SDK: ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-installer.bin
procedure:
export PATH=xxxxxx:$PATH
cd $GLSDK
./bin/setup-yocto.sh
cd yocto-layers
mkdir downloads
./build-core-sdk.sh dra7xx-evm
Error log:
ERROR: Function failed: do_compile (see /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/temp/log.do_compile.31139 for further information)
ERROR: Logfile of failure stored in: /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/temp/log.do_compile.31139
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4
| make all-recursive
| make[1]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git'
| Making all in shared
| make[2]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/shared'
| make[2]: Nothing to be done for `all'.
| make[2]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/shared'
| Making all in src
| make[2]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| GEN git-version.h
| make all-recursive
| make[3]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| Making all in xwayland
| make[4]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/xwayland'
| make all-am
| make[5]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/xwayland'
| make[5]: Nothing to be done for `all-am'.
| make[5]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/xwayland'
| make[4]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/xwayland'
| make[4]: Entering directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| GEN git-version.h
| CCLD weston-launch
| CCLD spring-tool
| spring_tool-animation.o: In function `weston_surface_animation_destroy':
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/animation.c:135: undefined reference to `wl_list_remove'
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/animation.c:136: undefined reference to `wl_list_remove'
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/animation.c:137: undefined reference to `wl_list_remove'
| spring_tool-animation.o: In function `weston_surface_animation_run':
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/animation.c:203: undefined reference to `wl_list_insert'
| spring_tool-animation.o: In function `wl_signal_add':
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/include/wayland-server.h:223: undefined reference to `wl_list_insert'
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/animation.c:214: undefined reference to `wl_list_insert'
| collect2: error: ld returned 1 exit status
| make[4]: *** [spring-tool] Error 1
| make[4]: *** Waiting for unfinished jobs....
| weston_launch-weston-launch.o: In function `handle_signal':
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/weston-launch.c:452: undefined reference to `drmSetMaster'
| /media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src/weston-launch.c:447: undefined reference to `drmDropMaster'
| make[4]: *** [weston-launch] Error 1
| make[4]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| make[3]: *** [all-recursive] Error 1
| make[3]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| make[2]: *** [all] Error 2
| make[2]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git/src'
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory `/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/weston/1.3.0-r3/git'
| make: *** [all] Error 2
| ERROR: oe_runmake failed
ERROR: Task 5 (/media/source_codes/jacinto/GLSDK_6_04_00_02/ti-glsdk_dra7xx-evm_6_04_00_02_linux-x64-install/ti-glsdk_dra7xx-evm_6_04_00_02/yocto-layers/sources/meta-ti/recipes-graphics/weston/weston_1.3.0.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1035 tasks of which 1034 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[GLSDK]>
[GLSDK]> Completed Yocto build at Wed Sep 17 17:00:54 HKT 2014
[GLSDK]>
kevin$
why "undefined reference to `wl_list_insert'" .......... ?
where can i get the library?
