I have build android 4.4.2 for pandaboard.
During booting it is getting blocked
Below is the log, kindly help me
Texas Instruments Inc X-Loader 1.41.0-gdd880470 (Nov 13 2014 - 14:34:31)
OMAP4460: 1.2 GHz capable SOM
Starting OS Bootloader from MMC/SD1 ...
U-Boot 1.1.4-g622fcfe5-dirty (Nov 13 2014 - 14:37:23)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Using default environment
In: serial
Out: serial
Err: serial
Battery not detected
efi partition table:
256 128K xloader
512 256K bootloader
2048 8M recovery
18432 8M boot
34816 512M system
1083392 256M cache
1607680 1125M userdata
Net: KS8851SNL
Hit any key to stop autoboot: 0
kernel @ 80008000 (3694872)
ramdisk @ 81000000 (325549)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.31-gcb5fc50 (jbq@jqueru.mtv.corp.google.com) (2
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 Panda board
[ 0.000000] Truncating RAM at 80000000-bfffffff to -afffffff (vmalloc region.
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4460 ES1.1
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 190208
[ 0.000000] free_area_init_node: node 0, pgdat c07617a0, node_mem_map c08e100
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 188672 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c0eeb000 s6944 r8192 d13536 u32768
[ 0.000000] pcpu-alloc: s6944 r8192 d13536 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa2
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G androidboot.cy
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 512MB 231MB = 743MB total
[ 0.000000] Memory: 744388k/744388k available, 42044k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xf0800000 - 0xf8000000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0046000 ( 248 kB)
[ 0.000000] .text : 0xc0046000 - 0xc0701000 (6892 kB)
[ 0.000000] .data : 0xc0702000 - 0xc0761f80 ( 384 kB)
[ 0.000000] .bss : 0xc0761fa4 - 0xc08e0d10 (1532 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, 1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 1s
[ 0.000000] Calibrating delay loop... 1392.74 BogoMIPS (lpj=5439488)
[ 0.015686] pid_max: default: 32768 minimum: 301
[ 0.070404] Mount-cache hash table entries: 512
[ 0.071594] Initializing cgroup subsys debug
[ 0.071624] Initializing cgroup subsys cpuacct
[ 0.071624] Initializing cgroup subsys freezer
[ 0.071746] CPU: Testing write buffer coherency: ok
[ 0.071929] L310 cache controller enabled
[ 0.071929] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x5e470000, Cache sB
[ 0.150177] CPU1: Booted secondary processor
[ 0.220520] Brought up 2 CPUs
[ 0.220520] SMP: Total of 2 processors activated (2792.83 BogoMIPS).
[ 0.220764] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.224060] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_insr
[ 0.224060] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_mai1
[ 0.224090] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_mai2
[ 0.224090] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.224121] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.224121] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.224151] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.224151] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_pre
[ 0.224212] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.224212] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for thermar
[ 0.224212] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_i
[ 0.224304] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_i
[ 0.224304] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.224304] omap_hwmod: l4_div_ck: missing clockdomain for l4_div_ck.
