Hey, I'm a student just starting on a new project.
Was going through the Stellaris EK-LM4F120XL LaunchPad Workshop, Lab 10: Graphics Library. Could do everything (uploading pictures, drawing shapes, coloring backgrounds, making buttons, etc) but the touch screen buttons just won't work. Nothing happens if I press the buttons or slide a slider. I used another touch screen with no luck, so it shouldn't be a hardware problem. They gave a demo program and it didn't work either (touch buttons). No compilation/linking errors. Used an oscilloscope to look for voltage spikes when I touch the screen: nothing is detected.
The only change I did to the program was the inclusion of more files in the utils folder. Was empty when I set it up, so I added my own files in.
Libraries are Altium Library types?
Linker
File Search Path
(Include)
"lib.a"
"C:\ti\StellarisWare\driverlib\ccs-cm4f\Debug\driverlib-cm4f.lib"
"C:\ti\StellarisWare\grlib\ccs-cm4f\Debug\grlib-cm4f.lib"
Add <dir>
"${CG_TOOL_ROOT}/lib"
"${CG_TOOL_ROOT}/include"
ARM Compiler (Include Options)
Add dir
"C:\ti\StellarisWare"
"${SW_ROOT}/boards/ek-lm4f120xl"
"${SW_ROOT}"
Playing with the code. Changed g_ulPanel in grlib_demo.c , int main(void) to other values and and changed WidgetAdd() parameters to get different screens and widgets, but only the 'next button' is present, previous button does not show up and next button does not disappear at the last screen. Should I be concerned about that?
// Add the first panel to the widget tree.
g_ulPanel = 0; //****This one changed
WidgetAdd(WIDGET_ROOT, (tWidget *)g_psPanels);
CanvasTextSet(&g_sTitle, g_pcPanelNames[0]);
Anyone had any similar experiences on this issue? Using Code Composer Studio v5. Full code below.
// grlib_demo.c - Demonstration of the Stellaris Graphics Library.
// Copyright (c) 2008-2010 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 6075 of the DK-LM3S9B96 Firmware Package.
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_sysctl.h"
#include "inc/hw_types.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/flash.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/uart.h"
#include "driverlib/udma.h"
#include "driverlib/rom.h"
#include "grlib/grlib.h"
#include "grlib/widget.h"
#include "grlib/canvas.h"
#include "grlib/checkbox.h"
#include "grlib/container.h"
#include "grlib/pushbutton.h"
#include "grlib/radiobutton.h"
#include "grlib/slider.h"
#include "utils/ustdlib.h"
#include "drivers/Kentec320x240x16_ssd2119_8bit.h"
//#include "drivers/sound.h"
#include "drivers/touch.h"
#include "images.h"
//! \addtogroup example_list
//! <h1>Graphics Library Demonstration (grlib_demo)</h1>
//! This application provides a demonstration of the capabilities of the
//! Stellaris Graphics Library. A series of panels show different features of
//! the library. For each panel, the bottom provides a forward and back button
//! (when appropriate), along with a brief description of the contents of the
//! panel.
//! The first panel provides some introductory text and basic instructions for
//! operation of the application.
//! The second panel shows the available drawing primitives: lines, circles,
//! rectangles, strings, and images.
//! The third panel shows the canvas widget, which provides a general drawing
//! surface within the widget hierarchy. A text, image, and application-drawn
//! canvas are displayed.
//! The fourth panel shows the check box widget, which provides a means of
//! toggling the state of an item. Four check boxes are provided, with each
//! having a red ``LED'' to the right. The state of the LED tracks the state
//! of the check box via an application callback.
//! The fifth panel shows the container widget, which provides a grouping
//! construct typically used for radio buttons. Containers with a title, a
//! centered title, and no title are displayed.
//! The sixth panel shows the push button widget. Two columns of push buttons
//! are provided; the appearance of each column is the same but the left column
//! does not utilize auto-repeat while the right column does. Each push button
//! has a red ``LED'' to its left, which is toggled via an application callback
//! each time the push button is pressed.
//! The seventh panel shows the radio button widget. Two groups of radio
//! buttons are displayed, the first using text and the second using images for
//! the selection value. Each radio button has a red ``LED'' to its right,
//! which tracks the selection state of the radio buttons via an application
//! callback. Only one radio button from each group can be selected at a time,
//! though the radio buttons in each group operate independently.
//! The eighth and final panel shows the slider widget. Six sliders
//! constructed using the various supported style options are shown. The
//! slider value callback is used to update two widgets to reflect the values
//! reported by sliders. A canvas widget near the top right of the display
//! tracks the value of the red and green image-based slider to its left and
//! the text of the grey slider on the left side of the panel is update to show
//! its own value. The slider on the right is configured as an indicator
//! which tracks the state of the upper slider and ignores user input.
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
// The DMA control structure table.
#ifdef ewarm
#pragma data_alignment=1024
tDMAControlTable sDMAControlTable[64];
#elif defined(ccs)
#pragma DATA_ALIGN(sDMAControlTable, 1024)
#else
tDMAControlTable sDMAControlTable[64] __attribute__ ((aligned(1024)));
#endif
// Forward declarations for the globals required to define the widgets at
// compile-time.
void OnPrevious(tWidget *pWidget);
void OnNext(tWidget *pWidget);
void OnIntroPaint(tWidget *pWidget, tContext *pContext);
void OnPrimitivePaint(tWidget *pWidget, tContext *pContext);
void OnCanvasPaint(tWidget *pWidget, tContext *pContext);
void OnCheckChange(tWidget *pWidget, unsigned long bSelected);
void OnButtonPress(tWidget *pWidget);
void OnRadioChange(tWidget *pWidget, unsigned long bSelected);
void OnSliderChange(tWidget *pWidget, long lValue);
extern tCanvasWidget g_psPanels[];
// The first panel, which contains introductory text explaining the
// application.
