Im trying to set dev environment of GLSDK ver 6.4.0.2 according to http://downloads.ti.com/dsps/dsps_public_sw/glsdk/6_04_00_02/exports/OMAP5_GLSDK_Software_Developers_Guide.html
up to the building of the Yocto, everything works fine.
when issuing ./build-core-sdk.sh omap5-evm command, im getting the following warning and then error which stops the build (refer to BLOCK 1)
later, found on the internet to set $ARCH to arm, when doing it, im getting other error (refer to BLOCK 2)
i saw at the end the 32 /64 issue but im working on 64 bit ubuntu and according to the software developer guide i dont need to change anything.
Will appreciate any advise
BLOCK 1
In which directory do you want to place the downloads for the Yocto build ?(if this directory does not exist it will be created)
Ensure that complete path is provided.
[ /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/downloads ]
[GLSDK]> MACHINE=omap5-evm bitbake arago-glsdk-multimedia-image
Pseudo is not present but is required, building this first before the main build
WARNING: Unable to get checksum for ti-compat-wireless-wl18xx SRC_URI entry 0001-wl12xx-additional-two-members-for-wl12xx_platform_da.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0001-Add-linux-oe-g-platform.patch: file could not be found 00:03:05
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0002-qlibraryinfo-allow-to-set-qt.conf-from-the-outside-u.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0003-Add-external-hostbindir-option.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0004-qt_functions-temporary-remove-isEmpty-check.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0006-Allow-building-a-separate-qmake-for-the-target.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0007-configureapp-Prefix-default-LIBDIRS-and-INCDIRS-with.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0008-qt_module-Fix-pkgconfig-replacement.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0009-qt_module-Fix-paths-in-.prl-files.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0011-configure-don-t-export-SYSTEM_VARIABLES-to-.qmake.va.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0012-configure.prf-Allow-to-add-extra-arguments-to-make.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0013-Disable-mkv8snapshot.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0014-enables-tslib-device-to-be-read-from-env-variable.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0015-qtbase-allow-build-of-examples.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0021-configure-make-pulseaudio-a-configurable-option.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0022-configure-make-alsa-a-configurable-option.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0023-configure-make-freetype-a-configurable-option.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0024-Use-OE_QMAKE_PATH_EXTERNAL_HOST_BINS-to-determine-pa.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0001-Always-build-uic.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0001-configure-preserve-built-qmake-and-swap-with-native-.patch: file could not be found
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0001-configure-bump-path-length-from-256-to-512-character.patch: file could not be found
NOTE: Error during finalise of /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/oe-core/meta/recipes-rt/images/core-image-rt.bb | ETA: 00:01:28
ERROR: ExpansionError during parsing /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/oe-core/meta/recipes-rt/images/core-image-rt.bb: Failure expanding variable toolchain_create_sdk_version: ExpansionError: Failure expanding variable METADATA_REVISION, expression was ${@base_detect_revision(d)} which triggered exception OSError: [Errno 12] Cannot allocate memory
NOTE: Error during finalise of /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/oe-core/meta/recipes-rt/images/core-image-rt-sdk.bb
ERROR: Command execution failed: Exited with 1
Summary: There were 21 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
[GLSDK]>
[GLSDK]> Completed Yocto build at Sun Nov 23 11:51:08 PST 2014
[GLSDK]>
dev@ubuntu:~/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers$
BLOCK 2
[GLSDK]> cp conf/local.conf conf/local.conf.pristine
[GLSDK]> echo ARAGO_BRAND = "glsdk" >> conf/local.conf
Loading cache: 100% |########################################################################################################################################################################| ETA: 00:00:00
Loaded 1195 entries from dependency cache.