[ 0.232696] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.235351] print_constraints: dummy:
[ 0.235351] NET: Registered protocol family 16
[ 0.235351] GPMC revision 6.0
[ 0.236938] EMIF0 is enabled with IRQ142
[ 0.237030] EMIF1 is enabled with IRQ143
[ 0.237060] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.237060]
[ 0.237213] HSI: device registered as omap_hwmod: hsi
[ 0.237396] OMAP GPIO hardware version 0.1
[ 0.238922] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.238922] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.238922] ram_console: got buffer at a0000000, size 200000
[ 0.241088] ram_console: uncorrectable error in header
[ 0.241088] ram_console: no valid data in buffer (sig = 0xaaaa8a2a)
[ 0.250000] console [ram-1] enabled
[ 0.250091] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.251281] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.262634] OMAP DMA hardware revision 0.0
[ 0.270111] bio: create slab <bio-0> at 0
[ 0.270629] print_constraints: vwl1271: 1800 mV
[ 0.271850] SCSI subsystem initialized
[ 0.271850] usbcore: registered new interface driver usbfs
[ 0.272399] usbcore: registered new interface driver hub
[ 0.272552] usbcore: registered new device driver usb
[ 0.282958] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.283813] Skipping twl internal clock init and using bootloader value (unk)
[ 0.284454] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.285980] print_constraints: VUSB: 3300 mV normal standby
[ 0.489532] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 0.490600] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal stay
[ 0.491271] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal stany
[ 0.491271] print_constraints: VCXIO: 1800 mV normal standby
[ 0.491760] print_constraints: VDAC: 1800 mV normal standby
[ 0.492706] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normy
[ 0.493377] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normy
[ 0.494476] print_constraints: CLK32KG:
[ 0.494476] print_constraints: VANA: 2100 mV normal standby
[ 0.509582] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.525146] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.540771] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 0.541412] omap-rproc omap-rproc.0: dsp is available
[ 0.541412] omap-rproc omap-rproc.1: ipu is available
[ 0.541412] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.542755] Bluetooth: Core ver 2.16
[ 0.542755] NET: Registered protocol family 31
[ 0.542755] Bluetooth: HCI device and connection manager initialized
[ 0.543151] Bluetooth: HCI socket layer initialized
[ 0.543151] Bluetooth: L2CAP socket layer initialized
[ 0.543151] Bluetooth: SCO socket layer initialized
[ 0.543975] cfg80211: Calling CRDA to update world regulatory domain
[ 0.545104] Switching to clocksource 32k_counter
[ 0.546936] musb-hdrc: version 6.0, musb-dma, peripheral
[ 0.547393] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bul)
[ 0.547454] musb-hdrc: MHDRC RTL version 2.0
[ 0.547454] musb-hdrc: setup fifo_mode 4
[ 0.547882] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.547882] musb-hdrc musb-hdrc: USB Peripheral mode controller at fc0ab000 4
[ 0.548583] Switched to NOHz mode on CPU #0
[ 0.548645] Switched to NOHz mode on CPU #1
[ 0.548675] NET: Registered protocol family 2
[ 0.548675] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.549407] TCP established hash table entries: 131072 (order: 8, 1048576 by)
[ 0.552795] TCP bind hash table entries: 65536 (order: 8, 1572864 bytes)
[ 0.555755] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.555938] TCP reno registered
[ 0.555938] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.555938] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.556976] NET: Registered protocol family 1
[ 0.556976] Trying to unpack rootfs image as initramfs...
[ 0.583831] Freeing initrd memory: 316K
[ 1.718414] omap-iommu omap-iommu.0: ducati registered
[ 1.718414] omap-iommu omap-iommu.1: tesla registered
[ 1.726806] ashmem: initialized
[ 1.734771] fuse init (API version 7.16)
[ 1.735321] msgmni has been set to 1454
[ 1.737182] io scheduler noop registered
[ 1.737365] io scheduler deadline registered
[ 1.737365] io scheduler cfq registered (default)
[ 1.737365] start plist test
[ 1.740600] end plist test
[ 1.745361] OMAP DSS rev 4.0
[ 1.753295] dsscomp: initializing.
[ 1.753784] misc dsscomp: display0=generic_dpi_panel
[ 1.753784] misc dsscomp: display1=hdmi_panel
[ 1.754058] misc dsscomp: found 2 displays and 4 overlays
[ 1.754638] could not allocate slot
[ 1.755035] omap-rproc omap-rproc.1: powering up ipu
[ 1.755462] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfy
[ 1.756195] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfy
[ 1.756774] rpmsg_virtio TX: 28 00 00 00 64 00 00 00 35 00 00 00 00 00 00 00.
[ 1.756958] rpmsg_virtio TX: 72 70 6d 73 67 2d 72 65 73 6d 67 72 00 00 00 00.
[ 1.756958] rpmsg_virtio TX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
[ 1.757171] rpmsg_virtio TX: 64 00 00 00 00 00 00 00 .
