I am using omap5432 UEVM with Android(Panda5AJ.1.5, http://omapedia.org/wiki/Panda5AJ.1.5_Release_Notes), it can not boot normally and keep rebooting all the time. Hope someone can help me!
The following is the booting log.
Texas Instruments Inc Bootloader 1.1.0-g33af7cb4-dirty
Build Info: Nov 20 2014 - 10:42:30
OMAP reset reason PRM_RSTST = 0x0001
PMIC reset reason SWOFF_STATUS = 0x00
sram: boot device: EMMC
kernel @ 80008000 (4897496)
ramdisk @ 81000000 (184195)
Device Serial Number: 2E6604F01CA80121
booting kernel...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.4.34-01535-g499e8d5-dirty (root@sszcwpt2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1
SMP PREEMPT Thu Dec 11 15:21:28 CST 2014
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: OMAP5 panda board
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Cannot detect omap type!
[ 0.000000] Reserving 20971520 bytes SDRAM for VRAM
[ 0.000000] cma: CMA: reserved 16 MiB at 93000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4: Map 0x9fe00000 to 0xfe600000 for dram barrier
[ 0.000000] On node 0 totalpages: 166912
[ 0.000000] free_area_init_node: node 0, pgdat c09efe40, node_mem_map c102d000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 82432 pages, LIFO batch:15
[ 0.000000] HighMem zone: 1024 pages used for memmap
[ 0.000000] HighMem zone: 82432 pages, LIFO batch:15
[ 0.000000] OMAP5432 ES2.0
[ 0.000000] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 0.000000] FIXME: omap5 opp layer init
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1834000 s13056 r8192 d15616 u36864
[ 0.000000] pcpu-alloc: s13056 r8192 d15616 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 164864
[ 0.000000] Kernel command line: console=ttyO2,115200n8 androidboot.console=ttyO2 omap_wdt.timer_margin=30 vmalloc=496M
omapfb.fb_opt=-1,-1,-1,1,1280,720 no_console_suspend=1 console=ttyO2,115200n8 androidboot.console=ttyO2 omap_wdt.timer_margin=30
vmalloc=496M omapfb.fb_opt=-1,-1,-1,1,1920,1080 console=ttyO2,115200n8 mem=1024M androidboot.console=ttyO2 vram=20M
omapfb.vram=0:16M earlyprintk loglevel=8 earlyprintk androidboot.serialno=2E6604F01CA80121 androidboot.bootloader=Texas
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 324MB 2MB 323MB 3MB = 652MB total
[ 0.000000] Memory: 630656k/630656k available, 417920k reserved, 333824K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08f5000 (9140 kB)
[ 0.000000] .init : 0xc08f5000 - 0xc094d300 ( 353 kB)
[ 0.000000] .data : 0xc094e000 - 0xc09f2b90 ( 659 kB)
[ 0.000000] .bss : 0xc09f2bb4 - 0xc0b6c670 (1511 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:626
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Architected local timer running at 6.14MHz.
[ 0.000183] Calibrating delay loop... 1590.23 BogoMIPS (lpj=6213632)
[ 0.031341] pid_max: default: 32768 minimum: 301
[ 0.031463] Security Framework initialized
[ 0.031555] Mount-cache hash table entries: 512
[ 0.032379] Initializing cgroup subsys debug
[ 0.032409] Initializing cgroup subsys cpuacct
[ 0.032409] Initializing cgroup subsys freezer
[ 0.032440] Initializing cgroup subsys net_cls
[ 0.032470] CPU: Testing write buffer coherency: ok
[ 0.032623] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.032836] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.032897] Setting up static identity map for 0x8068d270 - 0x8068d2c8
[ 0.033142] generating sar_ram layout...
[ 0.033447] sar ram layout created
[ 0.111602] CPU1: Booted secondary processor
[ 0.142395] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.142456] CPU1: Unknown IPI message 0x1
[ 0.142486] Brought up 2 CPUs
[ 0.142517] SMP: Total of 2 processors activated (3188.82 BogoMIPS).
[ 0.152221] omap_hwmod: aess: _wait_target_disable failed
[ 0.155059] omap_hwmod: dss_dispc: cannot be enabled (3)
[ 0.157745] omap_hwmod: dss_dsi1_a: cannot be enabled (3)
[ 0.160461] omap_hwmod: dss_dsi1_c: cannot be enabled (3)
[ 0.163146] omap_hwmod: dss_hdmi: cannot be enabled (3)
[ 0.165832] omap_hwmod: dss_rfbi: cannot be enabled (3)
[ 0.344329] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 0.347045] omap_hwmod: gpu: cannot be enabled (3)
[ 0.350036] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.350677] omap_hwmod: usb_otg_ss: setting DMADISABLE
[ 0.351928] omap_device: cannot add global notifier for dev PM QoS
[ 0.352508] dummy:
[ 0.353149] NET: Registered protocol family 16
[ 0.355346] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.357116] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.357208] OMAP GPIO hardware version 0.1
[ 0.357391] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.357604] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.357849] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.358093] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.358306] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.358551] gpiochip_add: registered GPIOs 192 to 223 on device: gpio
[ 0.358795] gpiochip_add: registered GPIOs 224 to 255 on device: gpio
[ 0.360076] omap_mux_init: Add partition: #1: core, flags: 4
[ 0.360778] omap_mux_init: Add partition: #2: wkup, flags: 4
[ 0.362091] Failed to get l3_init_clkdm
[ 0.367980] dmm dmm: initialized all PAT entries
[ 0.368896] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.368896] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.373016] OMAP DMA hardware revision 0.0
[ 0.374633] SmartReflex Recalibration delay = 86400000ms
[ 0.374633] SmartReflex Class 1.5 initialized
[ 0.374877] Reprogramming LPDDR2 timings to 532000000 Hz
[ 0.381134] bio: create slab <bio-0> at 0
[ 0.381591] vmmc_supply: 3000 mV
[ 0.381774] vwl1271: 1800 mV
[ 0.382568] SCSI subsystem initialized
[ 0.382781] usbcore: registered new interface driver usbfs
[ 0.382843] usbcore: registered new interface driver hub
[ 0.382965] usbcore: registered new device driver usb
[ 0.391418] i2c-gpio i2c-gpio: using pins 195 (SDA) and 194 (SCL)
[ 0.391601] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[ 0.427001] setting trigger mode 8 for irq 39 failed (gic_set_type+0x0/0xe8)
[ 0.427154] palmas 1-0048: twl6035 unknown detected
[ 0.427490] palmas 1-0048: Muxing GPIO 2, PWM 0, LED 0
[ 0.428619] SMPS45: 600 <--> 1310 mV at 880 mV normal standby
[ 0.429321] SMPS6: 1200 mV normal standby
[ 0.430053] SMPS7: 1800 mV normal standby
[ 0.430938] SMPS8: 600 <--> 1310 mV at 1040 mV normal standby
[ 0.431762] SMPS9: 2100 mV normal standby
[ 0.432342] SMPS10: 5000 mV normal standby
[ 0.432617] LDO1: 2800 mV normal standby
[ 0.433288] LDO2: 2900 mV normal standby
[ 0.433868] LDO3: 3000 mV normal standby
[ 0.434539] LDO4: 1500 mV normal standby
[ 0.435089] LDO5: 1800 mV normal standby
[ 0.435638] LDO6: 1500 mV normal standby
[ 0.436187] LDO7: 1500 mV normal standby
[ 0.436737] LDO8: 1500 mV normal standby
[ 0.437438] LDO9: 1800 <--> 3300 mV at 900 mV normal standby
[ 0.438293] LDOLN: 1800 mV normal standby
[ 0.438842] LDOUSB: 3250 mV normal standby
[ 0.440307] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
[ 0.440490] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 400 kHz
[ 0.440673] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
[ 0.440856] omap_i2c omap_i2c.5: bus 5 rev2.4.0 at 400 kHz
[ 0.442626] gpiochip_add: registered GPIOs 256 to 279 on device: tca6424
[ 0.442749] Linux video capture interface: v2.00
[ 0.442779] sr_init: No PMIC hook to init smartreflex
[ 0.443237] omap-iommu omap-iommu.0: dsp registered
[ 0.443298] omap-iommu omap-iommu.1: ipu registered
[ 0.443450] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.443908] Bluetooth: Core ver 2.16
[ 0.443939] NET: Registered protocol family 31
[ 0.443969] Bluetooth: HCI device and connection manager initialized
[ 0.443969] Bluetooth: HCI socket layer initialized
[ 0.444000] Bluetooth: L2CAP socket layer initialized
[ 0.444030] Bluetooth: SCO socket layer initialized
[ 0.452575] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 0.452880] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 0.453124] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 0.453155] Power Management for TI OMAP4XX/OMAP5XXX devices.
[ 0.609436] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 0.765686] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 0.765869] ------------[ cut here ]------------
[ 0.765899] WARNING: at arch/arm/mach-omap2/pm4xxx_5xxx.c:750 omap4_pm_init+0x844/0xc34()
[ 0.765899] Enabled DSS->EMIF Static dependency, needs proper rootcause
[ 0.765899] Modules linked in:
[ 0.765930] Backtrace:
[ 0.765930] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 0.765960] r6:000002ee r5:c0904870 r4:d402dec8 r3:c09b0f50
[ 0.765991] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 0.765991] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 0.766021] r8:00000000 r7:c09ae25c r6:c09ae22c r5:c09ae2bc r4:00000000
[ 0.766021] r3:00000009
[ 0.766052] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c0904870>] (omap4_pm_init+0x844/0xc34)
[ 0.766052] r3:c09f3f64 r2:c0828434
[ 0.766082] [<c090402c>] (omap4_pm_init+0x0/0xc34) from [<c0900e28>] (omap2_common_pm_subsys_init+0x188/0x21c)
[ 0.766082] [<c0900ca0>] (omap2_common_pm_subsys_init+0x0/0x21c) from [<c0008698>] (do_one_initcall+0x11c/0x184)
[ 0.766113] r5:00000004 r4:d402c000
[ 0.766113] [<c000857c>] (do_one_initcall+0x0/0x184) from [<c08f598c>] (kernel_init+0x104/0x1c4)
[ 0.766143] [<c08f5888>] (kernel_init+0x0/0x1c4) from [<c004a968>] (do_exit+0x0/0x804)
[ 0.766174] Board Information:
[ 0.766174] Revision : 0000
[ 0.766174] Serial : 0000000000000000
[ 0.766174] SoC Information:
[ 0.766174] CPU : OMAP5432
[ 0.766174] Rev : ES2.0
[ 0.766204] Type : GP
[ 0.766204] Production ID: D0110451-2E6604F0
[ 0.766204] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 0.766204]
[ 0.766204] ---[ end trace 08852b99bf1c02e6 ]---
[ 0.922515] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 0.922698] ------------[ cut here ]------------
[ 0.922729] WARNING: at arch/arm/mach-omap2/pm4xxx_5xxx.c:1235 omap4_pm_init+0xb24/0xc34()
[ 0.922729] omap4_pm_init: EMIF Clock domain denied idle: DDR3 WA
[ 0.922760] Modules linked in:
[ 0.922760] Backtrace:
[ 0.922790] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 0.922790] r6:000004d3 r5:c0904b50 r4:d402dec8 r3:c09b0f50
[ 0.922821] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 0.922851] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 0.922851] r8:00000000 r7:c09ae25c r6:c09ae22c r5:00000003 r4:00000000
[ 0.922882] r3:00000009
[ 0.922882] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c0904b50>] (omap4_pm_init+0xb24/0xc34)
[ 0.922912] r3:c068fa50 r2:c082867c
[ 0.922943] [<c090402c>] (omap4_pm_init+0x0/0xc34) from [<c0900e28>] (omap2_common_pm_subsys_init+0x188/0x21c)
[ 0.922943] [<c0900ca0>] (omap2_common_pm_subsys_init+0x0/0x21c) from [<c0008698>] (do_one_initcall+0x11c/0x184)
[ 0.922973] r5:00000004 r4:d402c000
[ 0.922973] [<c000857c>] (do_one_initcall+0x0/0x184) from [<c08f598c>] (kernel_init+0x104/0x1c4)
[ 0.923004] [<c08f5888>] (kernel_init+0x0/0x1c4) from [<c004a968>] (do_exit+0x0/0x804)
[ 0.923004] Board Information:
[ 0.923034] Revision : 0000
[ 0.923034] Serial : 0000000000000000
[ 0.923034] SoC Information:
[ 0.923034] CPU : OMAP5432
[ 0.923034] Rev : ES2.0
[ 0.923034] Type : GP
[ 0.923034] Production ID: D0110451-2E6604F0
[ 0.923065] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 0.923065]
[ 0.923065] ---[ end trace 08852b99bf1c02e7 ]---
[ 0.923095] omap_opp_set_min_rate: Missing opp info for hwmod hsi
[ 0.923095] Forcing clock hsi_fclk to minimum rate 192000000
[ 0.923126] omap_opp_set_min_rate: Missing opp info for hwmod ipu_c0
[ 0.923126] Forcing clock dpll_core_h22x2_ck to minimum rate 425600000
[ 0.923156] omap_opp_set_min_rate: Missing opp info for hwmod dsp_c0
[ 0.923187] Forcing clock virt_dpll_dsp_ck to minimum rate 233000000
[ 0.923950] Switching to clocksource arch_sys_counter
[ 0.931549] sr_classp5_calib_work: smartreflex_core: Calibration complete: Voltage Nominal=1040000 Calib=1040000 Dyn=1040000
OPP_margin=0 total_margin=0
[ 0.938232] NET: Registered protocol family 2
[ 0.938415] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.938842] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.939880] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 0.940948] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.940979] TCP: reno registered
[ 0.940979] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.941009] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.941192] NET: Registered protocol family 1
[ 0.941497] RPC: Registered named UNIX socket transport module.
[ 0.941497] RPC: Registered udp transport module.
[ 0.941528] RPC: Registered tcp transport module.
[ 0.941528] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.941589] usbhs_omap usbhs_omap: ehci_logic_fck failed:-2
[ 0.942413] Trying to unpack rootfs image as initramfs...
