• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » OMAP™ Applications Processors » OMAP 4 Forum » Audio Output Problem on Pandaboard running Ubuntu
Share
  • Forums
Options
  • Subscribe via RSS
This question is answered
Alireza Kenarsari Anhari
Posted by Alireza Kenarsari Anhari
on Jul 31 2012 15:00 PM
Intellectual500 points
I am having issues with the audio output level on my pandaboard (running prebuilt Ubuntu 12.04 precise pangolin).
I did set the audio output level (handset) to maximum possible (through alsamixer) and I can see that the audio samples being written to audio output device have large values the audio out level is very low. I wonder if there is a way to boost the audio out level on panadaboard running Ubuntu.
Alireza
Report Abuse
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Israel Cepeda
    Posted by Israel Cepeda
    on Aug 02 2012 13:15 PM
    Expert5515 points
    Hi Alireza,
    Can you share the out put of amixer controls command?, I want to see which controls and what values you are using. Thanks
    Regards!
    ICe
    Please click the Verify Answer button on this post if it answers your question
    _______________________________________________________
    Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
    ubuntu pandaboard audio
    Report Abuse
  • Alireza Kenarsari Anhari
    on Aug 02 2012 13:22 PM
    Thanks a lot for your reply here is the output of amixer
    Simple mixer control 'Sidetone Equalizer',0
      Capabilities: enum
      Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -18dB'
      Item0: 'Flat response'
    Simple mixer control 'Sidetone Mixer Capture',0
      Capabilities: pswitch pswitch-joined penum
      Playback channels: Mono
      Mono: Playback [off]
    Simple mixer control 'Sidetone Mixer Playback',0
      Mono: Playback [on]
    Simple mixer control 'Aux FM',0
      Capabilities: volume penum
      Playback channels: Front Left - Front Right
      Capture channels: Front Left - Front Right
      Limits: 0 - 7
      Front Left: 7 [100%] [24.00dB]
      Front Right: 7 [100%] [24.00dB]
    Simple mixer control 'Capture',0
      Capabilities: cvolume penum
      Limits: Capture 0 - 4
      Front Left: Capture 4 [100%] [30.00dB]
      Front Right: Capture 4 [100%] [30.00dB]
    Simple mixer control 'Capture Mixer Media Playback',0
    Simple mixer control 'Capture Mixer Tones',0
    Simple mixer control 'Capture Mixer Voice Capture',0
    Simple mixer control 'Capture Mixer Voice Playback',0
    Simple mixer control 'Capture Preamplifier',0
      Limits: 0 - 1
      Front Left: 0 [0%] [-6.00dB]
      Front Right: 0 [0%] [-6.00dB]
    Simple mixer control 'AMIC Equalizer',0
      Capabilities: enum
      Items: 'High-pass 0dB' 'High-pass -12dB' 'High-pass -18dB'
      Item0: 'High-pass 0dB'
    Simple mixer control 'AMIC UL',0
      Limits: 0 - 149
      Front Left: 126 [85%] [6.00dB]
      Front Right: 126 [85%] [6.00dB]
    Simple mixer control 'AUDUL Media',0
      Capabilities: volume volume-joined penum
      Capture channels: Mono
      Limits: 0 - 149
      Mono: 0 [0%] [-99999.99dB]
    Simple mixer control 'AUDUL Mono Mixer',0
    Simple mixer control 'AUDUL Tones',0
      Limits: 0 - 149
    Simple mixer control 'AUDUL Voice DL',0
      Limits: 0 - 149
    Simple mixer control 'AUDUL Voice UL',0
      Limits: 0 - 149
      Mono: 120 [81%] [0.00dB]
    Simple mixer control 'AUXL',0
    Simple mixer control 'AUXR',0
    Simple mixer control 'Analog Left',0
      Capabilities: cenum
      Items: 'Headset Mic' 'Main Mic' 'Aux/FM Left' 'Off'
      Item0: 'Aux/FM Left'
    Simple mixer control 'Analog Right',0
      Capabilities: cenum
      Items: 'Headset Mic' 'Sub Mic' 'Aux/FM Right' 'Off'
      Item0: 'Aux/FM Right'
    Simple mixer control 'BT UL',0
      Limits: 0 - 149
      Front Left: 120 [81%] [0.00dB]
      Front Right: 120 [81%] [0.00dB]
    Simple mixer control 'DL1 BT_VX',0
    Simple mixer control 'DL1 Capture',0
      Capabilities: pvolume pvolume-joined penum
      Limits: Playback 0 - 149
      Mono: Playback 0 [0%] [-99999.99dB]
    Simple mixer control 'DL1 Equalizer',0
      Capabilities: enum
      Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -20dB' '4Khz LPF   0dB'
    Simple mixer control 'DL1 MM_EXT',0
    Simple mixer control 'DL1 Media',0
      Mono: Playback 90 [60%] [-30.00dB]
    Simple mixer control 'DL1 Mixer Capture',0
    Simple mixer control 'DL1 Mixer Multimedia',0
      Mono: Playback [on]
    Simple mixer control 'DL1 Mixer Tones',0
    Simple mixer control 'DL1 Mixer Voice',0
    Simple mixer control 'DL1 Mono Mixer',0
    Simple mixer control 'DL1 PDM',0
      Mono: Playback [on]
    Simple mixer control 'DL1 Tones',0