[ 1.757171] rpmsg_virtio TX: 28 00 00 00 64 00 00 00 35 00 00 00 00 00 00 00.
[ 1.757171] rpmsg_virtio TX: 72 70 6d 73 67 2d 72 65 73 6d 67 72 00 00 00 00.
[ 1.757598] rpmsg_virtio TX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
[ 1.757598] rpmsg_virtio TX: 64 00 00 00 00 00 00 00 .
[ 1.758026] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.795349] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.834411] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.900024] console [ttyO2] enabled
[ 2.967163] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 3.100097] PVR: PVRCore_Init
[ 3.103668] PVR: PVRSRVDriverProbe(pDevice=ee4ade00)
[ 3.109375] PVR: SGX register base: 0x56000000
[ 3.114349] PVR: SGX register size: 65535
[ 3.118835] PVR: SGX IRQ: 53
[ 3.118927] PVR: EnableSystemClocks: Enabling System Clocks
[ 3.128387] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency ]
[ 3.141479] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency ]
[ 3.154510] PVR: PVRCore_Init: major device 251
[ 3.165222] brd: module loaded
[ 3.174072] loop: module loaded
[ 3.174072] (stk) :sysfs entries created
[ 3.182128] (stk) : debugfs entries created
[ 3.186859] (hci_tty): inside hci_tty_init
[ 3.191772] (hci_tty): allocated 250, 0
[ 3.198760] omap_temp_sensor omap_temp_sensor.0: omap_temp_sensor probed
[ 3.209320] PPP generic driver version 2.4.2
[ 3.214538] PPP Deflate Compression module registered
[ 3.220245] PPP BSD Compression module registered
[ 3.226348] PPP MPPE Compression module registered
[ 3.226348] NET: Registered protocol family 24
[ 3.236816] usbcore: registered new interface driver asix
[ 3.244995] usbcore: registered new interface driver cdc_ether
[ 3.251525] usbcore: registered new interface driver smsc95xx
[ 3.257965] usbcore: registered new interface driver net1080
[ 3.260803] usbcore: registered new interface driver cdc_subset
[ 3.270996] usbcore: registered new interface driver zaurus
[ 3.277282] cdc_ncm: 04-Aug-2011
[ 3.280914] usbcore: registered new interface driver cdc_ncm
[ 3.287384] usbcore: registered new interface driver zd1201
[ 3.289123] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.301086] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.307525] ehci-omap ehci-omap.0: new USB bus registered, assigned bus numb1
[ 3.315765] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 3.334381] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.340820] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.348388] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 3.348388] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.362365] usb usb1: Manufacturer: Linux 3.0.31-gcb5fc50 ehci_hcd
[ 3.369201] usb usb1: SerialNumber: ehci-omap.0
[ 3.369201] hub 1-0:1.0: USB hub found
[ 3.379089] hub 1-0:1.0: 3 ports detected
[ 3.412475] usbcore: registered new interface driver cdc_acm
[ 3.418945] cdc_acm: USB Abstract Control Model driver for USB modems and ISs
[ 3.427856] Initializing USB Mass Storage driver...
[ 3.433258] usbcore: registered new interface driver usb-storage
[ 3.440124] USB Mass Storage support registered.