[ 0.951385] Freeing initrd memory: 176K
[ 0.951812] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.955322] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1060000 Calib=1060000 Dyn=1060000
[ 0.970916] sr_classp5_calib_work: smartreflex_mm: Calibration complete: Voltage Nominal=1120000 Calib=1110000 Dyn=1120000
[ 1.060668] highmem bounce pool size: 64 pages
[ 1.061431] fuse init (API version 7.18)
[ 1.061553] msgmni has been set to 612
[ 1.063018] io scheduler noop registered
[ 1.063049] io scheduler deadline registered
[ 1.063079] io scheduler cfq registered (default)
[ 1.063781] OMAP DSS rev 6.1
[ 1.084259] dsscomp: initializing.
[ 1.084259] misc dsscomp: display0=hdmi_panel
[ 1.084289] misc dsscomp: found 1 displays and 4 overlays, WB overlay 1
[ 1.084899] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.085174] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.585235] console [ttyO2] enabled
[ 2.589294] omap_uart.4: ttyO4 at MMIO 0x48066000 (irq = 137) is a OMAP UART4
[ 2.597534] [drm] Initialized drm 1.1.0 20060810
[ 2.602600] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 2.610931] omap_ion_probe: adding heap tiler of type 4 with b5200000@5100000
[ 2.618591] omap_ion_probe: adding heap nonsecure_tiler of type 4 with b4300000@f00000
[ 2.627197] omap_ion_probe: adding heap system of type 0 with 0@0
[ 2.633697] omap_ion_probe: adding heap tiler_reservation of type 5 with 0@0
[ 2.645599] brd: module loaded
[ 2.651123] loop: module loaded
[ 2.654571] (stk) :sysfs entries created
[ 2.658813] (stk) : debugfs entries created
[ 2.663269] (hci_tty): inside hci_tty_init
[ 2.667938] (hci_tty): allocated 252, 0
[ 2.672027] AK8975 compass driver: init
[ 2.676788] gccore gccore.0: opp_get_opp_count: device OPP not found (-19)
[ 2.701965] NFC Driver for TI WiLink
[ 2.706176] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.713684] omap2_mcspi omap2_mcspi.1: master is unqueued, this is deprecated
[ 2.721557] omap2_mcspi omap2_mcspi.2: master is unqueued, this is deprecated
[ 2.729553] omap2_mcspi omap2_mcspi.4: master is unqueued, this is deprecated
[ 2.737365] tun: Universal TUN/TAP device driver, 1.6
[ 2.742767] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.749847] usbcore: registered new interface driver asix
[ 2.755676] usbcore: registered new interface driver cdc_ether
[ 2.761962] usbcore: registered new interface driver smsc95xx
[ 2.768157] usbcore: registered new interface driver net1080
[ 2.774261] usbcore: registered new interface driver cdc_subset
[ 2.780639] usbcore: registered new interface driver zaurus
[ 2.786651] usbcore: registered new interface driver cdc_ncm
[ 3.486511] PC detected
[ 3.495117] palmas-usb palmas-usb.8: Initialized Palmas USB module
[ 3.501953] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.508972] ehci_hcd: block sizes: qh 64 qtd 96 itd 160 sitd 96
[ 3.515533] ehci-omap ehci-omap.0: reset hcs_params 0x1313 dbg=0 cc=1 pcc=3 ordered ports=3
[ 3.524322] ehci-omap ehci-omap.0: reset hcc_params 20016 thresh 1 uframes 256/512/1024 park LPM
[ 3.533569] ehci-omap ehci-omap.0: reset command 0080b02 park=3 ithresh=8 period=1024 Reset HALT
[ 3.542907] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.548919] drivers/usb/core/inode.c: creating file 'devices'
[ 3.554962] drivers/usb/core/inode.c: creating file '001'
[ 3.560760] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.569213] ehci-omap ehci-omap.0: park 0
[ 3.573455] ehci-omap ehci-omap.0: support lpm
[ 3.578124] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 3.584167] ehci-omap ehci-omap.0: init command 0010005 (park)=0 ithresh=1 period=512 RUN
[ 3.603729] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.609832] usb usb1: default language 0x0409
[ 3.614440] usb usb1: udev 1, busnum 1, minor = 0
[ 3.619415] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.626525] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.634155] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.639739] usb usb1: Manufacturer: Linux 3.4.34-01535-g499e8d5-dirty ehci_hcd
[ 3.647338] usb usb1: SerialNumber: ehci-omap.0
[ 3.652313] usb usb1: usb_probe_device
[ 3.656249] usb usb1: configuration #1 chosen from 1 choice
[ 3.662139] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 3.668243] hub 1-0:1.0: usb_probe_interface
[ 3.672729] hub 1-0:1.0: usb_probe_interface - got id
[ 3.678039] hub 1-0:1.0: USB hub found
[ 3.682006] hub 1-0:1.0: 3 ports detected
[ 3.686218] hub 1-0:1.0: standalone hub
[ 3.690277] hub 1-0:1.0: individual port power switching
[ 3.695831] hub 1-0:1.0: individual port over-current protection
[ 3.702178] hub 1-0:1.0: power on to power good time: 20ms
[ 3.707946] hub 1-0:1.0: local power source is good
[ 3.713104] hub 1-0:1.0: enabling power on all ports
[ 3.718444] drivers/usb/core/inode.c: creating file '001'
[ 3.724212] ehci-omap ehci-omap.0: ...powerup ports...
[ 3.760131] usbcore: registered new interface driver cdc_wdm
[ 3.766082] Initializing USB Mass Storage driver...
[ 3.771270] usbcore: registered new interface driver usb-storage
[ 3.777618] USB Mass Storage support registered.
[ 3.782501] usbcore: registered new interface driver libusual
[ 3.788604] usbcore: registered new interface driver usbtest
[ 3.794555] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 3.801116] file system registered
[ 3.805480] gadget: Mass Storage Function, version: 2009/09/11
[ 3.811737] gadget: Number of LUNs=1
[ 3.815643] ehci-omap ehci-omap.0: GetStatus port:3 status 001803 0 ACK POWER sig=j CSC CONNECT
[ 3.824890] lun0: LUN: removable file: (no medium)
[ 3.830047] hub 1-0:1.0: port 3: status 0501 change 0001
[ 3.835815] gadget: android_usb ready
[ 3.931854] hub 1-0:1.0: state 7 ports 3 chg 0008 evt 0000
[ 3.937622] hub 1-0:1.0: port 3, status 0501, change 0000, 480 Mb/s
[ 4.017761] ehci-omap ehci-omap.0: port 3 high speed
[ 4.022979] ehci-omap ehci-omap.0: GetStatus port:3 status 001005 0 ACK POWER sig=se0 PE CONNECT
[ 4.103729] usb 1-3: new high-speed USB device number 2 using ehci-omap
[ 4.181884] ehci-omap ehci-omap.0: port 3 high speed
[ 4.187103] ehci-omap ehci-omap.0: GetStatus port:3 status 001005 0 ACK POWER sig=se0 PE CONNECT
[ 4.292541] mousedev: PS/2 mouse device common for all mice
[ 4.299682] usb 1-3: udev 2, busnum 1, minor = 1
[ 4.304656] usb 1-3: New USB device found, idVendor=0424, idProduct=9730
[ 4.311737] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.319610] usb 1-3: usb_probe_device
[ 4.323547] usb 1-3: configuration #1 chosen from 1 choice
[ 4.331634] input: palmas_pwron as /devices/platform/omap_i2c.1/i2c-1/1-0048/palmas-pwrbutton.7/input/input0
[ 4.342010] usb 1-3: adding 1-3:1.0 (config #1, interface 0)
[ 4.348052] smsc95xx 1-3:1.0: usb_probe_interface
[ 4.352996] smsc95xx 1-3:1.0: usb_probe_interface - got id
[ 4.359466] smsc95xx v1.0.4
[ 4.365417] twl_rtc twl_rtc.9: rtc core: registered twl_rtc as rtc0
[ 4.373626] i2c /dev entries driver
[ 4.377746] usbcore: registered new interface driver uvcvideo
[ 4.383789] USB Video Class driver (1.1.1)
[ 4.388214] Driver for 1-wire Dallas network protocol.
[ 4.394927] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
[ 4.402282] report_temperature_delayed_work_fn: Fail to set temp
[ 4.408935] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 4.418182] cpuidle: using governor ladder
[ 4.422729] cpuidle: using governor menu
[ 4.444213] Registered led device: blue
[ 4.449462] Registered led device: red
[ 4.454376] Registered led device: green
[ 4.459716] Registered led device: panda5::status1
[ 4.466918] Registered led device: panda5::status2
[ 4.476501] smsc95xx 1-3:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.0-3, smsc95xx USB 2.0 Ethernet, 46:ee:ff:d6:5f:41
[ 4.488372] drivers/usb/core/inode.c: creating file '002'
[ 4.494171] hub 1-0:1.0: state 7 ports 3 chg 0000 evt 0004
[ 4.500091] ehci-omap ehci-omap.0: GetStatus port:2 status 001803 0 ACK POWER sig=j CSC CONNECT
[ 4.509429] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1250000 Calib=1250000 Dyn=1250000
[ 4.523773] Registered led device: panda5::status3
[ 4.528930] hub 1-0:1.0: port 2, status 0501, change 0001, 480 Mb/s
[ 4.540557] Registered led device: panda5::status4
[ 4.546447] Registered led device: panda5::status5
[ 4.551849] usbcore: registered new interface driver usbhid
[ 4.557769] usbhid: USB HID core driver
[ 4.562469] ashmem: initialized
[ 4.565795] logger: created 256K log 'log_main'
[ 4.570587] logger: created 256K log 'log_events'
[ 4.575592] logger: created 256K log 'log_radio'
[ 4.580566] logger: created 256K log 'log_system'
[ 4.585998] omap_governor_init: domain cpu slope 118 const -2992
[ 4.592498] omap_governor_init: domain gpu slope 61 const -1558
[ 4.599334] rproc remoteproc0: ipu_c0 is available
[ 4.604461] rproc remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 4.614471] rproc remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 4.626525] OMAP HSI: HSI driver version 0.4.4
[ 4.631927] usbcore: registered new interface driver snd-usb-audio
[ 4.639190] mmc0: new high speed DDR MMC card at address 0001
[ 4.646270] mmcblk0: mmc0:0001 SEM04G 3.68 GiB
[ 4.652191] aess aess: ABE Firmware version 9560
[ 4.666229] mmcblk0boot0: mmc0:0001 SEM04G partition 1 2.00 MiB
[ 4.672576] mmcblk0boot1: mmc0:0001 SEM04G partition 2 2.00 MiB
[ 4.683288] Alternate GPT is invalid, using primary GPT.
[ 4.689025] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 4.689666] hub 1-0:1.0: debounce: port 2: total 100ms stable 100ms status 0x501
[ 4.704864] mmcblk0boot1: unknown partition table
[ 4.711395] mmcblk0boot0: unknown partition table
[ 4.719329] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
[ 4.725891] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
[ 4.732849] asoc: snd-soc-dummy-dai <-> Voice mapping ok
[ 4.738922] asoc: snd-soc-dummy-dai <-> Tones mapping ok
[ 4.744995] asoc: snd-soc-dummy-dai <-> Vibra mapping ok
[ 4.750823] asoc: snd-soc-dummy-dai <-> MODEM mapping ok
[ 4.756622] asoc: snd-soc-dummy-dai <-> MultiMedia1 LP mapping ok
[ 4.763122] ehci-omap ehci-omap.0: port 2 high speed
[ 4.763275] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 4.774536] ehci-omap ehci-omap.0: GetStatus port:2 status 001805 0 ACK POWER sig=j PE CONNECT
[ 4.784301] asoc: twl6040-legacy <-> mcpdm-legacy mapping ok
[ 4.790679] asoc: dit-hifi <-> mcasp-legacy mapping ok
[ 4.796600] asoc: dmic-hifi <-> omap-dmic mapping ok
[ 4.802551] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 4.808227] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 4.813781] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 4.819396] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 4.825042] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 4.831512] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 4.837951] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 4.844421] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 4.850769] usb 1-2: new high-speed USB device number 3 using ehci-omap
[ 4.850952] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 4.851196] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 4.851440] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 4.851684] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 4.851898] asoc: snd-soc-dummy-dai <-> omap-abe-vxrec-dai mapping ok
[ 4.852142] asoc: snd-soc-dummy-dai <-> omap-abe-echo-dai mapping ok
[ 4.852874] input: OMAP5EVM Headset Jack as /devices/platform/omap-abe-twl6040/sound/card0/input1
[ 4.853851] omap-abe-twl6040 omap-abe-twl6040: couldn't get AV Switch regulator
[ 4.912811] asoc: omap-hdmi-hifi <-> omap-hdmi-audio-dai mapping ok
[ 4.919952] oprofile: using timer interrupt.
[ 4.924560] GACT probability NOT on
[ 4.928222] Mirror/redirect action on
[ 4.932098] u32 classifier
[ 4.934936] Actions configured
[ 4.938507] Netfilter messages via NETLINK v0.30.
[ 4.943481] nf_conntrack version 0.5.0 (10112 buckets, 40448 max)
[ 4.950134] ctnetlink v0.93: registering with nfnetlink.
[ 4.955749] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.963073] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 4.969360] xt_time: kernel timezone is -0000
[ 4.974151] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.979858] ehci-omap ehci-omap.0: port 2 high speed
[ 4.979858] arp_tables: (C) 2002 David S. Miller
[ 4.979888] TCP: cubic registered
[ 4.979888] Initializing XFRM netlink socket
[ 4.997863] ehci-omap ehci-omap.0: GetStatus port:2 status 001005 0 ACK POWER sig=se0 PE CONNECT
[ 5.007354] NET: Registered protocol family 10
[ 5.012634] Mobile IPv6
[ 5.015197] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.020965] IPv6 over IPv4 tunneling driver
[ 5.025909] NET: Registered protocol family 17
[ 5.030578] NET: Registered protocol family 15
[ 5.035308] Bridge firewalling registered
[ 5.039703] Bluetooth: RFCOMM TTY layer initialized
[ 5.044830] Bluetooth: RFCOMM socket layer initialized
[ 5.050262] Bluetooth: RFCOMM ver 1.11
[ 5.054199] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.059814] Bluetooth: BNEP filters: protocol multicast
[ 5.065307] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.071594] NET: Registered protocol family 35
[ 5.076354] NET: Registered protocol family 37
[ 5.081024] NET: Registered protocol family 40
[ 5.086029] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 5.094116] ThumbEE CPU extension supported.
