Ducati and DCC files
I am working on a product based on OMAP4460 processor, 4AJ.2.2 code release.
We have successfully implemented a driver for our custom camera following the existing examples.
It works. Ducati binary loads properly and I am able to record video and see a preview.
My problem is with DCC files.
1) Understanding exactly what they are used for. What they are responsible for.
2) How they are generated - how I can generate my own.
Actually, I came across this while trying to change the maximal frame rate. While sensor/driver supports upto 60fps, Ducati reports only up to 24fps. Right now I don't have any DCC files, so I guess it uses default values.
Can anyone please point me in the right direction? Documentation or example would be appreciated.
Thanks in advance.
  • DCC is Dynamic Camera Calibration. These file include ISP parameters which Ducati applies according to changing light conditions. Generating these files is a complex process and needs some specialized tool. For more details you must contact your TI representative.
  • About DCC files
    DCC is a Dynamic Camera Configuration/Calibration. DCC tool is a Image quality tuning tool, ISP module is tuned as per the requirement by using this tool.
    [Answer]: DCC files contains parameters for complete ISP modules. They are used for loading different set of ISP parameters. And responsible for changing the image quality as per the requirement.
    [Answer]: DCC files are generated by using DCC tool. Yes can also generate yourself by using this tool with the help of user guide.
    Gajanan Ambi