[ 3.445465] usbcore: registered new interface driver usbserial
[ 3.451995] usbserial: USB Serial Driver core
[ 3.456878] USB Serial support registered for Keyspan - (without firmware)
[ 3.464569] USB Serial support registered for Keyspan 1 port adapter
[ 3.471679] USB Serial support registered for Keyspan 2 port adapter
[ 3.478759] USB Serial support registered for Keyspan 4 port adapter
[ 3.478851] usbcore: registered new interface driver keyspan
[ 3.492279] keyspan: v1.1.5:Keyspan USB to Serial Converter Driver
[ 3.500823] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.508544] android_usb gadget: Number of LUNs=1
[ 3.508544] lun0: LUN: removable file: (no medium)
[ 3.519500] android_usb gadget: android_usb ready
[ 3.524993] mousedev: PS/2 mouse device common for all mice
[ 3.531463] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.540069] i2c /dev entries driver
[ 3.540069] lirc_dev: IR Remote Control driver registered, major 248
[ 3.551757] IR NEC protocol handler initialized
[ 3.551757] IR RC5(x) protocol handler initialized
[ 3.562194] IR RC6 protocol handler initialized
[ 3.567230] IR JVC protocol handler initialized
[ 3.572326] IR Sony protocol handler initialized
[ 3.577484] IR RC5 (streamzap) protocol handler initialized
[ 3.583709] IR LIRC bridge handler initialized
[ 3.588745] dmm: probe base: fd300000, irq 145
[ 3.588745] device-mapper: uevent: version 1.0.3
[ 3.596343] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-m
[ 3.611328] Bluetooth: HCI UART driver ver 2.2
[ 3.616394] Bluetooth: HCI H4 protocol initialized
[ 3.621704] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 3.630004] (stc): st_register(2)
[ 3.630126] cpuidle: using governor ladder
[ 3.630126] cpuidle: using governor menu
[ 3.642883] (stc): chnl_id list empty :2
[ 3.647277] (stk) : st_kim_start
[ 3.653900] usbcore: registered new interface driver usbhid
[ 3.661071] usbhid: USB HID core driver
[ 3.681549] logger: created 256K log 'log_main'
[ 3.687591] logger: created 256K log 'log_events'
[ 3.687591] logger: created 256K log 'log_radio'
[ 3.698242] logger: created 256K log 'log_system'
[ 3.704437] OMAP HSI: HSI DRIVER Version 0.4.1
[ 3.709381] omap_hsi omap_hsi.0: Registering IRQ mpu_p1 (99)
[ 3.715911] omap_hsi omap_hsi.0: Registering IRQ mpu_dma (103)
[ 3.723510] omap_hsi omap_hsi.0: HSI Hardware REVISION 0x50043101
[ 3.739440] SDP4430 SoC init
[ 3.748596] usb 1-1: new high speed USB device number 2 using ehci-omap
[ 3.757781] (stk) :ldisc_install = 1
[ 3.783172] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 3.791229] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 3.798400] asoc: null-codec-dai <-> Voice mapping ok
[ 3.805511] asoc: null-codec-dai <-> Tones mapping ok
[ 3.812957] asoc: null-codec-dai <-> Vibra mapping ok
[ 3.819366] asoc: null-codec-dai <-> MODEM mapping ok
[ 3.825775] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 3.833740] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.841217] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 3.848693] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Steree
[ 3.858886] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 3.865417] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 3.871856] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 3.878326] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 3.884948] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.891754] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.898803] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.905029] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.905029] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.905517] hub 1-1:1.0: USB hub found
[ 3.905883] hub 1-1:1.0: 5 ports detected
[ 3.929656] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 3.937194] input: Panda Headset Jack as /devices/platform/soc-audio/sound/c1
[ 3.948822] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 3.955963] ALSA device list:
[ 3.959259] #0: TI OMAP4 Board
[ 3.959259] #1: OMAP4HDMI
[ 3.966003] GACT probability NOT on
[ 3.970031] Mirror/redirect action on
[ 3.970031] u32 classifier
[ 3.977172] Actions configured
[ 3.979644] Netfilter messages via NETLINK v0.30.
[ 3.986206] nf_conntrack version 0.5.0 (11636 buckets, 46544 max)
[ 3.989532] mmc0: host does not support reading read-only switch. assuming w.
[ 3.989624] mmc0: new SD card at address 0002
[ 3.990112] mmcblk0: mmc0:0002 00000 1.86 GiB
[ 4.011352] Alternate GPT is invalid, using primary GPT.
[ 4.011413] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 4.022521] ctnetlink v0.93: registering with nfnetlink.
