux for GPIO3 (not GPIO_WK3)
    omap_mux_init_signal( "kpd_row2.gpio_3",  OMAP_MUX_MODE3 | OMAP_PIN_INPUT |  OMAP_WAKEUP_EN); /* gpio_3 */
    omap_mux_init_signal( "sim_cd.gpio_wk3", OMAP_MUX_MODE7 | OMAP_PIN_INPUT); /* gpio_wk3 */
    If you need exactly GPIO_WK3 you can put GPIO3 in MUX_MODE7 and make GPIO_WK3 as regular gpio OMAP_MUX_MODE3.
    Also i can thry to do such mux in runtime with devmem2 programm - you have to find out register number for GPIO3 and GPIO_WK3 in TRM
    WBR,
    Report Abuse
    • Reply
  • lipoh Chen
    on Mar 05 2013 00:58 AM
    Prodigy80 points
    Hi Egor,
    Thanks for the reply.
    i already configure the pinmux for gpio_wk3 in MUX_MODE7. but the still facing the same problem.
    May you advice me on this?
    Thanks again.
    Report Abuse
    • Reply
  • Egor Rumjantsev
    on Mar 05 2013 01:04 AM
    Hi.
    May be my English not correct :)
    If you want to use GPIO_WK3 you have to set MUX_MODE3, not MUX_MODE7.
    WBR,
    Report Abuse
    • Reply
  • lipoh Chen
    on Mar 05 2013 01:08 AM
    Prodigy80 points
    Hi Egor,
    Sorry, my mistake. i already configure GPIO_WK3 to MUX_MODE3.
    Really sorry on that.
    Report Abuse
    • Reply
  • Egor Rumjantsev
    on Mar 05 2013 02:32 AM
    Then i can't help with this...sorry.
    I've always exported gpio from drivers or kernel board platform file.
    In this cases it worked for me.
    Try to check if pinmux register set up correctly....may be someone change you mux.
    Use devmem2 or other same utility
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