[ 5.094146] mmc1: host does not support reading read-only switch. assuming write-enable.
[ 5.107177] Registering SWP/SWPB emulation handler
[ 5.112335] mmc1: new high speed SDHC card at address 1234
[ 5.117034] clock: disabling unused clocks to save power
[ 5.123870] usb 1-2: udev 3, busnum 1, minor = 2
[ 5.128753] usb 1-2: New USB device found, idVendor=0424, idProduct=3503
[ 5.128936] mmcblk1: mmc1:1234 SA16G 14.4 GiB
[ 5.140472] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.148101] usb 1-2: usb_probe_device
[ 5.151977] usb 1-2: configuration #1 chosen from 1 choice
[ 5.152008] mmcblk1: p1 p2
[ 5.158416] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 5.158416]
[ 5.158660] Enter hdmi_core_init
[ 5.158721] Enable video_path
[ 5.174377] usb 1-2: adding 1-2:1.0 (config #1, interface 0)
[ 5.180389] hub 1-2:1.0: usb_probe_interface
[ 5.184875] hub 1-2:1.0: usb_probe_interface - got id
[ 5.190216] hub 1-2:1.0: USB hub found
[ 5.194244] hub 1-2:1.0: 3 ports detected
[ 5.198455] hub 1-2:1.0: standalone hub
[ 5.202484] hub 1-2:1.0: ganged power switching
[ 5.207244] hub 1-2:1.0: global over-current protection
[ 5.212890] hub 1-2:1.0: TT per port
[ 5.216674] hub 1-2:1.0: TT requires at most 8 FS bit times (666 ns)
[ 5.223358] hub 1-2:1.0: power on to power good time: 0ms
[ 5.229248] hub 1-2:1.0: local power source is good
[ 5.234344] hub 1-2:1.0: no over-current condition exists
[ 5.240051] hub 1-2:1.0: enabling power on all ports
[ 5.245666] drivers/usb/core/inode.c: creating file '003'
[ 5.346252] usb 1-2: link qh256-0001/d40ae180 start 1 [1/0 us]
[ 5.352386] hub 1-2:1.0: state 7 ports 3 chg 0000 evt 0000
[ 5.447540] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=880000 Calib=890000 Dyn=880000
[ 5.494995] cannot apply mgr(tv) on inactive device
[ 5.500091] cannot aply mgr(lcd)--invalid device
[ 5.516204] omapfb omapfb: failed to apply dispc config
[ 5.521728] cannot apply mgr(tv) on inactive device
[ 5.526855] omapfb omapfb: failed to apply dispc config
[ 5.532318] cannot aply mgr(lcd2)--invalid device
[ 5.537689] omapfb omapfb: failed to apply dispc config
[ 5.543579] LDOUSB: incomplete constraints, leaving on
[ 5.549224] LDOLN: incomplete constraints, leaving on
[ 5.554779] LDO8: incomplete constraints, leaving on
[ 5.560455] LDO6: incomplete constraints, leaving on
[ 5.566009] LDO5: incomplete constraints, leaving on
[ 5.574127] LDO3: incomplete constraints, leaving on
[ 5.580139] SMPS8: incomplete constraints, leaving on
[ 5.585754] SMPS6: incomplete constraints, leaving on
[ 5.591369] SMPS45: incomplete constraints, leaving on
[ 5.597320] input: gpio-keys as /devices/platform/gpio-keys.0/input/input2
[ 5.605621] twl_rtc twl_rtc.9: setting system clock to 2000-01-01 22:21:52 UTC (946765312)
[ 5.614379] ALSA device list:
[ 5.617584] #0: OMAP5EVM
[ 5.627166] #1: OMAPHDMI
[ 5.642974] Freeing init memory: 352K
[ 5.648895] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 5.732116] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.743713] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.758392] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.769989] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.781585] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.795562] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.810638] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.822235] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.833862] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.845458] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.857055] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.868652] omap_hsmmc omap_hsmmc.2: Timeout waiting on controller reset in omap_hsmmc_reset_controller_fsm
[ 5.892333] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 5.906402] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 5.922241] EXT4-fs (mmcblk0p9): recovery complete
[ 5.927337] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 5.970947] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap_hsmmc.1/by-name/cache
[ 6.208831] rproc remoteproc0: powering up ipu_c0
[ 6.238494] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 6.271820] rproc remoteproc0: Booting fw image ducati-m3-core0.xem3, size 13487335
[ 6.335144] EXT4-fs (mmcblk0p10): recovery complete
[ 6.341461] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 6.400787] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap_hsmmc.1/by-name/userdata
[ 6.425933] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
[ 6.497924] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[ 6.507232] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 6.516113] omap-iommu omap-iommu.1: ipu: version 2.1
[ 6.531402] rproc remoteproc0: remote processor ipu_c0 is now up
[ 6.540222] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.547790] rproc remoteproc0: registered virtio0 (type 7)
[ 6.591217] HDCP: failed to load keys
[ 6.591217]
[ 6.611968] android_usb: already disabled
[ 6.616302] android_usb: already disabled
[ 6.621368] android_usb: already disabled
[ 6.628631] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[ 6.636505] adb_open
[ 6.642517] mtp_bind_config
[ 6.645538] adb_bind_config
[ 6.726013] PVR: PVRCore_Init
[ 6.729339] PVR: LinuxMMInit: Maximum page pool size: 10800
[ 6.735565] PVR: PVRSRVDriverProbe(pDevice=d40ea200)
shell@android:/ $ [ 6.742034] PVR: SGX register base: 0x56000000
[ 6.748657] PVR: SGX register size: 65535
[ 6.752990] PVR: SGX IRQ: 53
[ 6.756225] PVR: EnableSystemClocks: Enabling System Clocks
[ 6.897430] android_work: sent uevent USB_STATE=CONNECTED
[ 6.904418] android_usb gadget: high-speed config #1: android
[ 6.910797] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.913757] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 7.067199] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 7.077178] ------------[ cut here ]------------
[ 7.082031] WARNING: at arch/arm/mach-omap2/omap_hwmod.c:1803 _idle+0x224/0x238()
[ 7.089904] omap_hwmod: gpu: idle state can only be entered from enabled state
[ 7.097503] Modules linked in: pvrsrvkm_sgx544_116(O+)
[ 7.102935] Backtrace:
[ 7.105529] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 7.114410] r6:0000070b r5:c0028090 r4:d2ae9b20 r3:c09b0f50
[ 7.120422] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 7.129791] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 7.139739] r8:8073d7ad r7:d40eda80 r6:a0000013 r5:c09a48c0 r4:ffffffea
[ 7.146636] r3:00000009
[ 7.149414] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c0028090>] (_idle+0x224/0x238)
[ 7.158233] r3:c0820b88 r2:c08226d8
[ 7.162017] [<c0027e6c>] (_idle+0x0/0x238) from [<c002874c>] (omap_hwmod_idle+0x2c/0x48)
[ 7.170532] r6:a0000013 r5:c09a4910 r4:c09a48c0
[ 7.175415] [<c0028720>] (omap_hwmod_idle+0x0/0x48) from [<c0040840>] (omap_device_idle_hwmods+0x30/0x44)
[ 7.185485] r6:00000000 r5:d40edb00 r4:00000001 r3:d40edac0
[ 7.191467] [<c0040810>] (omap_device_idle_hwmods+0x0/0x44) from [<c0040a3c>] (_omap_device_deactivate+0xa8/0x140)
[ 7.202392] r5:d40eda80 r4:d40edb00
[ 7.206207] [<c0040994>] (_omap_device_deactivate+0x0/0x140) from [<c00412bc>] (omap_device_idle+0x30/0x5c)
[ 7.216461] [<c004128c>] (omap_device_idle+0x0/0x5c) from [<c00413a0>] (omap_device_runtime_suspend+0x24/0x2c)
[ 7.226989] r4:00000000 r3:00000000
[ 7.230773] [<c004137c>] (omap_device_runtime_suspend+0x0/0x2c) from [<c02f0f50>] (__rpm_callback+0x3c/0x78)
[ 7.241149] r5:d40ea268 r4:d40ea208
[ 7.244934] [<c02f0f14>] (__rpm_callback+0x0/0x78) from [<c02f1480>] (rpm_suspend+0x268/0x774)
[ 7.253997] r6:00000000 r5:d40ea268 r4:d40ea208 r3:ffffffff
[ 7.259979] [<c02f1218>] (rpm_suspend+0x0/0x774) from [<c02f2a04>] (__pm_runtime_suspend+0x64/0x7c)
[ 7.269500] [<c02f29a0>] (__pm_runtime_suspend+0x0/0x7c) from [<c02eda8c>] (pm_generic_runtime_idle+0x4c/0x54)
[ 7.280029] r7:00000004 r6:c00407fc r5:d40ea268 r4:d40ea208
[ 7.285980] [<c02eda40>] (pm_generic_runtime_idle+0x0/0x54) from [<c004080c>] (_od_runtime_idle+0x10/0x14)
[ 7.296142] r4:d40ea208 r3:00000000
[ 7.299896] [<c00407fc>] (_od_runtime_idle+0x0/0x14) from [<c02f0f50>] (__rpm_callback+0x3c/0x78)
[ 7.309234] [<c02f0f14>] (__rpm_callback+0x0/0x78) from [<c02f1b10>] (rpm_idle+0x108/0x2bc)
[ 7.317993] r6:00000000 r5:d40ea208 r4:d40ea268 r3:00000088
[ 7.323944] [<c02f1a08>] (rpm_idle+0x0/0x2bc) from [<c02f1dac>] (__pm_runtime_idle+0x64/0x7c)
[ 7.332885] [<c02f1d48>] (__pm_runtime_idle+0x0/0x7c) from [<c02e8fd0>] (driver_probe_device+0x12c/0x224)
[ 7.342926] r7:00000000 r6:00000001 r5:c0a5ee88 r4:d40ea208
[ 7.348907] [<c02e8ea4>] (driver_probe_device+0x0/0x224) from [<c02e915c>] (__driver_attach+0x94/0x98)
[ 7.358673] r8:00000001 r7:00000000 r6:d40ea23c r5:bf03e25c r4:d40ea208
[ 7.365539] r3:00000000
[ 7.368316] [<c02e90c8>] (__driver_attach+0x0/0x98) from [<c02e7614>] (bus_for_each_dev+0x68/0x9c)
[ 7.377716] r6:c02e90c8 r5:00000000 r4:bf03e25c r3:c02e90c8
[ 7.383666] [<c02e75ac>] (bus_for_each_dev+0x0/0x9c) from [<c02e8a7c>] (driver_attach+0x24/0x28)
[ 7.392883] r6:d245abc0 r5:c09c7410 r4:bf03e25c
[ 7.397766] [<c02e8a58>] (driver_attach+0x0/0x28) from [<c02e86c0>] (bus_add_driver+0x180/0x240)
[ 7.406982] [<c02e8540>] (bus_add_driver+0x0/0x240) from [<c02e9658>] (driver_register+0x80/0x134)
[ 7.416381] [<c02e95d8>] (driver_register+0x0/0x134) from [<c02ea5ac>] (platform_driver_register+0x4c/0x60)
[ 7.426605] r8:00000001 r7:00000001 r6:00000000 r5:bf03e7e0 r4:bf03ebd4
[ 7.433471] r3:c02ea31c
[ 7.436279] [<c02ea560>] (platform_driver_register+0x0/0x60) from [<bf05506c>] (PVRCore_Init+0x6c/0x1dc [pvrsrvkm_sgx544_116])
[ 7.448242] [<bf055000>] (PVRCore_Init+0x0/0x1dc [pvrsrvkm_sgx544_116]) from [<c0008698>] (do_one_initcall+0x11c/0x184)
[ 7.459564] r6:00000000 r5:bf03e7e0 r4:d2ae8000
[ 7.464447] [<c000857c>] (do_one_initcall+0x0/0x184) from [<c009cdf8>] (sys_init_module+0xdac/0x1b78)
[ 7.474121] [<c009c04c>] (sys_init_module+0x0/0x1b78) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 7.483612] Board Information:
[ 7.483642] Revision : 0000
[ 7.483642] Serial : 0000000000000000
[ 7.483642] SoC Information:
[ 7.483642] CPU : OMAP5432
[ 7.483642] Rev : ES2.0
[ 7.483642] Type : GP
[ 7.483642] Production ID: D0110451-2E6604F0
[ 7.483642] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 7.483673]
[ 7.516723] ---[ end trace 08852b99bf1c02e9 ]---
[ 7.533569] PVR: PVRCore_Init: major device 246
[ 7.611572] hub 1-2:1.0: hub_suspend
[ 7.615325] usb 1-2: unlink qh256-0001/d40ae180 start 1 [1/0 us]
[ 7.634735] usb 1-2: usb auto-suspend, wakeup 1
[ 7.822387] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 7.984588] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 7.993438] PVR: Installing MISR with cookie bf0433c4
[ 7.998992] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie d2aa9ac0
[ 8.006835] PVR: SysFinalise: Version string: SGX revision = 1.1.6
[ 8.013488] ------------[ cut here ]------------
[ 8.018371] WARNING: at arch/arm/mach-omap2/omap_hwmod.c:1803 _idle+0x224/0x238()
[ 8.026214] omap_hwmod: gpu: idle state can only be entered from enabled state
[ 8.033813] Modules linked in: pvrsrvkm_sgx544_116(O)
[ 8.039123] Backtrace:
[ 8.041687] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 8.050537] r6:0000070b r5:c0028090 r4:d24fbb68 r3:c09b0f50
[ 8.056518] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 8.065856] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 8.075805] r8:b842f309 r7:d40eda80 r6:a0000013 r5:c09a48c0 r4:ffffffea
[ 8.082672] r3:00000009
[ 8.085449] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c0028090>] (_idle+0x224/0x238)
[ 8.094207] r3:c0820b88 r2:c08226d8
[ 8.097961] [<c0027e6c>] (_idle+0x0/0x238) from [<c002874c>] (omap_hwmod_idle+0x2c/0x48)
[ 8.106475] r6:a0000013 r5:c09a4910 r4:c09a48c0
[ 8.111328] [<c0028720>] (omap_hwmod_idle+0x0/0x48) from [<c0040840>] (omap_device_idle_hwmods+0x30/0x44)
[ 8.121368] r6:00000000 r5:d40edb00 r4:00000001 r3:d40edac0
[ 8.127349] [<c0040810>] (omap_device_idle_hwmods+0x0/0x44) from [<c0040a3c>] (_omap_device_deactivate+0xa8/0x140)
[ 8.138214] r5:d40eda80 r4:d40edb00
[ 8.141967] [<c0040994>] (_omap_device_deactivate+0x0/0x140) from [<c00412bc>] (omap_device_idle+0x30/0x5c)
[ 8.152191] [<c004128c>] (omap_device_idle+0x0/0x5c) from [<c00413a0>] (omap_device_runtime_suspend+0x24/0x2c)
[ 8.162689] r4:00000000 r3:00000000
[ 8.166473] [<c004137c>] (omap_device_runtime_suspend+0x0/0x2c) from [<c02f0f50>] (__rpm_callback+0x3c/0x78)
[ 8.176788] r5:d40ea268 r4:d40ea208
[ 8.180541] [<c02f0f14>] (__rpm_callback+0x0/0x78) from [<c02f1480>] (rpm_suspend+0x268/0x774)
[ 8.189605] r6:00000000 r5:d40ea268 r4:d40ea208 r3:ffffffff
[ 8.195556] [<c02f1218>] (rpm_suspend+0x0/0x774) from [<c02f2a04>] (__pm_runtime_suspend+0x64/0x7c)
[ 8.205047] [<c02f29a0>] (__pm_runtime_suspend+0x0/0x7c) from [<c02eda8c>] (pm_generic_runtime_idle+0x4c/0x54)
[ 8.215576] r7:00000004 r6:c00407fc r5:d40ea268 r4:d40ea208
[ 8.221527] [<c02eda40>] (pm_generic_runtime_idle+0x0/0x54) from [<c004080c>] (_od_runtime_idle+0x10/0x14)
[ 8.231658] r4:d40ea208 r3:00000000
[ 8.235412] [<c00407fc>] (_od_runtime_idle+0x0/0x14) from [<c02f0f50>] (__rpm_callback+0x3c/0x78)
[ 8.244750] [<c02f0f14>] (__rpm_callback+0x0/0x78) from [<c02f1b10>] (rpm_idle+0x108/0x2bc)
[ 8.253509] r6:00000000 r5:d40ea208 r4:d40ea268 r3:00000088
[ 8.259490] [<c02f1a08>] (rpm_idle+0x0/0x2bc) from [<c02f1dac>] (__pm_runtime_idle+0x64/0x7c)
[ 8.268493] [<c02f1d48>] (__pm_runtime_idle+0x0/0x7c) from [<bf021238>] (DisableSGXClocks+0x40/0x84 [pvrsrvkm_sgx544_116])
[ 8.280090] r7:bf0433c4 r6:bf0432a8 r5:00000000 r4:bf043310
[ 8.286102] [<bf0211f8>] (DisableSGXClocks+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01ea78>] (SysFinalise+0x104/0x200
[ 8.299346] r4:bf0432a8
[ 8.302093] [<bf01e974>] (SysFinalise+0x0/0x200 [pvrsrvkm_sgx544_116]) from [<bf0149a8>] (PVRSRVFinaliseSystem+0x3c/0xbc
[ 8.315612] r8:e0989000 r7:e0988000 r6:00000000 r5:bf0433c4 r4:e0988000
[ 8.322753] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
+0x58/0x84 [pvrsrvkm_sgx544_116])
[ 8.337432] r5:e0989000 r4:e0988000
[ 8.341278] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
+0x8c/0x24c [pvrsrvkm_sgx544_116])
[ 8.355773] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 8.361846] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
+0xe8/0x44c [pvrsrvkm_sgx544_116])
[ 8.376281] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 8.383392] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 8.395355] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 8.402221] r4:d2b9e380
[ 8.404998] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 8.413543] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 8.420440] r4:d2a41380