[ 4.029327] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.037017] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 4.039825] xt_time: kernel timezone is -0000
[ 4.048919] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.056823] arp_tables: (C) 2002 David S. Miller
[ 4.062255] TCP cubic registered
[ 4.066223] NET: Registered protocol family 10
[ 4.071685] Mobile IPv6
[ 4.071685] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.086303] IPv6 over IPv4 tunneling driver
[ 4.093811] NET: Registered protocol family 17
[ 4.102600] NET: Registered protocol family 15
[ 4.107757] Bluetooth: RFCOMM TTY layer initialized
[ 4.113189] Bluetooth: RFCOMM socket layer initialized
[ 4.118896] Bluetooth: RFCOMM ver 1.11
[ 4.123107] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.128936] NET: Registered protocol family 35
[ 4.133941] lib80211: common routines for IEEE802.11 drivers
[ 4.137176] mmc1: card claims to support voltages below the defined range. T.
[ 4.150390] lib80211_crypt: registered algorithm 'NULL'
[ 4.156158] VFP support v0.3:
[ 4.156219] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.157684] mmc1: new SDIO card at address 0001
[ 4.170715] implementor 41 architecture 3 part 30 variant 9 rev 4
[ 4.177459] ThumbEE CPU extension supported.
[ 4.182159] Registering SWP/SWPB emulation handler
[ 4.194671] Reprogramming LPDDR2 timings to 400000000 Hz
[ 4.201507] Power Management for TI OMAP4.
[ 4.207122] OMAP4 PM: Static dependency added between MPUSS and DUCATI <-> L.
[ 4.209716] usb 1-1.1: new high speed USB device number 3 using ehci-omap
[ 4.224945] sr_init: No PMIC hook to init smartreflex
[ 4.229278] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver inid
[ 4.239837] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver inid
[ 4.248809] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver inid
[ 4.258209] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 4.273834] clock: disabling unused clocks to save power
[ 4.281860] sr_class1p5_calib_work: iva: Calibration complete: Voltage:Nomin0
[ 4.294372] sr_class1p5_calib_work: core: Calibration complete: Voltage:Nomi0
[ 4.305847] sr_class1p5_calib_work: mpu: Calibration complete: Voltage:Nomin0
[ 4.330627] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.349945] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumbe0
[ 4.360382] smsc95xx v1.0.4
[ 4.465087] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.05
[ 4.734283] sr_class1p5_calib_work: core: Calibration complete: Voltage:Nomi0
[ 4.850738] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=102508
[ 4.860046] sr_class1p5_calib_work: mpu: Calibration complete: Voltage:Nomin0
[ 4.880126] cannot apply mgr(lcd) on inactive device
[ 4.886505] omapfb omapfb: failed to apply dispc config
[ 4.896209] cannot apply mgr(tv) on inactive device
[ 4.902069] omapfb omapfb: failed to apply dispc config
[ 4.910980] cannot apply mgr(lcd2) on inactive device
[ 4.912475] (stk) :ldisc installation timeout
[ 4.912475] (stk) :ldisc_install = 0
[ 4.925811] sr_class1p5_calib_work: mpu: Calibration complete: Voltage:Nomin0
[ 4.937500] omapfb omapfb: failed to apply dispc config
[ 4.946563] omapdss DPI: Could not find exact pixel clock. Requested 74250 kz
[ 4.958831] regulator_init_complete: VANA: incomplete constraints, leaving on
[ 4.968048] regulator_init_complete: VDAC: incomplete constraints, leaving on
[ 4.976623] regulator_init_complete: VCXIO: incomplete constraints, leaving n
[ 4.985382] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.993103] Freeing init memory: 248K
[ 5.882049] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_.