    Simple mixer control 'DL1 Voice',0
    Simple mixer control 'DL2 Capture',0
    Simple mixer control 'DL2 Left Equalizer',0
      Capabilities: enum
      Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -20dB' '450Hz High-pass'
    Simple mixer control 'DL2 Media',0
    Simple mixer control 'DL2 Mixer Capture',0
    Simple mixer control 'DL2 Mixer Multimedia',0
    Simple mixer control 'DL2 Mixer Tones',0
    Simple mixer control 'DL2 Mixer Voice',0
    Simple mixer control 'DL2 Mono Mixer',0
    Simple mixer control 'DL2 Right Equalizer',0
      Capabilities: enum
    Simple mixer control 'DL2 Tones',0
    Simple mixer control 'DL2 Voice',0
    Simple mixer control 'DMIC Equalizer',0
      Capabilities: enum
    Simple mixer control 'DMIC1 UL',0
      Limits: 0 - 149
    Simple mixer control 'DMIC2 UL',0
      Limits: 0 - 149
    Simple mixer control 'DMIC3 UL',0
      Limits: 0 - 149
    Simple mixer control 'Earphone',0
      Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
      Limits: Playback 0 - 15
      Mono: Playback 0 [0%] [-24.00dB] [off]
    Simple mixer control 'Handsfree',0
      Capabilities: pvolume penum
      Limits: Playback 0 - 29
      Mono:
      Front Left: Playback 0 [0%] [-52.00dB]
      Front Right: Playback 0 [0%] [-52.00dB]
    Simple mixer control 'Handsfree Left Playback',0
      Capabilities: enum
      Items: 'Off' 'HF DAC' 'Line-In amp'
      Item0: 'Off'
    Simple mixer control 'Handsfree Right Playback',0
      Capabilities: enum
      Item0: 'Off'
    Simple mixer control 'Headset',0
      Mono:
      Front Left: Playback 13 [87%] [-4.00dB]
      Front Right: Playback 13 [87%] [-4.00dB]
    Simple mixer control 'Headset Left Playback',0
      Capabilities: enum
      Items: 'Off' 'HS DAC' 'Line-In amp'
      Item0: 'HS DAC'
    Simple mixer control 'Headset Power Mode',0
      Capabilities: enum
      Items: 'Low-Power' 'High-Perfomance'
      Item0: 'Low-Power'
    Simple mixer control 'Headset Right Playback',0
      Capabilities: enum
      Item0: 'HS DAC'
    Simple mixer control 'MUX_UL00',0
      Capabilities: enum
      Items: 'None' 'DMic0L' 'DMic0R' 'DMic1L' 'DMic1R' 'DMic2L' 'DMic2R' 'BT Left' 'BT Right' 'MMExt Left' 'MMExt Right' 'AMic0' 'AMic1' 'VX Left' 'VX Right'
      Item0: 'AMic0'
    Simple mixer control 'MUX_UL01',0
      Capabilities: enum
      Item0: 'AMic1'
    Simple mixer control 'MUX_UL02',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL03',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL04',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL05',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL06',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL07',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL10',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_UL11',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_VX0',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'MUX_VX1',0
      Capabilities: enum
      Item0: 'None'
    Simple mixer control 'PLL Selection',0
      Capabilities: enum
      Item0: 'Low-Power'
    Simple mixer control 'SDT DL',0
      Limits: 0 - 149
    Simple mixer control 'SDT UL',0
      Limits: 0 - 149
    Simple mixer control 'TWL6040 Power Mode',0
      Capabilities: enum
      Items: 'Low-Power' 'High-Performance'
      Item0: 'Low-Power'
    Simple mixer control 'VXREC Media',0
      Limits: 0 - 149
    Simple mixer control 'VXREC Tones',0
      Limits: 0 - 149
    Simple mixer control 'VXREC Voice DL',0
      Limits: 0 - 149
    Simple mixer control 'VXREC Voice UL',0
      Limits: 0 - 149
    Simple mixer control 'Vibra Left Playback',0
      Capabilities: enum
      Items: 'Input FF' 'Audio PDM'
      Item0: 'Input FF'
    Simple mixer control 'Vibra Right Playback',0
      Capabilities: enum
      Item0: 'Input FF'
    Simple mixer control 'Voice Capture Mixer Capture',0
    Simple mixer control 'Voice Capture Mixer Media Playback',0
    Simple mixer control 'Voice Capture Mixer Tones Playback',0
    Report Abuse
  • Israel Cepeda
    on Aug 03 2012 11:57 AM
    Verified Answer
    Verified by Alireza Kenarsari Anhari
    Expert5515 points
    My guess it that those values were take during playback, right?
    You have DL1 Media set to value 90 that is -30 dB, that means at this point you are attenuating the signal. You can increase this value to get higher volume.
    Also Headset controls is not at it's higher value, you may want to try with values that are not attenuating the signal.
      Mono:
    Please try increasing this values to see if you problem get solved.
    Regards!
    ICe
    Report Abuse
    on Aug 03 2012 12:07 PM
    Cheers!
    Report Abuse
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
