• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » /etc... Analog » /etc... Analog Forum » How to calculate time constant of caps in following ckts
Share
/etc... Analog
  • Forum
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Aamir Ali
Posted by Aamir Ali
on Apr 21 2012 05:45 AM
Expert2115 points
1. in fig 1, how to calculate time constant for C1 & C2. What are other parameters included in C2. & what are initial current in C1 & C2 when charging just starts.
It is given by I= Vs-Vc/R (Let vc=0v initilally)
2. in fig 2, zener will keep 12 V across cap, assume R1=1M (in fig its 10k, ignore this value). While calculating initial current direct relation cannot be used. I=Vs-vc/R As current will be limited by R1 here.
How to find that
3. in fig 3 lets say I have a initial cap value =14v & voltage source=12V. In this I don't think cap will discharge as there no path left.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Apr 22 2012 08:34 AM
    Guru101625 points
    Hi, Aamir,
    Are your questions with respect to a particular Texas Instruments' IC? If so, can you provide us with the TI part number in question?
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Aamir Ali
    Posted by Aamir Ali
    on Apr 23 2012 03:40 AM
    Expert2115 points
    Hi Dan,
    I m grad student doing industrial training as part of course. in company dey are working on msp430g2553 & bq78pl116. i m working on project  for reading data from pl116 & send it to PC & interfacing 8 temp sensor ..
    1. Now fig1 is related to msp430g225s internal adc. here the discussion related to msp. but i want to know in general how to calculate time for that charging c1 & c2.
    I know how to calculate time for simple RC, RLC, LC. But here there are two caps.
    http://e2e.ti.com/support/microcontrollers/msp43016-bit_ultra-low_power_mcus/f/166/p/180701/654389.aspx#654389
    2. Now fig 2, is relaled to bq78pl116 where mosfets are charged with this way. (not exactly dis ckt but part of it.)
    cap is input cap of mosfet to charge.
    3. Also if you can here:
    http://e2e.ti.com/support/power_management/battery_management/f/179/t/182655.aspx
    BR
    Aamir
    Report Abuse
    • Reply
  • Suresh Upadhya
    Posted by Suresh Upadhya
    on Apr 23 2012 12:47 PM
    Prodigy80 points
    1. Time const of C1 branch (ignoring the C2 branch it has to charge in turn) is R1* C1 = 1ms.
        Time const of C2 branch (which is charged as C1 gets charged) is R2* C2 = 270ns.
          => C2 branch gets charged much faster than
        The overall circuit's time constant is only marginally greater than 1ms.
    Initial current in C1  = VBat / R1 = 1.2ma; in C2 = VC1/ R2 = 0.
    2. Assuming VC1= 0 initially, initial current is VBat / R1 = 62ua. The  RC circuit will charge as usual, till VC  = Vz = 12V. After that, the current (VBat - Vzener )/ R1 will all drain through the zener path, leaving the capacitor charged at Vzener = 12V.
    3. Well, the capacitor's discharge path will be its leakage resistance (parallel to the cap in its classical model) and some reverse leakage current through the diode into the battery! Of course it will retain voltage close to VBat due to the normal charging path from the battery.
    Hope this helps.
    Suresh Upadhya
    Suresh Upadhya,
    Proprietor,
    www.thefirststep.in
    Report Abuse
    • Reply
  • Aamir Ali
    Posted by Aamir Ali
    on Apr 24 2012 02:23 AM
    Expert2115 points
    Thanks Suresh for your reply. I have some questions :
    1. Fig 1: Time constant for C1= 1ms & c2 is 270ns
    Now C2 will be get charged upto voltage of C1 . But since C1 gets charged in 1ms, how come C2 can be charged upto that voltage in less time.
    2. Fig 2: So here time constant will be R1*c1.& charging voltage upto 12V.
    to calculate time for capacitor to charge
    VC= V(1- exp(-t/RC))
    So Vc=12V & V=62V, R&C are known . So time can be calculated. Is it the method?
    Report Abuse
    • Reply
  • Suresh Upadhya
    on Apr 24 2012 04:04 AM
    Prodigy80 points
    1. You are right. The cascaded charging time constant for C2 is also nearly same as that of C1; just delayed by some ns due to R2, C2.
    I was trying to simplify the load behaviour of the two branches, so that we can understand/ estimate the circuit behaviour. For the given part values, I expect the signals at C1 and C2 to be nearly same as that without the R2, C2 branch altogether!!!
    2. You are right. This assumes that there is negligible leakage current through the zener, till its rated voltage.
    Suresh Upadhya,
    Proprietor,
    www.thefirststep.in
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