[ 8.423217] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 8.431976] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 8.439025] Board Information:
[ 8.439025] Revision : 0000
[ 8.439056] Serial : 0000000000000000
[ 8.439056] SoC Information:
[ 8.439056] CPU : OMAP5432
[ 8.439056] Rev : ES2.0
[ 8.439056] Type : GP
[ 8.439056] Production ID: D0110451-2E6604F0
[ 8.439056] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 8.439056]
[ 8.472076] ---[ end trace 08852b99bf1c02ea ]---
[ 8.477203] omaplfb: OMAPLFBInitFBDev: Device 2: invalid framebuffer size
[ 8.484374] omaplfb: OMAPLFBInitFBDev: Device 1: invalid framebuffer size
[ 8.491516] omaplfb: OMAPLFBInitFBVRAM: Device 0: Using 2 VRAM framebuffers
[ 8.649902] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 8.811859] powerdomain: waited too long for powerdomain gpu_pwrdm to complete transition
[ 8.820495] omap-rproc omap-rproc.1: received echo reply from ipu_c0
[ 8.827209] ------------[ cut here ]------------
[ 8.832061] WARNING: at arch/arm/mach-omap2/omap4-common.c:262 axi_error_handler+0x34/0x64()
[ 8.840881]
[ 8.840911] AXI error with Local pheripheral
[ 8.846832] Modules linked in: pvrsrvkm_sgx544_116(O)
[ 8.852325] Backtrace:
[ 8.854888] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 8.863739] r6:00000106 r5:c002977c r4:d24fbae0 r3:c09b0f50
[ 8.869689] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 8.878997] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 8.888946] r8:00000000 r7:00000023 r6:00000023 r5:c0951c50 r4:d409a380
[ 8.895812] r3:00000009
[ 8.898559] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c002977c>] (axi_error_handler+0x34/0x64)
[ 8.908233] r3:20000000 r2:c0822be0
[ 8.911987] [<c0029748>] (axi_error_handler+0x0/0x64) from [<c00a90bc>] (handle_irq_event_percpu+0x80/0x2e4)
[ 8.922302] [<c00a903c>] (handle_irq_event_percpu+0x0/0x2e4) from [<c00a9364>] (handle_irq_event+0x44/0x64)
[ 8.932525] [<c00a9320>] (handle_irq_event+0x0/0x64) from [<c00ac074>] (handle_fasteoi_irq+0xc4/0x16c)
[ 8.942260] r6:d24fa000 r5:c0951c50 r4:c0951c00 r3:00000000
[ 8.948242] [<c00abfb0>] (handle_fasteoi_irq+0x0/0x16c) from [<c00a8894>] (generic_handle_irq+0x38/0x4c)
[ 8.958160] r5:c094c538 r4:c0974d78
[ 8.961914] [<c00a885c>] (generic_handle_irq+0x0/0x4c) from [<c00145a8>] (handle_IRQ+0x54/0xb4)
[ 8.971038] [<c0014554>] (handle_IRQ+0x0/0xb4) from [<c00084d0>] (gic_handle_irq+0x2c/0x60)
[ 8.979797] r8:d2409000 r7:d24fbc1c r6:d24fbbe8 r5:c0973a40 r4:fa212000
[ 8.986663] r3:00000023
[ 8.989410] [<c00084a4>] (gic_handle_irq+0x0/0x60) from [<c0687f00>] (__irq_svc+0x40/0x70)
[ 8.998077] Exception stack(0xd24fbbe8 to 0xd24fbc30)
[ 9.003387] bbe0: e09a0000 0000fe44 00000001 c0973a1c e09a0000 0000fe44
[ 9.011932] bc00: 00000001 00000000 d2409000 d24fa000 d24fbd60 d24fbc4c d24fbc50 d24fbc30
[ 9.020507] bc20: bf01f460 bf001e8c a0000113 ffffffff
[ 9.025817] r6:ffffffff r5:a0000113 r4:bf001e8c r3:bf01f460
[ 9.031829] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf01f460>] (SysEnableSGXInterrupts+0x48/0x5c
[ 9.045532] r6:bf0433c4 r5:bf0432a8 r4:bf043310 r3:00000002
[ 9.051544] [<bf01f418>] (SysEnableSGXInterrupts+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf021168>] (EnableSGXClocks+0x58/0x98
[ 9.065490] r5:bf043310 r4:00000000
[ 9.069305] [<bf021110>] (EnableSGXClocks+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf01f71c>] (SysDevicePostPowerState+0x38/0x40
[ 9.083374] r6:00000000 r5:00000000 r4:d247d700
[ 9.088287] [<bf01f6e4>] (SysDevicePostPowerState+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf01345c>]
(PVRSRVDevicePostPowerStateKM_AnyVaCb+0x5c/0x98 [pvrsrvkm_sgx544_116])
[ 9.104278] [<bf013400>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf012b60>]
(List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x3c/0x60 [pvrsrvkm_sgx544_116])
[ 9.121856] r6:bf013400 r5:d24fbce8 r4:00000000 r3:d247d700
[ 9.127868] [<bf012b24>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x0/0x60 [pvrsrvkm_sgx544_116]) from [<bf0137b0>]
(PVRSRVSetDevicePowerStateKM+0x6c/0xd4 [pvrsrvkm_sgx544_116])
[ 9.144653] r3:00000000 r2:00000000 r1:bf013400
[ 9.149505] r6:bf04330c r5:00000000 r4:00000000
[ 9.154418] [<bf013744>] (PVRSRVSetDevicePowerStateKM+0x0/0xd4 [pvrsrvkm_sgx544_116]) from [<bf0291e4>]
(SGXScheduleCCBCommandKM+0x50/0x124 [pvrsrvkm_sgx544_116])
[ 9.169647] r7:00000006 r6:d2aa9ac0 r5:ffffffff r4:00000000
[ 9.175659] [<bf029194>] (SGXScheduleCCBCommandKM+0x0/0x124 [pvrsrvkm_sgx544_116]) from [<bf026680>] (SGXGetMiscInfoUkernel
+0x7c/0x148 [pvrsrvkm_sgx544_116])
[ 9.190490] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck
+0xb0/0x514 [pvrsrvkm_sgx544_116])
[ 9.205139] [<bf02674c>] (SGXDevInitCompatCheck+0x0/0x514 [pvrsrvkm_sgx544_116]) from [<bf0142fc>]
(PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x24/0x5c [pvrsrvkm_sgx544_116])
[ 9.221191] r8:e0989000 r7:e0988000 r6:00000000 r5:d2aa9ac0 r4:bf02674c
[ 9.228302] [<bf0142d8>] (PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf012908>]
(List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x24/0x4c [pvrsrvkm_sgx544_116])
[ 9.245971] r5:bf0142d8 r4:00000000
[ 9.249786] [<bf0128e4>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x0/0x4c [pvrsrvkm_sgx544_116]) from [<bf0149d0>]
(PVRSRVFinaliseSystem+0x64/0xbc [pvrsrvkm_sgx544_116])
[ 9.265808] r5:bf0433c4 r4:00000000
[ 9.269622] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 9.284301] r5:e0989000 r4:e0988000
[ 9.288116] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
[ 9.302612] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 9.308624] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
[ 9.323028] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 9.330108] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 9.342041] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 9.348907] r4:d2b9e380
[ 9.351684] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 9.360260] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 9.367095] r4:d2a41380
[ 9.369873] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 9.378631] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 9.385681] Board Information:
[ 9.385681] Revision : 0000
[ 9.385681] Serial : 0000000000000000
[ 9.385681] SoC Information:
[ 9.385681] CPU : OMAP5432
[ 9.385681] Rev : ES2.0
[ 9.385681] Type : GP
[ 9.385711] Production ID: D0110451-2E6604F0
[ 9.385711] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 9.385711]
[ 9.418701] ---[ end trace 08852b99bf1c02eb ]---
[ 9.423553] ------------[ cut here ]------------
[ 9.428405] WARNING: at arch/arm/mach-omap2/omap_l3_noc.c:97 l3_interrupt_handler+0xc0/0x168()
[ 9.437438] L3 standard error: TARGET:SGX at address 0xfe38
[ 9.443359] Modules linked in: pvrsrvkm_sgx544_116(O)
[ 9.448638] Backtrace:
[ 9.451232] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 9.460083] r6:00000061 r5:c003a068 r4:d24fb9d0 r3:c09b0f50
[ 9.466033] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 9.475341] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 9.485260] r8:d24fbbe8 r7:0000002a r6:c069130c r5:80080001 r4:e0858600
[ 9.492126] r3:00000009
[ 9.494903] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c003a068>] (l3_interrupt_handler+0xc0/0x168)
[ 9.504943] r3:c082d8a0 r2:c082d7c0
[ 9.508697] [<c0039fa8>] (l3_interrupt_handler+0x0/0x168) from [<c00a90bc>] (handle_irq_event_percpu+0x80/0x2e4)
[ 9.519348] r8:d24fbbe8 r7:0000002a r6:0000002a r5:c0952190 r4:d40aeb40
[ 9.526397] [<c00a903c>] (handle_irq_event_percpu+0x0/0x2e4) from [<c00a9364>] (handle_irq_event+0x44/0x64)
[ 9.536621] [<c00a9320>] (handle_irq_event+0x0/0x64) from [<c00ac074>] (handle_fasteoi_irq+0xc4/0x16c)
[ 9.546386] r6:d24fa000 r5:c0952190 r4:c0952140 r3:00000000
[ 9.552337] [<c00abfb0>] (handle_fasteoi_irq+0x0/0x16c) from [<c00a8894>] (generic_handle_irq+0x38/0x4c)
[ 9.562255] r5:c094c538 r4:c0974d78
[ 9.566040] [<c00a885c>] (generic_handle_irq+0x0/0x4c) from [<c00145a8>] (handle_IRQ+0x54/0xb4)
[ 9.575164] [<c0014554>] (handle_IRQ+0x0/0xb4) from [<c00084d0>] (gic_handle_irq+0x2c/0x60)
[ 9.583892] r8:00000000 r7:d24fbb2c r6:d24fbaf8 r5:c0973a40 r4:fa212000
[ 9.590789] r3:0000002a
[ 9.593536] [<c00084a4>] (gic_handle_irq+0x0/0x60) from [<c0687f00>] (__irq_svc+0x40/0x70)
[ 9.602203] Exception stack(0xd24fbaf8 to 0xd24fbb40)
[ 9.607482] bae0: c0a05740 c0a05740
[ 9.616058] bb00: 00000000 00000000 00000082 c094c538 d24fa000 0000001e 00000000 d24fa000
[ 9.624633] bb20: d24fbd60 d24fbb84 d24fbb88 d24fbb40 c004de68 c004d7a8 20000113 ffffffff
[ 9.633209] r6:ffffffff r5:20000113 r4:c004d7a8 r3:c004de68
[ 9.639160] [<c004d748>] (__do_softirq+0x0/0x25c) from [<c004de68>] (irq_exit+0x98/0xa0)
[ 9.647644] [<c004ddd0>] (irq_exit+0x0/0xa0) from [<c00145ac>] (handle_IRQ+0x58/0xb4)
[ 9.655853] r4:c0974d78 r3:fa212000
[ 9.659606] [<c0014554>] (handle_IRQ+0x0/0xb4) from [<c00084d0>] (gic_handle_irq+0x2c/0x60)
[ 9.668365] r8:d2409000 r7:d24fbc1c r6:d24fbbe8 r5:c0973a40 r4:fa212000
[ 9.675231] r3:0000001e
[ 9.677978] [<c00084a4>] (gic_handle_irq+0x0/0x60) from [<c0687f00>] (__irq_svc+0x40/0x70)
[ 9.686645] Exception stack(0xd24fbbe8 to 0xd24fbc30)
[ 9.691955] bbe0: e09a0000 0000fe44 00000001 c0973a1c e09a0000 0000fe44
[ 9.700500] bc00: 00000001 00000000 d2409000 d24fa000 d24fbd60 d24fbc4c d24fbc50 d24fbc30
[ 9.709075] bc20: bf01f460 bf001e8c a0000113 ffffffff
[ 9.714385] r6:ffffffff r5:a0000113 r4:bf001e8c r3:bf01f460
[ 9.720397] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf01f460>] (SysEnableSGXInterrupts+0x48/0x5c
[ 9.734069] r6:bf0433c4 r5:bf0432a8 r4:bf043310 r3:00000002
[ 9.740081] [<bf01f418>] (SysEnableSGXInterrupts+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf021168>] (EnableSGXClocks+0x58/0x98
[ 9.754028] r5:bf043310 r4:00000000
[ 9.757873] [<bf021110>] (EnableSGXClocks+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf01f71c>] (SysDevicePostPowerState+0x38/0x40
[ 9.771911] r6:00000000 r5:00000000 r4:d247d700
[ 9.776824] [<bf01f6e4>] (SysDevicePostPowerState+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf01345c>]
[ 9.792816] [<bf013400>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf012b60>]
[ 9.810394] r6:bf013400 r5:d24fbce8 r4:00000000 r3:d247d700
[ 9.816436] [<bf012b24>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x0/0x60 [pvrsrvkm_sgx544_116]) from [<bf0137b0>]
[ 9.833190] r3:00000000 r2:00000000 r1:bf013400
[ 9.838043] r6:bf04330c r5:00000000 r4:00000000
[ 9.842987] [<bf013744>] (PVRSRVSetDevicePowerStateKM+0x0/0xd4 [pvrsrvkm_sgx544_116]) from [<bf0291e4>]
[ 9.858184] r7:00000006 r6:d2aa9ac0 r5:ffffffff r4:00000000
[ 9.864227] [<bf029194>] (SGXScheduleCCBCommandKM+0x0/0x124 [pvrsrvkm_sgx544_116]) from [<bf026680>] (SGXGetMiscInfoUkernel
[ 9.879058] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck
[ 9.893707] [<bf02674c>] (SGXDevInitCompatCheck+0x0/0x514 [pvrsrvkm_sgx544_116]) from [<bf0142fc>]
[ 9.909759] r8:e0989000 r7:e0988000 r6:00000000 r5:d2aa9ac0 r4:bf02674c
[ 9.916870] [<bf0142d8>] (PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf012908>]
[ 9.934539] r5:bf0142d8 r4:00000000
[ 9.938354] [<bf0128e4>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x0/0x4c [pvrsrvkm_sgx544_116]) from [<bf0149d0>]
[ 9.954406] r5:bf0433c4 r4:00000000
[ 9.958221] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 9.972900] r5:e0989000 r4:e0988000
[ 9.976715] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
[ 9.991210] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 9.997222] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
[ 10.011596] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 10.018676] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 10.030639] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 10.037506] r4:d2b9e380
[ 10.040252] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 10.048828] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 10.055694] r4:d2a41380
[ 10.058441] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 10.067199] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 10.074249] Board Information:
[ 10.074249] Revision : 0000
[ 10.074279] Serial : 0000000000000000
[ 10.074279] SoC Information:
[ 10.074279] CPU : OMAP5432
[ 10.074279] Rev : ES2.0
[ 10.074279] Type : GP
[ 10.074279] Production ID: D0110451-2E6604F0
[ 10.074279] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 10.074279]
[ 10.107299] ---[ end trace 08852b99bf1c02ec ]---
[ 10.112670] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx1 addr 0x3c
[ 10.112731] ------------[ cut here ]------------
[ 10.112731] WARNING: at arch/arm/mach-omap2ystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 10.128997] r5:e0989000 r4:e0988000
[ 10.129089] [<bf01cd68>084d0>] (gic_handle_irq+0x2c/0x60)
<4>[ 10.145843] r8:d2409000 r7:d24fbbbc r6:d24fbb88 r5:c0973a40 r4:fa212000
<4>[ 10.145843] r3:0000002a
[ 10.145874] [<c00084a4>] (gic_han544_116]) from [<bf01e7b4>] (BridgedDispatchKM+0x8c/0x24c [pvrsrvkm_sgx544_116])
[ 10.162597] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 10.162658] [<bf01e728>][pvrsrvkm_sgx544_116])
<4>[ 10.178466] r6:00000c54 r5:d2409000 r4:00000c50 r3:000f4240
<4>[ 10.178558] [<bf028de8>] (SGXReset+0x0/0x138 [pvrsrvkm_sgx544_116]) from [<bf027a70>] (SGXvrsrvkm_sgx544_116]) from
[ 10.195678] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 10.195678] r4:d2b9e380
[ etMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck+0xb0/0x514 [pvrsrvkm_sgx544_116])
[ 10.211761] [<bf02674c>] (SGXDevInitCompatCheck[ 10.227874]
<4>[ 10.227874] ---[ end trace 08852b99bf1c032f ]---
<4>[ 10.227874] ------------[ cut here ]------------
[ 10.227874] WARNING: at arch/arm/mach-omap2/omap_l3_n842] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116])
[ 10.244934] [<bf02674c>60925] Production ID: D0110451-2E6604F0
<4>[ 10.260925] Die ID : 1CA80121-00000503-015D6074-0A00C00E
<4>[ 10.260925]
<4>[ 10.260925] ---[ end trace 08852b99bf1c0342 ]-- bf001e88 60000113 ffffffff
[ 10.277374] r6:ffffffff r5:60000113 r4:bf001e88 r3:bf0270b0
[ 10.277435] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf02700000000 r7:0000008e r6:00000000 r5:d2a41380
r4:c01c6749
[ 10.293975] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_iocc d24fbc00
d24fbbe0 bf0270b0 bf001e88 60000113 ffffffff
[ 10.309692] r6:ffffffff r5:60000113 r4:bf001e88 r3:bf0270b0
[ 10.309753] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx5444_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM+0xe8/0x44c
[ 10.326904] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 10.3000005c4 e0b34010 e09a0000 00008ba0 000005c4 d2409000 d2409000 d24fa000
<4>[ 10.342681] bbc0: d24fbd60 d24fbbfc d24fbc00 d24fbbe0 bf0270b0 bf001e88 60000113 ffffffff
[ 10.342712] r6:ffffffff r5:60000113 r4:bf001e88 r3:bf0270b0