[ 5.996704] init: /dev/hw_random not found
[ 6.001617] keychord: using input dev gpio-keys for fevent
[ 6.074829] (stk) : timed out waiting for ldisc to be un-installed
[ 6.116363] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. )
[ 6.173400] wl1271: loaded
[ 6.179870] wl1271: initialized
[ 6.192169] (stk) :ldisc_install = 1
[ 6.263824] EXT4-fs (mmcblk0p6): recovery complete
[ 6.274841] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. c
[ 6.632965] sr_class1p5_calib_work: mpu: Calibration complete: Voltage:Nomin0
[ 7.350280] (stk) :ldisc installation timeout
[ 7.351989] (stk) :ldisc_install = 0
[ 7.660247] EXT4-fs (mmcblk0p7): recovery complete
[ 7.674591] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. c
[ 7.721374] init: /dev/hw_random not found
[ 7.758575] healthd: wakealarm_init: timerfd_create failed
[ 7.768676] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[ 7.772247] healthd: No charger supplies found
[ 7.773345] healthd: BatteryStatusPath not found
[ 7.773345] healthd: BatteryHealthPath not found
[ 7.773376] healthd: BatteryPresentPath not found
[ 7.773376] healthd: BatteryCapacityPath not found
[ 7.773376] healthd: BatteryVoltagePath not found
[ 7.773406] healthd: BatteryTemperaturePath not found
[ 7.773406] healthd: BatteryTechnologyPath not found
[ 7.773406] binder: 94:94 transaction failed 29189, size 0-0
[ 7.827545] omap-rproc omap-rproc.1: rproc_loader_cont: failed to load ducatn
[ 7.830963] init: cannot find '/system/etc/install-recovery.sh', disabling ''
[ 7.838684] init: property 'sys.powerctl' doesn't exist while expanding '${s'
[ 7.838684] init: powerctl: cannot expand '${sys.powerctl}'
[ 7.838684] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist whil'
[ 7.838745] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writ'
[ 7.839111] android_usb: already disabled
[ 7.858367] adb_open
[ 7.858367] adb_bind_config
shell@panda:/ $ [ 8.469055] PVR: Installing MISR with cookie c07d674c
[ 8.475341] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie ee496f0
[ 8.483520] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from f0b20000
[ 8.492248] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[ 8.520202] (stk) : timed out waiting for ldisc to be un-installed
[ 8.634552] (stk) :ldisc_install = 1
[ 8.695373] (stc): st_tty_open
[ 8.699371] (stk) :line discipline installed
[ 8.705657] (stk) :TIInit_7.6.15.bts
[ 9.196014] (stc): add_channel_to_table: id 2
[ 9.196014] (stc): st_register(3)
[ 9.205169] (stc): add_channel_to_table: id 3
[ 9.212066] (stc): st_register(4)
[ 9.216491] (stc): add_channel_to_table: id 4
[ 11.275177] (stc): remove_channel_from_table: id 2
[ 11.280914] (stc): remove_channel_from_table: id 3
[ 11.286529] (stc): remove_channel_from_table: id 4
[ 11.293518] (stc): all chnl_ids unregistered
[ 11.298919] (stk) :ldisc_install = 0
[ 11.307342] (stc): st_tty_close
[ 11.311706] (stc): 2 not un-registered
[ 11.316192] (stc): 3 not un-registered
[ 11.320709] (stc): 4 not un-registered
[ 11.474395] misc dsscomp: [ed8ee800] ignoring set failure -22
[ 25.267913] warning: `zygote' uses 32-bit capabilities (legacy support in us)
[ 25.319793] alarm_set_rtc: no RTC, time will be lost on reboot
[ 31.331542] healthd: battery l=0 v=0 t=0.0 h=1 st=1 chg=
[ 31.350646] request_suspend_state: wakeup (3->0) at 31344482424 (1970-01-02 )
[ 33.161315] acc_open
[ 33.163940] acc_release
[ 40.477935] init: sys_prop: permission denied uid:1003 name:service.bootanit
[ 43.037414] eth0: no IPv6 routers present
[ 51.176635] request_suspend_state: sleep (0->3) at 51170471193 (1970-01-02 0)
[ 51.188385] DSSCOMP: dsscomp_early_suspend
[ 51.207153] DSSCOMP: blanked screen
[ 104.450958] binder: release 829:829 transaction 6395 out, still active
With Regards,
Santosh Kumar B.
