• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » OMAP™ Applications Processors » OMAP 4 Forum » How to read .264 input to DDR2 ram in omap4430 processor on panda board
Share
  • Forums
Options
  • Subscribe via RSS
This question is answered
studinstru sggs
Posted by studinstru sggs
on Apr 20 2012 01:07 AM
Expert1875 points
I just want to read .264 input to ddr2 ram in omap4430 processor on panda board .
For this purpose ,shall I use .gel file ?
I am working with CCS5 and windows platform.
-Studinstru
omap4430 omap omappedia pandaboard omx h264 omap4460 security Pandabaord OMAP4460 Panda Board panda ICS building error omap 4430 sgx omap4430 blaze code composer OMAP4 Forum Guidelines OMAP4430 Tesla Bios-syslink
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Venkat Ramana Peddigari
    Posted by Venkat Ramana Peddigari
    on Apr 20 2012 02:21 AM
    Verified Answer
    Verified by studinstru sggs
    Expert4080 points
    Did you try using the Memory --> Load option available in CCSv5. When you view the memory tab, you can right click to access the Load option where you can choose the file to load, specify the address, format and length to load the contents into the memory.
    After you connect to the board using CCSv5, halt it using the breakpoint at the location you want to load the content and then use the Memory -> Load option to read the data. Obviously, your code should take care of parsing the header accordingly from that DDR location.
    Thanks & Best Regards,
    Venkat
    Please click the Verify Answer button on this post if it answers your question
    _____________________________________________
    Be sure to read the OMAP4 Forum Guidelines & FAQ-
    Report Abuse
    • Reply
  • Manuel Contreras
    Posted by Manuel Contreras
    on Apr 20 2012 09:52 AM
    Genius9015 points
    Hi, you can try posting your question in next forum Code Composer Forum
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81.aspx
    _______________________________________________________
    Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
    CSS forum
    Report Abuse
    • Reply
  • Manuel Contreras
    on Apr 20 2012 10:02 AM
    Genius9015 points
    Clarifying, I agree with Venkat's post, it must work, i haven't used that option to copy into memory, I knew the option to read from memory and store it in hex view format and binary. In my previous post I was just pointing to CCS forum.
    Report Abuse
    • Reply
  • studinstru sggs
    on Apr 23 2012 06:29 AM
    Expert1875 points
         Thanks a lot, i came to know the options existing to load/save/Fill the memory which i dont know earlier, but what type of input file formats are supported?? because i have H.264(Video Codec) encoded stream in Output.264 format which is a binary file. How can i load this file to the LPDDR2 memory without converting into any other format??
    I read in the manual help about GEL files GEL_MemoryLoad(), GEL_MemorySave(), GEL_MemoryFill(). Can i use these functions to load the memory?? Which one will be more effective option???? Using GEL file or direct right click on memory window and load option??
    studinstru
    bootloader codecs BeagleBoard Beagle Board Camera
    Report Abuse
    • Reply
  • studinstru sggs
    on Apr 23 2012 06:58 AM
    Expert1875 points
    Thanks to Venkat and Manuel.
    I got your point regarding using the memory load options in CCSV5.
    But in this option, mentioned input format should be in .dat or .out ......
    I am using the H.264 encoded stream (Video Codec) which is in .264 format.
    So, how should I use this input(.264) for loading into ddr2 memory (as there are two options only that is .dat and .out) ??
    how should i convert that .264 into .out or .dat ??
    I read some information related to the GEL file.
    Other options according to me for loading the input file into the ddr2 ram is  (Please comment on this) :
    There are some functions like GEL_memory_Load() which is helpful for loading the input  into the processor.
    Please ,Give your suggestions....................!
    -Studinstru
    binaries community member of the month codecs BeagleBoard Beagle Board Check bundled zip containing source code and log file here http://e2e.ti.com/cfs-file.ashx/__key/CommunityServer-Discussions-Components-Files/849/2821.testenc.zip
    Report Abuse
    • Reply
  • Manuel Contreras
    on Apr 23 2012 10:48 AM
    Genius9015 points
    Studinstru;
    I would like to suggest that your question to be moved to proper forum
    and they have a Guidelines and FAQ section
    ///////////////////////// copy-past from CCS forum ///////////////////////////////
    Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
    Click here to track an issue. Enter your bug id in the "Find Record ID" box
    they have a similar post
    http://e2e.ti.com/support/development_tools/code_composer_studio/int-code_composer_studio/f/90/t/162080.aspx
    Report Abuse
    • Reply
  • studinstru sggs
    on Apr 24 2012 01:35 AM
    Expert1875 points
    Ok manuel !
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