[ 10.342773] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf0270b0>] (SGXRunScript+0x94/0xa8
[ 10.342773] r6:00000040 r5:d2409610 r4:0000002a r3:e0b34010
[ 10.342864] [<bf02701c>] (SGXRunScript+0x0/0xa8 [pvrsrvkm_sgx544_116]) from [<bf027aa0>] (SGXInitialise+0x80/0x1c4
[ 10.342864] r7:00000000 r6:e0b36160 r5:00000000 r4:d2409000
[ 10.342956] [<bf027a20>] (SGXInitialise+0x0/0x1c4 [pvrsrvkm_sgx544_116]) from [<bf028c44>] (SGXPostPowerState+0xbc/0x150
[ 10.342956] r7:00000002 r6:d2409000 r5:00000000 r4:00000000
[ 10.343048] [<bf028b88>] (SGXPostPowerState+0x0/0x150 [pvrsrvkm_sgx544_116]) from [<bf013480>]
(PVRSRVDevicePostPowerStateKM_AnyVaCb+0x80/0x98 [pvrsrvkm_sgx544_116])
[ 10.343048] r7:00000000 r6:00000000 r5:00000000 r4:d247d700
[ 10.343109] [<bf013400>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf012b60>]
[ 10.343139] r6:bf013400 r5:d24fbce8 r4:00000000 r3:d247d700
[ 10.343200] [<bf012b24>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x0/0x60 [pvrsrvkm_sgx544_116]) from [<bf0137b0>]
[ 10.343200] r3:00000000 r2:00000000 r1:bf013400
[ 10.343231] r6:bf04330c r5:00000000 r4:00000000
[ 10.343292] [<bf013744>] (PVRSRVSetDevicePowerStateKM+0x0/0xd4 [pvrsrvkm_sgx544_116]) from [<bf0291e4>]
[ 10.343292] r7:00000006 r6:d2aa9ac0 r5:ffffffff r4:00000000
[ 10.343383] [<bf029194>] (SGXScheduleCCBCommandKM+0x0/0x124 [pvrsrvkm_sgx544_116]) from [<bf026680>] (SGXGetMiscInfoUkernel
[ 10.343475] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck
[ 10.343536] [<bf02674c>] (SGXDevInitCompatCheck+0x0/0x514 [pvrsrvkm_sgx544_116]) from [<bf0142fc>]
[ 10.343536] r8:e0989000 r7:e0988000 r6:00000000 r5:d2aa9ac0 r4:bf02674c
[ 10.343627] [<bf0142d8>] (PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf012908>]
[ 10.343627] r5:bf0142d8 r4:00000000
[ 10.343688] [<bf0128e4>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x0/0x4c [pvrsrvkm_sgx544_116]) from [<bf0149d0>]
[ 10.343719] r5:bf0433c4 r4:00000000
[ 10.343780] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 10.343780] r5:e0989000 r4:e0988000
[ 10.343872] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
[ 10.343872] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 10.343933] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
[ 10.343963] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 10.343994] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 10.343994] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 10.343994] r4:d2b9e380
[ 10.344024] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 10.344024] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 10.344024] r4:d2a41380
[ 10.344055] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 10.344055] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 10.344055] Board Information:
[ 10.344085] Revision : 0000
[ 10.344085] Serial : 0000000000000000
[ 10.344085] SoC Information:
[ 10.344085] CPU : OMAP5432
[ 10.344085] Rev : ES2.0
[ 10.344085] Type : GP
[ 10.344085] Production ID: D0110451-2E6604F0
[ 10.344085] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 10.344116]
[ 10.344116] ---[ end trace 08852b99bf1c0372 ]---
[ 10.344116] ------------[ cut here ]------------
[ 10.344116] WARNING: at arch/arm/mach-omap2/omap4-common.c:262 axi_error_handler+0x34/0x64()
[ 10.344146]
[ 10.344146] AXI error with Local pheripheral
[ 10.344146] Modules linked in: pvrsrvkm_sgx544_116(O)
[ 10.344146] Backtrace:
[ 10.344146] [<c0017c14>] (dump_backtrace+0x0/0x10c) from [<c067cfc4>] (dump_stack+0x18/0x1c)
[ 10.344177] r6:00000106 r5:c002977c r4:d24fba90 r3:00000000
[ 10.344177] [<c067cfac>] (dump_stack+0x0/0x1c) from [<c0046a54>] (warn_slowpath_common+0x54/0x6c)
[ 10.344207] [<c0046a00>] (warn_slowpath_common+0x0/0x6c) from [<c0046b10>] (warn_slowpath_fmt+0x38/0x40)
[ 10.344207] r8:00000000 r7:00000023 r6:00000023 r5:c0951c50 r4:d409a380
[ 10.344207] r3:00000009
[ 10.344238] [<c0046ad8>] (warn_slowpath_fmt+0x0/0x40) from [<c002977c>] (axi_error_handler+0x34/0x64)
[ 10.344238] r3:20000000 r2:c0822be0
[ 10.344238] [<c0029748>] (axi_error_handler+0x0/0x64) from [<c00a90bc>] (handle_irq_event_percpu+0x80/0x2e4)
[ 10.344268] [<c00a903c>] (handle_irq_event_percpu+0x0/0x2e4) from [<c00a9364>] (handle_irq_event+0x44/0x64)
[ 10.344268] [<c00a9320>] (handle_irq_event+0x0/0x64) from [<c00ac074>] (handle_fasteoi_irq+0xc4/0x16c)
[ 10.344268] r6:d24fa000 r5:c0951c50 r4:c0951c00 r3:00000000
[ 10.344299] [<c00abfb0>] (handle_fasteoi_irq+0x0/0x16c) from [<c00a8894>] (generic_handle_irq+0x38/0x4c)
[ 10.344299] r5:c094c538 r4:c0974d78
[ 10.344299] [<c00a885c>] (generic_handle_irq+0x0/0x4c) from [<c00145a8>] (handle_IRQ+0x54/0xb4)
[ 10.344329] [<c0014554>] (handle_IRQ+0x0/0xb4) from [<c00084d0>] (gic_handle_irq+0x2c/0x60)
[ 10.344329] r8:d2409000 r7:d24fbbcc r6:d24fbb98 r5:c0973a40 r4:fa212000
[ 10.344329] r3:00000023
[ 10.344360] [<c00084a4>] (gic_handle_irq+0x0/0x60) from [<c0687f00>] (__irq_svc+0x40/0x70)
[ 10.344360] Exception stack(0xd24fbb98 to 0xd24fbbe0)
[ 10.344360] bb80: e09a0000 00000bb4
[ 10.344360] bba0: 00000000 e0b34010 e09a0000 00000bb4 00000000 d2409000 d2409000 d24fa000
[ 10.344390] bbc0: d24fbd60 d24fbbfc d24fbc00 d24fbbe0 bf0270b0 bf001e88 60000113 ffffffff
[ 10.344390] r6:ffffffff r5:60000113 r4:bf001e88 r3:bf0270b0
[ 10.344451] [<bf001e6c>] (OSWriteHWReg+0x0/0x40 [pvrsrvkm_sgx544_116]) from [<bf0270b0>] (SGXRunScript+0x94/0xa8
[ 10.344451] r6:00000040 r5:d240961c r4:0000002b r3:e0b34010
[ 10.344543] [<bf02701c>] (SGXRunScript+0x0/0xa8 [pvrsrvkm_sgx544_116]) from [<bf027aa0>] (SGXInitialise+0x80/0x1c4
[ 10.344543] r7:00000000 r6:e0b36160 r5:00000000 r4:d2409000
[ 10.344635] [<bf027a20>] (SGXInitialise+0x0/0x1c4 [pvrsrvkm_sgx544_116]) from [<bf028c44>] (SGXPostPowerState+0xbc/0x150
[ 10.344635] r7:00000002 r6:d2409000 r5:00000000 r4:00000000
[ 10.344726] [<bf028b88>] (SGXPostPowerState+0x0/0x150 [pvrsrvkm_sgx544_116]) from [<bf013480>]
[ 10.344726] r7:00000000 r6:00000000 r5:00000000 r4:d247d700
[ 10.344818] [<bf013400>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf012b60>]
[ 10.344818] r6:bf013400 r5:d24fbce8 r4:00000000 r3:d247d700
[ 10.344879] [<bf012b24>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x0/0x60 [pvrsrvkm_sgx544_116]) from [<bf0137b0>]
[ 10.344879] r3:00000000 r2:00000000 r1:bf013400
[ 10.344909] r6:bf04330c r5:00000000 r4:00000000
[ 10.344970] [<bf013744>] (PVRSRVSetDevicePowerStateKM+0x0/0xd4 [pvrsrvkm_sgx544_116]) from [<bf0291e4>]
[ 10.345001] r7:00000006 r6:d2aa9ac0 r5:ffffffff r4:00000000
[ 10.345062] [<bf029194>] (SGXScheduleCCBCommandKM+0x0/0x124 [pvrsrvkm_sgx544_116]) from [<bf026680>] (SGXGetMiscInfoUkernel
[ 10.345153] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck
[ 10.345214] [<bf02674c>] (SGXDevInitCompatCheck+0x0/0x514 [pvrsrvkm_sgx544_116]) from [<bf0142fc>]
[ 10.345245] r8:e0989000 r7:e0988000 r6:00000000 r5:d2aa9ac0 r4:bf02674c
[ 10.345306] [<bf0142d8>] (PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf012908>]
[ 10.345306] r5:bf0142d8 r4:00000000
[ 10.345397] [<bf0128e4>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x0/0x4c [pvrsrvkm_sgx544_116]) from [<bf0149d0>]
[ 10.345397] r5:bf0433c4 r4:00000000
[ 10.345458] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 10.345489] r5:e0989000 r4:e0988000
[ 10.345550] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
[ 10.345550] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 10.345642] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
[ 10.345642] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 10.345672] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 10.345672] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 10.345703] r4:d2b9e380
[ 10.345703] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 10.345703] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 10.345733] r4:d2a41380
[ 10.345733] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 10.345733] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 10.345764] Board Information:
[ 10.345764] Revision : 0000
[ 10.345764] Serial : 0000000000000000
[ 10.345764] SoC Information:
[ 10.345764] CPU : OMAP5432
[ 10.345764] Rev : ES2.0
[ 10.345764] Type : GP
[ 10.345794] Production ID: D0110451-2E6604F0
[ 10.345794] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 10.345794]
[ 10.345794] ---[ end trace 08852b99bf1c0373 ]---0000 (Unknown)
[ 11.366210] PVR_K: (MKT-167) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366210] PVR_K: (MKT-168) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366210] PVR_K: (MKT-169) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366241] PVR_K: (MKT-16A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366241] PVR_K: (MKT-16B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366271] PVR_K: (MKT-16C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366271] PVR_K: (MKT-16D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366271] PVR_K: (MKT-16E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366302] PVR_K: (MKT-16F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366302] PVR_K: (MKT-170) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366302] PVR_K: (MKT-171) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366333] PVR_K: (MKT-172) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366333] PVR_K: (MKT-173) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366363] PVR_K: (MKT-174) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366363] PVR_K: (MKT-175) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366363] PVR_K: (MKT-176) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366394] PVR_K: (MKT-177) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366394] PVR_K: (MKT-178) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366394] PVR_K: (MKT-179) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366424] PVR_K: (MKT-17A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366424] PVR_K: (MKT-17B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366424] PVR_K: (MKT-17C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366455] PVR_K: (MKT-17D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366455] PVR_K: (MKT-17E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366485] PVR_K: (MKT-17F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366485] PVR_K: (MKT-180) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366485] PVR_K: (MKT-181) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366516] PVR_K: (MKT-182) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366516] PVR_K: (MKT-183) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366516] PVR_K: (MKT-184) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366546] PVR_K: (MKT-185) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366546] PVR_K: (MKT-186) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366577] PVR_K: (MKT-187) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366577] PVR_K: (MKT-188) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366577] PVR_K: (MKT-189) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366607] PVR_K: (MKT-18A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366607] PVR_K: (MKT-18B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366607] PVR_K: (MKT-18C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366638] PVR_K: (MKT-18D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366638] PVR_K: (MKT-18E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366638] PVR_K: (MKT-18F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366668] PVR_K: (MKT-190) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366668] PVR_K: (MKT-191) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366699] PVR_K: (MKT-192) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366699] PVR_K: (MKT-193) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366699] PVR_K: (MKT-194) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366729] PVR_K: (MKT-195) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366729] PVR_K: (MKT-196) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366729] PVR_K: (MKT-197) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366760] PVR_K: (MKT-198) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366760] PVR_K: (MKT-199) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366760] PVR_K: (MKT-19A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366790] PVR_K: (MKT-19B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366790] PVR_K: (MKT-19C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366821] PVR_K: (MKT-19D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366821] PVR_K: (MKT-19E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366821] PVR_K: (MKT-19F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366851] PVR_K: (MKT-1A0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366851] PVR_K: (MKT-1A1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366851] PVR_K: (MKT-1A2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366882] PVR_K: (MKT-1A3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366882] PVR_K: (MKT-1A4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366912] PVR_K: (MKT-1A5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366912] PVR_K: (MKT-1A6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366912] PVR_K: (MKT-1A7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366943] PVR_K: (MKT-1A8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366943] PVR_K: (MKT-1A9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366943] PVR_K: (MKT-1AA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366973] PVR_K: (MKT-1AB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366973] PVR_K: (MKT-1AC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367004] PVR_K: (MKT-1AD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367004] PVR_K: (MKT-1AE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367004] PVR_K: (MKT-1AF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367034] PVR_K: (MKT-1B0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367034] PVR_K: (MKT-1B1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367034] PVR_K: (MKT-1B2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367065] PVR_K: (MKT-1B3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367065] PVR_K: (MKT-1B4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367095] PVR_K: (MKT-1B5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367095] PVR_K: (MKT-1B6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367095] PVR_K: (MKT-1B7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367126] PVR_K: (MKT-1B8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367126] PVR_K: (MKT-1B9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367126] PVR_K: (MKT-1BA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367156] PVR_K: (MKT-1BB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367156] PVR_K: (MKT-1BC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367156] PVR_K: (MKT-1BD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367187] PVR_K: (MKT-1BE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367187] PVR_K: (MKT-1BF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367218] PVR_K: (MKT-1C0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367218] PVR_K: (MKT-1C1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367218] PVR_K: (MKT-1C2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367248] PVR_K: (MKT-1C3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367248] PVR_K: (MKT-1C4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367248] PVR_K: (MKT-1C5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367279] PVR_K: (MKT-1C6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367279] PVR_K: (MKT-1C7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367309] PVR_K: (MKT-1C8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367309] PVR_K: (MKT-1C9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367309] PVR_K: (MKT-1CA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367340] PVR_K: (MKT-1CB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367340] PVR_K: (MKT-1CC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367340] PVR_K: (MKT-1CD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367370] PVR_K: (MKT-1CE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367370] PVR_K: (MKT-1CF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367401] PVR_K: (MKT-1D0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367401] PVR_K: (MKT-1D1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367401] PVR_K: (MKT-1D2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367431] PVR_K: (MKT-1D3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367431] PVR_K: (MKT-1D4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367431] PVR_K: (MKT-1D5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367462] PVR_K: (MKT-1D6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367462] PVR_K: (MKT-1D7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367492] PVR_K: (MKT-1D8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367492] PVR_K: (MKT-1D9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367492] PVR_K: (MKT-1DA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367523] PVR_K: (MKT-1DB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367523] PVR_K: (MKT-1DC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367523] PVR_K: (MKT-1DD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367553] PVR_K: (MKT-1DE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367553] PVR_K: (MKT-1DF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367553] PVR_K: (MKT-1E0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367584] PVR_K: (MKT-1E1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367584] PVR_K: (MKT-1E2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367614] PVR_K: (MKT-1E3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367614] PVR_K: (MKT-1E4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367614] PVR_K: (MKT-1E5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367645] PVR_K: (MKT-1E6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367645] PVR_K: (MKT-1E7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367645] PVR_K: (MKT-1E8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367675] PVR_K: (MKT-1E9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367675] PVR_K: (MKT-1EA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367706] PVR_K: (MKT-1EB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367706] PVR_K: (MKT-1EC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367706] PVR_K: (MKT-1ED) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367736] PVR_K: (MKT-1EE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367736] PVR_K: (MKT-1EF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367736] PVR_K: (MKT-1F0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367767] PVR_K: (MKT-1F1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367767] PVR_K: (MKT-1F2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367797] PVR_K: (MKT-1F3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367797] PVR_K: (MKT-1F4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367797] PVR_K: (MKT-1F5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367828] PVR_K: (MKT-1F6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367828] PVR_K: (MKT-1F7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367828] PVR_K: (MKT-1F8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367858] PVR_K: (MKT-1F9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367858] PVR_K: (MKT-1FA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367889] PVR_K: (MKT-1FB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367889] PVR_K: (MKT-1FC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367889] PVR_K: (MKT-1FD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367919] PVR_K: (MKT-1FE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367919] PVR_K: (MKT-1FF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.367919] PVR_K: SGX Kernel CCB WO:0x0 RO:0x0
[ 11.367950] ------------[ cut here ]------------
[ 11.367950] Kernel BUG at bf027ba8 [verbose debug info unavailable]
[ 11.367950] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[ 11.367950] Modules linked in: pvrsrvkm_sgx544_116(O)
[ 11.367980] CPU: 0 Tainted: G W O (3.4.34-01535-g499e8d5-dirty #1)
[ 11.368011] PC is at SGXInitialise+0x188/0x1c4 [pvrsrvkm_sgx544_116]
[ 11.368041] LR is at LinuxUnLockMutex+0x10/0x14 [pvrsrvkm_sgx544_116]
[ 11.368072] pc : [<bf027ba8>] lr : [<bf007d10>] psr: 60000113
[ 11.368072] sp : d24fbc28 ip : 00000000 fp : d24fbc4c
[ 11.368072] r10: d24fbd60 r9 : d24fa000 r8 : d2409000
[ 11.368072] r7 : c0973a1c r6 : 00000000 r5 : 00000000 r4 : d2409000
[ 11.368103] r3 : 60000113 r2 : 00000001 r1 : 00000000 r0 : bf03ec50
[ 11.368103] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 11.368103] Control: 10c5387d Table: 9252c06a DAC: 00000015
[ 11.368103]
[ 11.368103] SP: 0xd24fbba8:
[ 11.368133] bba8 00000001 60000113 d2409000 00000000 00000000 c0973a1c d2409000 d24fa000
[ 11.368133] bbc8 d24fbd60 d24fbc4c 00000000 d24fbc28 bf007d10 bf027ba8 60000113 ffffffff
[ 11.368164] bbe8 00000000 e0b34000 00000000 00000000 bf03ba00 00000000 d2409000 00000000
[ 11.368164] bc08 00000000 c0973a1c d2409000 d24fbd60 d24fbc4c d24fbc28 bf027ba8 bf0275dc
[ 11.368194] bc28 00000032 00000000 00000000 00000000 d2409000 00000002 d24fbc9c d24fbc50
[ 11.368194] bc48 bf028c44 bf027a2c e59ff018 00000001 d247d700 00000000 00000000 00000000
[ 11.368225] bc68 d2409000 d24fa000 d24fbd60 d24fbc9c d24fbc30 d24fbc90 d247d700 00000000
[ 11.368225] bc88 00000000 00000000 d24fbcbc d24fbca0 bf013480 bf028b94 d247d700 00000000
[ 11.368255]
[ 11.368255] FP: 0xd24fbbcc:
[ 11.368255] bbcc d24fbc4c 00000000 d24fbc28 bf007d10 bf027ba8 60000113 ffffffff 00000000
[ 11.368286] bbec e0b34000 00000000 00000000 bf03ba00 00000000 d2409000 00000000 00000000
[ 11.368286] bc0c c0973a1c d2409000 d24fbd60 d24fbc4c d24fbc28 bf027ba8 bf0275dc 00000032
[ 11.368316] bc2c 00000000 00000000 00000000 d2409000 00000002 d24fbc9c d24fbc50 bf028c44
[ 11.368316] bc4c bf027a2c e59ff018 00000001 d247d700 00000000 00000000 00000000 d2409000
[ 11.368347] bc6c d24fa000 d24fbd60 d24fbc9c d24fbc30 d24fbc90 d247d700 00000000 00000000
[ 11.368347] bc8c 00000000 d24fbcbc d24fbca0 bf013480 bf028b94 d247d700 00000000 d24fbce8
[ 11.368377] bcac bf013400 d24fbce0 d24fbcc0 bf012b60 bf01340c bf0201ac d24fbce8 00000000
[ 11.368377]
[ 11.368377] R4: 0xd2408f80:
[ 11.368377] 8f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.368408] 8fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.368408] 8fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.368438] 8fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.368438] 9000 00000007 00000000 00000000 00000000 00000000 e09a0000 00000000 56000000
[ 11.368469] 9020 0000ffff 1fb5ad00 00081e20 00000001 00000000 b3e32000 0000000b d2acc000
[ 11.368469] 9040 d2a86ec0 e0b2fa068>] (l3_interrupt_handler+0xc0/0x168)
[ 10.352203] r3:c082d8a0 r2:c082d7c0
[ 10.352203] [<c0039fa8>] (l3_interrupt_handler+0x0/0x168) from [<c00a90bc>] (handle_irq_event_percpu+0x80/0x2e4)
[ 10.352203] r8:00000000 r7:0000002a r6:0000002a r5:c0952190 r4:d40aeb40
[ 10.352233] [<c00a903c>] (handle_irq_event_percpu+0x0/0x2e4) from [<c00a9364>] (handle_irq_event+0x44/0x64)
[ 10.352233] [<c00a9320>] (handle_irq_event+0x0/0x64) from [<c00ac074>] (handle_fasteoi_irq+0xc4/0x16c)
[ 10.352233] r6:d24fa000 r5:c0952190 r4:c0952140 r3:00000000
[ 10.352264] [<c00abfb0>] (handle_fasteoi_irq+0x0/0x16c) from [<c00a8894>] (generic_handle_irq+0x38/0x4c)
[ 10.352264] r5:c094c538 r4:c0974d78
[ 10.352264] [<c00a885c>] (generic_handle_irq+0x0/0x4c) from [<c00145a8>] (handle_IRQ+0x54/0xb4)
[ 10.352294] [<c0014554>] (handle_IRQ+0x0/0xb4) from [<c00084d0>] (gic_handle_irq+0x2c/0x60)
[ 10.352294] r8:d2409000 r7:d24fbc14 r6:d24fbbe0 r5:c0973a40 r4:fa212000
[ 10.352294] r3:0000002a
[ 10.352325] [<c00084a4>] (gic_handle_irq+0x0/0x60) from [<c0687f00>] (__irq_svc+0x40/0x70)
[ 10.352325] Exception stack(0xd24fbbe0 to 0xd24fbc28)
[ 10.352325] bbe0: e09a0000 410d8500 e59ff018 fe40d000 d2409000 00000000 e0b36160 c0973a1c
[ 10.352355] bc00: d2409000 d24fa000 d24fbd60 d24fbc4c d24fbc08 d24fbc28 bf001ea0 bf027ae4
[ 10.352355] bc20: a0000113 ffffffff
[ 10.352355] r6:ffffffff r5:a0000113 r4:bf027ae4 r3:bf001ea0
[ 10.352447] [<bf027a20>] (SGXInitialise+0x0/0x1c4 [pvrsrvkm_sgx544_116]) from [<bf028c44>] (SGXPostPowerState+0xbc/0x150
[ 10.352447] r7:00000002 r6:d2409000 r5:00000000 r4:00000000
[ 10.352539] [<bf028b88>] (SGXPostPowerState+0x0/0x150 [pvrsrvkm_sgx544_116]) from [<bf013480>]
[ 10.352539] r7:00000000 r6:00000000 r5:00000000 r4:d247d700
[ 10.352600] [<bf013400>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x0/0x98 [pvrsrvkm_sgx544_116]) from [<bf012b60>]
[ 10.352630] r6:bf013400 r5:d24fbce8 r4:00000000 r3:d247d700
[ 10.352691] [<bf012b24>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x0/0x60 [pvrsrvkm_sgx544_116]) from [<bf0137b0>]
[ 10.352691] r3:00000000 r2:00000000 r1:bf013400
[ 10.352691] r6:bf04330c r5:00000000 r4:00000000
[ 10.352783] [<bf013744>] (PVRSRVSetDevicePowerStateKM+0x0/0xd4 [pvrsrvkm_sgx544_116]) from [<bf0291e4>]
[ 10.352783] r7:00000006 r6:d2aa9ac0 r5:ffffffff r4:00000000
[ 10.352874] [<bf029194>] (SGXScheduleCCBCommandKM+0x0/0x124 [pvrsrvkm_sgx544_116]) from [<bf026680>] (SGXGetMiscInfoUkernel
[ 10.352966] [<bf026604>] (SGXGetMiscInfoUkernel+0x0/0x148 [pvrsrvkm_sgx544_116]) from [<bf0267fc>] (SGXDevInitCompatCheck
[ 10.353027] [<bf02674c>] (SGXDevInitCompatCheck+0x0/0x514 [pvrsrvkm_sgx544_116]) from [<bf0142fc>]
[ 10.353027] r8:e0989000 r7:e0988000 r6:00000000 r5:d2aa9ac0 r4:bf02674c
[ 10.353118] [<bf0142d8>] (PVRSRVFinaliseSystem_CompatCheck_AnyCb+0x0/0x5c [pvrsrvkm_sgx544_116]) from [<bf012908>]
[ 10.353118] r5:bf0142d8 r4:00000000
[ 10.353179] [<bf0128e4>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x0/0x4c [pvrsrvkm_sgx544_116]) from [<bf0149d0>]
[ 10.353210] r5:bf0433c4 r4:00000000
[ 10.353271] [<bf01496c>] (PVRSRVFinaliseSystem+0x0/0xbc [pvrsrvkm_sgx544_116]) from [<bf01cdc0>] (PVRSRVInitSrvDisconnectBW
[ 10.353271] r5:e0989000 r4:e0988000
[ 10.353363] [<bf01cd68>] (PVRSRVInitSrvDisconnectBW+0x0/0x84 [pvrsrvkm_sgx544_116]) from [<bf01e7b4>] (BridgedDispatchKM
[ 10.353363] r6:bf043154 r5:d247df00 r4:d24fbeac r3:d247df00
[ 10.353424] [<bf01e728>] (BridgedDispatchKM+0x0/0x24c [pvrsrvkm_sgx544_116]) from [<bf005840>] (PVRSRV_BridgeDispatchKM
[ 10.353454] r8:00000000 r7:0000008e r6:00000000 r5:d2a41380 r4:c01c6749
[ 10.353485] [<bf005758>] (PVRSRV_BridgeDispatchKM+0x0/0x44c [pvrsrvkm_sgx544_116]) from [<c0123e6c>] (do_vfs_ioctl+0x8c/0x5dc)
[ 10.353485] r9:d24fa000 r8:00000000 r7:0000000d r6:bec3c884 r5:d2a41380
[ 10.353485] r4:d2b9e380
[ 10.353515] [<c0123de0>] (do_vfs_ioctl+0x0/0x5dc) from [<c0124434>] (sys_ioctl+0x78/0x80)
[ 10.353515] r9:d24fa000 r8:00000000 r7:0000000d r6:c01c6749 r5:bec3c884
[ 10.353515] r4:d2a41380
[ 10.353546] [<c01243bc>] (sys_ioctl+0x0/0x80) from [<c0013680>] (ret_fast_syscall+0x0/0x30)
[ 10.353546] r8:c0013848 r7:00000036 r6:00000001 r5:bec3c8d8 r4:00de5038
[ 10.353546] Board Information:
[ 10.353576] Revision : 0000
[ 10.353576] Serial : 0000000000000000
[ 10.353576] SoC Information:
[ 10.353576] CPU : OMAP5432
[ 10.353576] Rev : ES2.0
[ 10.353576] Type : GP
[ 10.353576] Production ID: D0110451-2E6604F0
[ 10.353576] Die ID : 1CA80121-00000503-015D6074-0A00C00E
[ 10.353607]
[ 10.353607] ---[ end trace 08852b99bf1c0378 ]---
[ 11.361572] PVR_K:(Error): PollForValueKM: Timeout. Expected 0x1 but found 0x0 (mask 0x1). [0, ]
[ 11.361602] PVR_K:(Error): SGXInitialise: Wait for uKernel initialisation failed [0, ]
[ 11.361633] ACTIVE COMPOSITIONS on lcd
[ 11.361633]
[ 11.361633] DISPC pipeline:
[ 11.361633]
[ 11.361633] user_info: clean (none)
[ 11.361633] info: clean (none)
[ 11.361663] shadow: off clean (none)
[ 11.361663] dispc: (none)
[ 11.361663]
[ 11.361663] ACTIVE COMPOSITIONS on tv
[ 11.361663]
[ 11.361663] DISPC pipeline:
[ 11.361663]
[ 11.361663] user_info: clean (none)
[ 11.361663] info: clean (none)
[ 11.361694] shadow: off clean (none)
[ 11.361694] dispc: (none)
[ 11.361694]
[ 11.361694] ACTIVE COMPOSITIONS on lcd2
[ 11.361694]
[ 11.361694] DISPC pipeline:
[ 11.361694]
[ 11.361694] user_info: clean (none)
[ 11.361724] info: clean (none)
[ 11.361724] shadow: off clean (none)
[ 11.361724] dispc: (none)
[ 11.361724]
[ 11.361724] ACTIVE GRALLOC FLIPS
[ 11.361724]
[ 11.361724]
[ 11.361755] PVR_K: SGX debug (SGX_DDK_Android sgxddk 19 1.9@2166536)
[ 11.361755] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 11.361755] PVR_K: Flip Command Complete Data 1 for display device 1:
[ 11.361785] PVR_K: SGX Host control:
[ 11.361785] PVR_K: (HC-0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361785] PVR_K: (HC-10) 0x00000000 0x0000000A 0x00081E20 0x00000003
[ 11.361816] PVR_K: (HC-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361816] PVR_K: (HC-30) 0x00000000 0xEEB2F170 0x00000000 0x00000000
[ 11.361816] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361846] PVR_K: (HC-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361846] PVR_K: (HC-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361877] PVR_K: (HC-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361877] PVR_K: (HC-80) 0x00000000 0x00000000 0x00000094 0xE1A0C00D
[ 11.361877] PVR_K: SGX TA/3D control:
[ 11.361907] PVR_K: (T3C-0) 0xF4003000 0xF4003160 0xF4002000 0x00000000