WARNING: Unable to get checksum for nativesdk-qtbase SRC_URI entry 0001-Add-linux-oe-g-platform.patch: file could not be found | ETA: 00:01:16
Parsing recipes: 100% |######################################################################################################################################################################| Time: 00:01:49
Parsing of 1638 .bb files complete (901 cached, 737 parsed). 2023 targets, 103 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/meta-qt5/recipes-devtools/cmake/cmake_2.8.12.1.bbappend
/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-connectivity/inetutils/inetutils_1.8.bbappend
Build Configuration:
BB_VERSION = "1.18.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-12.04"
TARGET_SYS = "arm-oe-linux-gnueabi"
MACHINE = "omap5-evm"
DISTRO = "arago"
DISTRO_VERSION = "2013.10"
TUNE_FEATURES = "armv7a vfp thumb neon callconvention-hard cortexa15"
TARGET_FPU = "vfp-neon"
meta-arago-distro
meta-arago-extras = "(nobranch):283813dffe8633af04c87faedb4c601518fa3a9c"
meta-qt5 = "(nobranch):775d77e482f1ea203c78003cccd2547075fd720f"
toolchain-layer
meta-networking
meta-ruby
meta-oe = "(nobranch):44754206632dd5b0725aeb43e99e4ff9e0245dca"
meta-ti = "(nobranch):2a3aa0fedbcf5419af60cb97f01d15c1acdedd03"
meta-linaro-toolchain = "(nobranch):c9f78d6eff14ada3f2bc960e81883b27a10afecc"
meta = "(nobranch):394fa61d00b97c19610bfb38f02174c4e8aeeb15"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_compile (see /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/pseudo-native/1.5.1-r3/temp/log.do_compile.53447 for further information)
ERROR: Logfile of failure stored in: /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/pseudo-native/1.5.1-r3/temp/log.do_compile.53447
Log data follows:
| DEBUG: Executing shell function do_compile
| WARNING: Can't find stubs-32.h, but usually need it to build 32-bit libpseudo.
| If the build fails, install 32-bit developer packages.
| If you are using 32-bit binaries, the 32-bit libpseudo is NOT optional.
| make: *** No rule to make target `distclean'. Stop.
| WARNING: Guessing architecture CFLAGS '-m32'.
| If you need specific flags, use --cflags.
| SQLite header for version 3007015 found in /home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr.
| Enabling in-memory database by default.
| NOTE: make -j 1 -e MAKEFLAGS= libpseudo
| mkdir -p lib/pseudo/lib
| ./makewrappers
| Checking for old/new clone mechanics...New clone.
| common
| ports/common/wrapfuncs.in: .......
| linux
| ports/linux/wrapfuncs.in: ................................................................
| unix
| ports/unix/wrapfuncs.in: ................................................................
| uids_generic
| ports/uids_generic/wrapfuncs.in: ........................
| linux/newclone
| ports/linux/newclone/wrapfuncs.in: .
| Writing functions... Warning: lchown from linux overriding unix
| done. Cleaning up.
| ./maketables enums/*.in
| enums/msg_type.in: type: msg_type_t (prefix 'PSEUDO_MSG_ENUM')
| ping shutdown op ack
| nak fastop
| enums/op.in: type: op_t (prefix 'OP_ENUM')
| extra column: int wait (default 0)
| chdir chmod chown chroot
| close creat dup fchmod
| fchown fstat link mkdir
| mknod open rename stat
| unlink symlink exec may-unlink
| did-unlink cancel-unlink
| enums/query_field.in: type: query_field_t (prefix 'PSQF_ENUM')
| access client dev fd
| ftype gid id inode
| mode op order path
| perm program result severity
| stamp tag text type
| uid
| enums/query_type.in: type: query_type_t (prefix 'PSQT_ENUM')
| extra column: const char * sql (default "LITTLE BOBBY TABLES")
| exact less greater bitand
| notequal like notlike sqlpat
| enums/res.in: type: res_t (prefix 'RESULT_ENUM')
| succeed fail error
| enums/sev.in: type: sev_t (prefix 'SEVERITY_ENUM')
| debug info warn error
| critical
| Writing datatypes... done. Cleaning up.
| gcc -fno-strict-aliasing -isystem/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/include -O2 -pipe -pipe -std=gnu99 -Wall -W -Wextra -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -m32 -DPSEUDO_PREFIX='"/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib/pseudo/lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.5.1"' -DUSE_MEMORY_DB -DPSEUDO_FORCE_ASYNC -O2 -g -L/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib -I/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/include -D_GNU_SOURCE -c -o pseudo_wrappers.o pseudo_wrappers.c
| In file included from /usr/include/assert.h:37:0,
| from pseudo_wrappers.c:20:
| /usr/include/features.h:324:26: fatal error: bits/predefs.h: No such file or directory
| compilation terminated.
| make: *** [pseudo_wrappers.o] Error 1
| ERROR: oe_runmake failed
ERROR: Task 7 (virtual:native:/home/dev/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers/sources/oe-core/meta/recipes-devtools/pseudo/pseudo_1.5.1.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 70 tasks of which 0 didn't need to be rerun and 1 failed.
No currently running tasks (70 of 72)
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[GLSDK]>
[GLSDK]> Completed Yocto build at Sun Nov 23 12:00:57 PST 2014
[GLSDK]>
dev@ubuntu:~/ti-glsdk_omap5-uevm_6_04_00_02/yocto-layers$ echo $ARCH
arm
