• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » /etc... Analog » /etc... Analog Forum » Welcome to the Iron Circuit Design Contest!
Share
/etc... Analog
  • Forum
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 13 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
G Hann
Posted by G Hann
on Mar 03 2009 12:43 PM
Prodigy560 points
Welcome to the TI sponsored Iron Circuit Design Challenge Forum! This forum should be a great place to get some assistance with your ICD contest entry - especially the analog portions. I am a Signal Chain Marketing Engineer and have worked for TI analog for 8 years focusing in the performance analog area. Favorite TI amplifier today - the INA333 - the low power and zero drift instrumentation amp is going to make sensor signal conditioning a lot more interesting. If you could tag your contest forum questions with "Iron Circuit" that would be a great help, good luck designing and don't hesitate to ask if you need some help! .
Iron Circuit
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ZHamid
    Posted by ZHamid
    on Mar 30 2009 09:51 AM
    Prodigy190 points
    Hi everyone,
    Here is a short FAQ to get you started:
    1. Where can I find more details on the competition?
    Details can be found at the EDN Iron Circuit Design Contest website
    1. What is the contest about?
    The contest is to find the best ideas for a low power wireless circuit that include at least three sensors of your choice, including at least three components from the TI approved parts list.
    1. What do I have to submit?
    You will have to submit a block diagram and schematics, bill of materials and additional supporting information. Actual design does not have to be built or tested. For more details visit the entry details page
    1. How do I enter?
    Visit http://www.edn.com/icd/ and click on the Register Now link
    1. How will my design be judged?
      1. Creativity and Technical Elegance - Have you created a unique or different way to solve a problem?
      2. Overall Circuit Efficiency - How well does your circuit use the capabilities of the components you chose?
      3. Overall Utility - Does your circuit have a practical use; could someone build and use it?
      4. Power Budget - How well does your circuit use and conserve power?
      5. Quality of Documentation - Have you expressed circuit operations and utility clearly?
    2. The most important thing: What is the prize?
    Bragging rights and …
    1.
      1. Grand Prize - $500 American Express Gift Card. The winning circuit design will also be published in EDN magazine and featured online at EDN.com!
      2. 2nd Place - Garmin Nuvi 265T GPS
      3. 3rd Place - Flip Video Ultra Series Camcorder
    In addition, random participants and voters will get surprise prizes!
    7. When is it due?
    The entries are due by May15th.
    If you have any other questions - do drop us a line!
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Mar 31 2009 15:02 PM
    Prodigy60 points
    I am planning to enter the Iron Circuit Challenge and my entry will be a wireless biosensor device. I have been working on the design for some time now and for the most part have completed but of of the sensor circuits. The device is intended to measure record and communicate (O2 saturation - Pulse Ox, Temperature, Heart rate and SCL/SCR = Skin conductance level and variabiliy.) I am hoping to use the INA333 for the SCL/SCR measurement and was hoping to be able to get some design assistance.
    Thanks in advance for any help and/or guidance.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Mar 31 2009 19:29 PM
    Expert7120 points
    If you are planning to use the INA333 to measure the skin conductance, you will probably need a very stable excitation source with which you either generate a known precision current or voltage divider with a known precision source and a known resistor.  The INA333 can accept common input signal levels 100mV from either rail; however, I would recommend biasing the common signal levels such that it is mid supply about either 5V or 3.3V--whichever you prefer.  You can scale the gain of the INA333 based on the maximum voltage that you anticipate on measuring such that it does not saturate the output into the positive rail.  You will also need to apply a small voltage at the reference pin if you anticipate your minimum signal level to be very small.  This will keep the INA333's output off the ground rail for those low input cases.
    I hope this helps as a start.
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Apr 01 2009 11:15 AM
    Prodigy60 points
    Thanks Matt.
    I saw a voltage reference device REF50xx in the ist, and am wondering if that would work (per you suggestion) as a known precision voltage source? So basically the idea is to apply .5v across the skin and measure conductivity (in Micro Siemens ranging 1-50, or approximately .5 Micro Amps). I am also wondering if I might need a bridge on the input stage?
    What is the best way to programatically adjust the gain? I am thinking a signal switch alon with a resistor bank?
