I am trying to install GLSDK 6.04 on Ubuntu 12.04. I am facing issues while building Yocto filesystem. Any help would be appreciated.
command:
./build-core-sdk.sh dra7xx-evm
log:
DEBUG: Mirror fetch failure for url http://sources.openembedded.org/git2_git.omapzoom.org.kernel.omap.git.tar.gz (original url: git://git.omapzoom.org/kernel/omap.git;protocol=git;branch=p-ti-glsdk-3.8.y)
DEBUG: Fetcher failure: Fetch command failed with exit code 8, output:
http://sources.openembedded.org/git2_git.omapzoom.org.kernel.omap.git.tar.gz:
2014-07-15 14:04:19 ERROR 404: Not Found.
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/downloads/git2/git.omapzoom.org.kernel.omap.git'...
fatal: read error: Network is unreachable
fatal: early EOF
fatal: index-pack failed
DEBUG: Python function base_do_fetch finished
DEBUG: Python function do_fetch finished
ERROR: Function failed: Fetcher failure for URL: 'git://git.omapzoom.org/kernel/omap.git;protocol=git;branch=p-ti-glsdk-3.8.y'. Unable to fetch URL from any source.
I am not able to build specific recipes also:
./build-specific-recipe.sh dra7xx-evm omapdrmtest
[GLSDK]>
[GLSDK]> Current Directory is /opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers
[GLSDK]> PATH is /opt/platform/dra7xx/toolchain1/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
[GLSDK]> Building on vmubn-is0637 running Linux vmubn-is0637 3.2.0-23-generic-pae #36-Ubuntu SMP Tue Apr 10 22:19:09 UTC 2012 i686 i686 i386 GNU/Linux
[GLSDK]> Starting Yocto build at Wed Jul 16 19:14:14 IST 2014
[GLSDK]>
[GLSDK]> cd build
[GLSDK]> cp conf/local.conf conf/local.conf.pristine
[GLSDK]> echo ARAGO_BRAND = "glsdk" >> conf/local.conf
[GLSDK]> . conf/setenv
[GLSDK]> MACHINE=dra7xx-evm bitbake omapdrmtest
Loading cache: 100% |###################################################################################| ETA: 00:00:00
Loaded 2020 entries from dependency cache.
Parsing recipes: 100% |#################################################################################| Time: 00:00:17
Parsing of 1638 .bb files complete (1634 cached, 4 parsed). 2023 targets, 98 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/meta-qt5/recipes-devtools/cmake/cmake_2.8.12.1.bbappend
/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-connectivity/inetutils/inetutils_1.8.bbappend
Build Configuration:
BB_VERSION = "1.18.0"
BUILD_SYS = "i686-linux"
NATIVELSBSTRING = "Ubuntu-12.04"
TARGET_SYS = "arm-oe-linux-gnueabi"
MACHINE = "dra7xx-evm"
DISTRO = "arago"
DISTRO_VERSION = "2013.10"
TUNE_FEATURES = "armv7a vfp thumb neon callconvention-hard cortexa15"
TARGET_FPU = "vfp-neon"
meta-arago-distro
meta-arago-extras = "(nobranch):283813dffe8633af04c87faedb4c601518fa3a9c"
meta-qt5 = "(nobranch):775d77e482f1ea203c78003cccd2547075fd720f"
toolchain-layer
meta-networking
meta-ruby
meta-oe = "(nobranch):44754206632dd5b0725aeb43e99e4ff9e0245dca"
meta-ti = "(nobranch):96fae48172519a621bb38c875a0b0e89a198868c"
meta-linaro-toolchain = "(nobranch):c9f78d6eff14ada3f2bc960e81883b27a10afecc"
meta = "(nobranch):394fa61d00b97c19610bfb38f02174c4e8aeeb15"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: Fetcher failure: Fetch command failed with exit code 128, output:
fatal: repository '/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/downloads/git2/git.omapzoom.org.kernel.omap.git/' does not exist
ERROR: Logfile of failure stored in: /opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-oe-linux-gnueabi/linux-ti-glsdk/3.8.13-r2d+gitrAUTOINC+2c871a879dbb4234232126f7075468d5bf0a50e3-arago0/temp/log.do_unpack.18959
Log data follows:
| DEBUG: Executing python function do_unpack
| DEBUG: Executing python function base_do_unpack
| DEBUG: Running export PATH="/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/oe-core/scripts:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/i686-linux/usr/bin/cortexa15hf-vfp-neon-oe-linux-gnueabi:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/bin/crossscripts:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/i686-linux/usr/sbin:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/i686-linux/usr/bin:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/i686-linux/sbin:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/i686-linux//bin:/opt/platform/dra7xx/toolchain1/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/oe-core/scripts:/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/bitbake/bin:/opt/platform/dra7xx/toolchain1/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"; export HOME="/home/ittiam"; git clone -s -n /opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/downloads/git2/git.omapzoom.org.kernel.omap.git/ /opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-oe-linux-gnueabi/linux-ti-glsdk/3.8.13-r2d+gitrAUTOINC+2c871a879dbb4234232126f7075468d5bf0a50e3-arago0/git/
| DEBUG: Python function base_do_unpack finished
| DEBUG: Python function do_unpack finished
ERROR: Task 962 (/opt/platform/dra7xx/sdk/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/meta-ti/recipes-kernel/linux/linux-ti-glsdk_3.8.bb, do_unpack) failed with exit code '1'
NOTE: Tasks Summary: Attempted 613 tasks of which 611 didn't need to be rerun and 1 failed.
No currently running tasks (613 of 1510)
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[GLSDK]>
[GLSDK]> Completed Yocto build at Thu Jul 17 03:02:32 IST 2014
[GLSDK]>
Thanks in advance.