[ 11.361907] PVR_K: (T3C-10) 0x00000000 0x00000002 0x00000000 0x00000000
[ 11.361907] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361938] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361938] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361938] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361968] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361968] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361968] PVR_K: (T3C-80) 0xF4004000 0x00000000 0x0001120F 0x00000000
[ 11.361999] PVR_K: (T3C-90) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.361999] PVR_K: (T3C-A0) 0x00000000 0xF4000000 0xB3E32000 0x00000000
[ 11.361999] PVR_K: (T3C-B0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362030] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362030] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362030] PVR_K: (T3C-E0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362060] PVR_K: (T3C-F0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362060] PVR_K: (T3C-100) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362091] PVR_K: (T3C-110) 0x00000000 0xF2019010 0xF2019014 0xF2019034
[ 11.362091] PVR_K: (T3C-120) 0xF2019030 0xF4007000 0xF4012820 0xF4006020
[ 11.362091] PVR_K: (T3C-130) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362121] PVR_K: (T3C-140) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362121] PVR_K: (T3C-150) 0x00000000 0x00000000 0x00000000 0x00000000
[ 11.362121] PVR_K: Last SGX microkernel status code: 00000000 (Unknown)
[ 11.362152] PVR_K: (MKT-0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362152] PVR_K: (MKT-1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362152] PVR_K: (MKT-2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362182] PVR_K: (MKT-3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362182] PVR_K: (MKT-4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362213] PVR_K: (MKT-5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362213] PVR_K: (MKT-6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362213] PVR_K: (MKT-7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362243] PVR_K: (MKT-8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362243] PVR_K: (MKT-9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362243] PVR_K: (MKT-A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362274] PVR_K: (MKT-B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362274] PVR_K: (MKT-C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362304] PVR_K: (MKT-D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362304] PVR_K: (MKT-E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362304] PVR_K: (MKT-F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362335] PVR_K: (MKT-10) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362335] PVR_K: (MKT-11) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362335] PVR_K: (MKT-12) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362365] PVR_K: (MKT-13) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362365] PVR_K: (MKT-14) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362396] PVR_K: (MKT-15) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362396] PVR_K: (MKT-16) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362396] PVR_K: (MKT-17) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362426] PVR_K: (MKT-18) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362426] PVR_K: (MKT-19) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362426] PVR_K: (MKT-1A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362457] PVR_K: (MKT-1B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362457] PVR_K: (MKT-1C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362457] PVR_K: (MKT-1D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362487] PVR_K: (MKT-1E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362487] PVR_K: (MKT-1F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362518] PVR_K: (MKT-20) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362518] PVR_K: (MKT-21) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362518] PVR_K: (MKT-22) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362548] PVR_K: (MKT-23) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362548] PVR_K: (MKT-24) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362548] PVR_K: (MKT-25) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362579] PVR_K: (MKT-26) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362579] PVR_K: (MKT-27) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362609] PVR_K: (MKT-28) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362609] PVR_K: (MKT-29) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362609] PVR_K: (MKT-2A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362640] PVR_K: (MKT-2B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362640] PVR_K: (MKT-2C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362640] PVR_K: (MKT-2D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362670] PVR_K: (MKT-2E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362670] PVR_K: (MKT-2F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362670] PVR_K: (MKT-30) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362701] PVR_K: (MKT-31) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362701] PVR_K: (MKT-32) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362731] PVR_K: (MKT-33) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362731] PVR_K: (MKT-34) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362731] PVR_K: (MKT-35) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362762] PVR_K: (MKT-36) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362762] PVR_K: (MKT-37) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362762] PVR_K: (MKT-38) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362792] PVR_K: (MKT-39) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362792] PVR_K: (MKT-3A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362823] PVR_K: (MKT-3B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362823] PVR_K: (MKT-3C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362823] PVR_K: (MKT-3D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362854] PVR_K: (MKT-3E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362854] PVR_K: (MKT-3F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362854] PVR_K: (MKT-40) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362884] PVR_K: (MKT-41) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362884] PVR_K: (MKT-42) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362884] PVR_K: (MKT-43) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362915] PVR_K: (MKT-44) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362915] PVR_K: (MKT-45) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362945] PVR_K: (MKT-46) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362945] PVR_K: (MKT-47) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362945] PVR_K: (MKT-48) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362976] PVR_K: (MKT-49) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362976] PVR_K: (MKT-4A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.362976] PVR_K: (MKT-4B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363006] PVR_K: (MKT-4C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363006] PVR_K: (MKT-4D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363037] PVR_K: (MKT-4E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363037] PVR_K: (MKT-4F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363037] PVR_K: (MKT-50) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363067] PVR_K: (MKT-51) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363067] PVR_K: (MKT-52) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363067] PVR_K: (MKT-53) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363098] PVR_K: (MKT-54) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363098] PVR_K: (MKT-55) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363128] PVR_K: (MKT-56) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363128] PVR_K: (MKT-57) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363128] PVR_K: (MKT-58) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363159] PVR_K: (MKT-59) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363159] PVR_K: (MKT-5A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363159] PVR_K: (MKT-5B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363189] PVR_K: (MKT-5C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363189] PVR_K: (MKT-5D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363189] PVR_K: (MKT-5E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363220] PVR_K: (MKT-5F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363220] PVR_K: (MKT-60) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363250] PVR_K: (MKT-61) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363250] PVR_K: (MKT-62) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363250] PVR_K: (MKT-63) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363281] PVR_K: (MKT-64) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363281] PVR_K: (MKT-65) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363281] PVR_K: (MKT-66) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363311] PVR_K: (MKT-67) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363311] PVR_K: (MKT-68) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363342] PVR_K: (MKT-69) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363342] PVR_K: (MKT-6A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363342] PVR_K: (MKT-6B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363372] PVR_K: (MKT-6C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363372] PVR_K: (MKT-6D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363372] PVR_K: (MKT-6E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363403] PVR_K: (MKT-6F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363403] PVR_K: (MKT-70) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363403] PVR_K: (MKT-71) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363433] PVR_K: (MKT-72) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363433] PVR_K: (MKT-73) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363464] PVR_K: (MKT-74) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363464] PVR_K: (MKT-75) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363464] PVR_K: (MKT-76) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363494] PVR_K: (MKT-77) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363494] PVR_K: (MKT-78) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363494] PVR_K: (MKT-79) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363525] PVR_K: (MKT-7A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363525] PVR_K: (MKT-7B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363555] PVR_K: (MKT-7C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363555] PVR_K: (MKT-7D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363555] PVR_K: (MKT-7E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363586] PVR_K: (MKT-7F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363586] PVR_K: (MKT-80) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363586] PVR_K: (MKT-81) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363616] PVR_K: (MKT-82) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363616] PVR_K: (MKT-83) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363647] PVR_K: (MKT-84) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363647] PVR_K: (MKT-85) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363647] PVR_K: (MKT-86) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363677] PVR_K: (MKT-87) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363677] PVR_K: (MKT-88) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363677] PVR_K: (MKT-89) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363708] PVR_K: (MKT-8A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363708] PVR_K: (MKT-8B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363739] PVR_K: (MKT-8C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363739] PVR_K: (MKT-8D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363739] PVR_K: (MKT-8E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363769] PVR_K: (MKT-8F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363769] PVR_K: (MKT-90) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363769] PVR_K: (MKT-91) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363800] PVR_K: (MKT-92) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363800] PVR_K: (MKT-93) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363800] PVR_K: (MKT-94) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363830] PVR_K: (MKT-95) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363830] PVR_K: (MKT-96) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363861] PVR_K: (MKT-97) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363861] PVR_K: (MKT-98) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363861] PVR_K: (MKT-99) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363891] PVR_K: (MKT-9A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363891] PVR_K: (MKT-9B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363891] PVR_K: (MKT-9C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363922] PVR_K: (MKT-9D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363922] PVR_K: (MKT-9E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363952] PVR_K: (MKT-9F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363952] PVR_K: (MKT-A0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363952] PVR_K: (MKT-A1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363983] PVR_K: (MKT-A2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363983] PVR_K: (MKT-A3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.363983] PVR_K: (MKT-A4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364013] PVR_K: (MKT-A5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364013] PVR_K: (MKT-A6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364044] PVR_K: (MKT-A7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364044] PVR_K: (MKT-A8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364044] PVR_K: (MKT-A9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364074] PVR_K: (MKT-AA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364074] PVR_K: (MKT-AB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364074] PVR_K: (MKT-AC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364105] PVR_K: (MKT-AD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364105] PVR_K: (MKT-AE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364135] PVR_K: (MKT-AF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364135] PVR_K: (MKT-B0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364135] PVR_K: (MKT-B1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364166] PVR_K: (MKT-B2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364166] PVR_K: (MKT-B3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364166] PVR_K: (MKT-B4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364196] PVR_K: (MKT-B5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364196] PVR_K: (MKT-B6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364196] PVR_K: (MKT-B7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364227] PVR_K: (MKT-B8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364227] PVR_K: (MKT-B9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364257] PVR_K: (MKT-BA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364257] PVR_K: (MKT-BB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364257] PVR_K: (MKT-BC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364288] PVR_K: (MKT-BD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364288] PVR_K: (MKT-BE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364288] PVR_K: (MKT-BF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364318] PVR_K: (MKT-C0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364318] PVR_K: (MKT-C1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364349] PVR_K: (MKT-C2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364349] PVR_K: (MKT-C3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364349] PVR_K: (MKT-C4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364379] PVR_K: (MKT-C5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364379] PVR_K: (MKT-C6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364379] PVR_K: (MKT-C7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364410] PVR_K: (MKT-C8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364410] PVR_K: (MKT-C9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364410] PVR_K: (MKT-CA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364440] PVR_K: (MKT-CB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364440] PVR_K: (MKT-CC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364471] PVR_K: (MKT-CD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364471] PVR_K: (MKT-CE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364471] PVR_K: (MKT-CF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364501] PVR_K: (MKT-D0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364501] PVR_K: (MKT-D1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364501] PVR_K: (MKT-D2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364532] PVR_K: (MKT-D3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364532] PVR_K: (MKT-D4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364562] PVR_K: (MKT-D5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364562] PVR_K: (MKT-D6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364562] PVR_K: (MKT-D7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364593] PVR_K: (MKT-D8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364593] PVR_K: (MKT-D9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364593] PVR_K: (MKT-DA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364624] PVR_K: (MKT-DB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364624] PVR_K: (MKT-DC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364654] PVR_K: (MKT-DD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364654] PVR_K: (MKT-DE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364654] PVR_K: (MKT-DF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364685] PVR_K: (MKT-E0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364685] PVR_K: (MKT-E1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364685] PVR_K: (MKT-E2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364715] PVR_K: (MKT-E3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364715] PVR_K: (MKT-E4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364715] PVR_K: (MKT-E5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364746] PVR_K: (MKT-E6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364746] PVR_K: (MKT-E7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364776] PVR_K: (MKT-E8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364776] PVR_K: (MKT-E9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364776] PVR_K: (MKT-EA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364807] PVR_K: (MKT-EB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364807] PVR_K: (MKT-EC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364807] PVR_K: (MKT-ED) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364837] PVR_K: (MKT-EE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364837] PVR_K: (MKT-EF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364868] PVR_K: (MKT-F0) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364868] PVR_K: (MKT-F1) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364868] PVR_K: (MKT-F2) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364898] PVR_K: (MKT-F3) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364898] PVR_K: (MKT-F4) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364898] PVR_K: (MKT-F5) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364929] PVR_K: (MKT-F6) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364929] PVR_K: (MKT-F7) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364929] PVR_K: (MKT-F8) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364959] PVR_K: (MKT-F9) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364959] PVR_K: (MKT-FA) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364990] PVR_K: (MKT-FB) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364990] PVR_K: (MKT-FC) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.364990] PVR_K: (MKT-FD) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365020] PVR_K: (MKT-FE) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365020] PVR_K: (MKT-FF) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365020] PVR_K: (MKT-100) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365051] PVR_K: (MKT-101) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365051] PVR_K: (MKT-102) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365081] PVR_K: (MKT-103) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365081] PVR_K: (MKT-104) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365081] PVR_K: (MKT-105) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365112] PVR_K: (MKT-106) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365112] PVR_K: (MKT-107) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365112] PVR_K: (MKT-108) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365142] PVR_K: (MKT-109) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365142] PVR_K: (MKT-10A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365173] PVR_K: (MKT-10B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365173] PVR_K: (MKT-10C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365173] PVR_K: (MKT-10D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365203] PVR_K: (MKT-10E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365203] PVR_K: (MKT-10F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365203] PVR_K: (MKT-110) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365234] PVR_K: (MKT-111) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365234] PVR_K: (MKT-112) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365234] PVR_K: (MKT-113) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365264] PVR_K: (MKT-114) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365264] PVR_K: (MKT-115) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365295] PVR_K: (MKT-116) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365295] PVR_K: (MKT-117) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365295] PVR_K: (MKT-118) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365325] PVR_K: (MKT-119) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365325] PVR_K: (MKT-11A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365325] PVR_K: (MKT-11B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365356] PVR_K: (MKT-11C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365356] PVR_K: (MKT-11D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365386] PVR_K: (MKT-11E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365386] PVR_K: (MKT-11F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365386] PVR_K: (MKT-120) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365417] PVR_K: (MKT-121) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365417] PVR_K: (MKT-122) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365417] PVR_K: (MKT-123) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365447] PVR_K: (MKT-124) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365447] PVR_K: (MKT-125) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365478] PVR_K: (MKT-126) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365478] PVR_K: (MKT-127) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365478] PVR_K: (MKT-128) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365509] PVR_K: (MKT-129) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365509] PVR_K: (MKT-12A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365509] PVR_K: (MKT-12B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365539] PVR_K: (MKT-12C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365539] PVR_K: (MKT-12D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365570] PVR_K: (MKT-12E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365570] PVR_K: (MKT-12F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365570] PVR_K: (MKT-130) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365600] PVR_K: (MKT-131) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365600] PVR_K: (MKT-132) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365600] PVR_K: (MKT-133) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365631] PVR_K: (MKT-134) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365631] PVR_K: (MKT-135) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365631] PVR_K: (MKT-136) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365661] PVR_K: (MKT-137) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365661] PVR_K: (MKT-138) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365692] PVR_K: (MKT-139) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365692] PVR_K: (MKT-13A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365692] PVR_K: (MKT-13B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365722] PVR_K: (MKT-13C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365722] PVR_K: (MKT-13D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365722] PVR_K: (MKT-13E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365753] PVR_K: (MKT-13F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365753] PVR_K: (MKT-140) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365753] PVR_K: (MKT-141) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365783] PVR_K: (MKT-142) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365783] PVR_K: (MKT-143) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365814] PVR_K: (MKT-144) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365814] PVR_K: (MKT-145) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365814] PVR_K: (MKT-146) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365844] PVR_K: (MKT-147) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365844] PVR_K: (MKT-148) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365875] PVR_K: (MKT-149) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365875] PVR_K: (MKT-14A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365875] PVR_K: (MKT-14B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365905] PVR_K: (MKT-14C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365905] PVR_K: (MKT-14D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365905] PVR_K: (MKT-14E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365936] PVR_K: (MKT-14F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365936] PVR_K: (MKT-150) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365936] PVR_K: (MKT-151) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365966] PVR_K: (MKT-152) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365966] PVR_K: (MKT-153) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365997] PVR_K: (MKT-154) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365997] PVR_K: (MKT-155) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.365997] PVR_K: (MKT-156) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366027] PVR_K: (MKT-157) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366027] PVR_K: (MKT-158) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366027] PVR_K: (MKT-159) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366058] PVR_K: (MKT-15A) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366058] PVR_K: (MKT-15B) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366088] PVR_K: (MKT-15C) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366088] PVR_K: (MKT-15D) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366088] PVR_K: (MKT-15E) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366119] PVR_K: (MKT-15F) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366119] PVR_K: (MKT-160) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366119] PVR_K: (MKT-161) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366149] PVR_K: (MKT-162) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366149] PVR_K: (MKT-163) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366180] PVR_K: (MKT-164) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366180] PVR_K: (MKT-165) 00000000 00000000 00000000 00000000 (Unknown)
[ 11.366180] PVR_K: (MKT-166) 00000000 00000000 00000000 00000000 (Unknown)
[ 17.161193] SMP: failed to stop secondary CPUs
[ 17.161224]
[ 17.161224] Restarting Linux version 3.4.34-01535-g499e8d5-dirty (root@sszcwpt2) (gcc version 4.6.x-google 20120106 (prerelease)
(GCC) ) #1 SMP PREEMPT Thu Dec 11 15:21:28 CST 2014
[ 17.161224]
[ 17.201232] arm_restart: Console was locked! Busting
Texas Instruments Inc Bootloader 1.1.0-g33af7cb4-dirty
Build Info: Nov 20 2014 - 10:42:30
OMAP reset reason PRM_RSTST = 0x0001
PMIC reset reason SWOFF_STATUS = 0x00
sram: boot device: EMMC
kernel @ 80008000 (4897496)
ramdisk @ 81000000 (184195)
Device Serial Number: 2E6604F01CA80121
booting kernel...
Uncompressing Linux... done, booting the kernel.