    Thanks again for all the help.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Apr 01 2009 13:46 PM
    Expert7120 points
    A bridge might actually be a better idea because it is easier to keep your signals of interest differential; likewise, using the REF50xx is a good idea to excite the bridge.  If you anticipate having to dynamically adjust your gain to achieve the best impedance measurement, you might consider using the PGA308 for this end.  Here is a link to the data sheet:
    http://focus.ti.com/docs/prod/folders/print/pga308.html
    Matt
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Apr 01 2009 15:40 PM
    Prodigy60 points
    Great. Thanks again for all the help.
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Apr 03 2009 12:14 PM
    Prodigy60 points
    Hi Matt,
    I managed to puttogether a design and simulate it in Tina using the PGA308 and it seems to work (at least theoretically).Now before I order boards I was hoping to be able to build a prototype. I just recieved some samples (PGA308AIDGSTG4), frankly I just picked what was available from the list and not quite sure what the G4 stands for. Anyway, is there an evaluation board (or prefereably a breakout board) that I could use to basically mount the device as a DIP? I have some breakout boards that are for SSOP type device packaging (I belive .63 pitch) and am not sure if that will work. Is the device mentioned .5 pitch?
    Report Abuse
    • Reply
  • ZHamid
    Posted by ZHamid
    on Apr 03 2009 14:25 PM
    Prodigy190 points
    Hi everyone!
    Just want to re-iterate that for the Iron Circuit Design contest, we are not looking for a finished, working design. A concept will do – so you DON’T have to submit a detailed schematic along with detailed BOM down to the resistor level. Just get creative J
    Voltaz, looks like you are on roll with your design. Good Luck!
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Apr 13 2009 20:12 PM
    Prodigy60 points
    Hi Matt,
    Any chance you could explain what is going on here:
    I was expecting to see 1.363v at the output not 743.68mV ! I am a bit confused as to why this is happening.
    Thanks in advance for any help.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Apr 14 2009 18:37 PM
    Expert7120 points
    The problem is that you are saturating the output of the buffer amplifier (VOA1) off of the negative input.  This is a limitation of a 3 OPA INA when the common mode voltage is not high enough.  Where you bias  your common levels from the bridge is dependent on how much your differential signal will change.   You can determine where to set the common mode level, VCM, based on the equations below.  Note that to get the voltage at Vin- and Vin+ into definition form, we denote the voltage as having both a common and differential component.  Off the -input it is VCM -Vdiff/2 and off the positive input it is VCM+Vdiff/2.  The output of each amplifier is VCM +/- (Vdiff/2)*Gain.   Here you can see why in your case the amplifier was saturating--your differential voltage was 100mV; therefore, Vdiff/2 = 50mV and VCM = (271mV  + 409mV)/2 =340mV.  The output of each amplifier can only swing 75mV to either the ground or positive supply rail, so in your case the output of A1 was being driven to 340mV - 50mV*10 = -160mV, which is well below the ground rail.
    If you expect large variation in the impedance you are trying to measure with your 100k ohm bridge, you might consider configuring it this way:
    Also, if you want to decrease the sensitivity of the skin resistance,  you can put a resistor in parallel with Rskin.
    I hope this helps.
    Matt
    Report Abuse
    • Reply
  • voltaz
    Posted by voltaz
    on Apr 14 2009 20:29 PM
    Prodigy60 points
    Perfect thank you very much. I realy appreciate the help Matt.
    Best Regrads,
    Report Abuse
    • Reply
  • ZHamid
    Posted by ZHamid
    on May 28 2009 17:14 PM
    Prodigy190 points
    Heads up:  We'll be opening up the voting session for the winners soon! Stay tuned ...
    Report Abuse
    • Reply
  • ZHamid
    Posted by ZHamid
    on Jun 02 2009 18:00 PM
    Prodigy190 points
    You can go here to see the top 3 circuits. Vote on who wins the $500 AMEX Gift Card and enter for a chance to win one of three Flip Video Series Camcorder. Happy voting and good luck!
    Report Abuse
    • Reply
  • ZHamid
    Posted by ZHamid
    on Jun 24 2009 17:19 PM
    Prodigy190 points
    Results are out Jul 1st. Good Luck to the finalists and registrants!
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