Canvas(g_sIntroduction, g_psPanels, 0, 0, &g_sKentec320x240x16_SSD2119, 0, 24,
320, 166, CANVAS_STYLE_APP_DRAWN, 0, 0, 0, 0, 0, 0, OnIntroPaint);
// The second panel, which demonstrates the graphics primitives.
Canvas(g_sPrimitives, g_psPanels + 1, 0, 0, &g_sKentec320x240x16_SSD2119, 0,
24, 320, 166, CANVAS_STYLE_APP_DRAWN, 0, 0, 0, 0, 0, 0,
OnPrimitivePaint);
// The third panel, which demonstrates the canvas widget.
Canvas(g_sCanvas3, g_psPanels + 2, 0, 0, &g_sKentec320x240x16_SSD2119, 205,
27, 110, 158, CANVAS_STYLE_OUTLINE | CANVAS_STYLE_APP_DRAWN, 0, ClrGray,
0, 0, 0, 0, OnCanvasPaint);
Canvas(g_sCanvas2, g_psPanels + 2, &g_sCanvas3, 0,
&g_sKentec320x240x16_SSD2119, 5, 109, 195, 76,
CANVAS_STYLE_OUTLINE | CANVAS_STYLE_IMG, 0, ClrGray, 0, 0, 0, g_pucLogo,
0);
Canvas(g_sCanvas1, g_psPanels + 2, &g_sCanvas2, 0,
&g_sKentec320x240x16_SSD2119, 5, 27, 195, 76,
CANVAS_STYLE_FILL | CANVAS_STYLE_OUTLINE | CANVAS_STYLE_TEXT,
ClrMidnightBlue, ClrGray, ClrSilver, &g_sFontCm22, "Text", 0, 0);
// The fourth panel, which demonstrates the checkbox widget.
tCanvasWidget g_psCheckBoxIndicators[] =
CanvasStruct(g_psPanels + 3, g_psCheckBoxIndicators + 1, 0,
&g_sKentec320x240x16_SSD2119, 230, 30, 50, 42,
CANVAS_STYLE_IMG, 0, 0, 0, 0, 0, g_pucLightOff, 0),
CanvasStruct(g_psPanels + 3, g_psCheckBoxIndicators + 2, 0,
&g_sKentec320x240x16_SSD2119, 230, 82, 50, 48,
CanvasStruct(g_psPanels + 3, 0, 0,
&g_sKentec320x240x16_SSD2119, 230, 134, 50, 42,
tCheckBoxWidget g_psCheckBoxes[] =
CheckBoxStruct(g_psPanels + 3, g_psCheckBoxes + 1, 0,
&g_sKentec320x240x16_SSD2119, 40, 30, 185, 42,
CB_STYLE_OUTLINE | CB_STYLE_FILL | CB_STYLE_TEXT, 16,
ClrMidnightBlue, ClrGray, ClrSilver, &g_sFontCm22, "Select",
0, OnCheckChange),
CheckBoxStruct(g_psPanels + 3, g_psCheckBoxes + 2, 0,
&g_sKentec320x240x16_SSD2119, 40, 82, 185, 48,
CB_STYLE_IMG, 16, 0, ClrGray, 0, 0, 0, g_pucLogo,
OnCheckChange),
CheckBoxStruct(g_psPanels + 3, g_psCheckBoxIndicators, 0,
&g_sKentec320x240x16_SSD2119, 40, 134, 189, 42,
CB_STYLE_OUTLINE | CB_STYLE_TEXT, 16,
0, ClrGray, ClrGreen, &g_sFontCm20, "Select",
0, OnCheckChange),
#define NUM_CHECK_BOXES (sizeof(g_psCheckBoxes) / \
sizeof(g_psCheckBoxes[0]))
// The fifth panel, which demonstrates the container widget.
Container(g_sContainer3, g_psPanels + 4, 0, 0, &g_sKentec320x240x16_SSD2119,
210, 47, 105, 118, CTR_STYLE_OUTLINE | CTR_STYLE_FILL,
ClrMidnightBlue, ClrGray, 0, 0, 0);
Container(g_sContainer2, g_psPanels + 4, &g_sContainer3, 0,
&g_sKentec320x240x16_SSD2119, 5, 109, 200, 76,
(CTR_STYLE_OUTLINE | CTR_STYLE_FILL | CTR_STYLE_TEXT |
CTR_STYLE_TEXT_CENTER), ClrMidnightBlue, ClrGray, ClrSilver,
&g_sFontCm22, "Group2");
Container(g_sContainer1, g_psPanels + 4, &g_sContainer2, 0,
&g_sKentec320x240x16_SSD2119, 5, 27, 200, 76,
CTR_STYLE_OUTLINE | CTR_STYLE_FILL | CTR_STYLE_TEXT, ClrMidnightBlue,
ClrGray, ClrSilver, &g_sFontCm22, "Group1");
// The sixth panel, which contains a selection of push buttons.
tCanvasWidget g_psPushButtonIndicators[] =
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 1, 0,
&g_sKentec320x240x16_SSD2119, 40, 85, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 2, 0,
&g_sKentec320x240x16_SSD2119, 90, 85, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 3, 0,
&g_sKentec320x240x16_SSD2119, 145, 85, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 4, 0,
&g_sKentec320x240x16_SSD2119, 40, 165, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 5, 0,
&g_sKentec320x240x16_SSD2119, 90, 165, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 6, 0,
&g_sKentec320x240x16_SSD2119, 145, 165, 20, 20,
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 7, 0,
&g_sKentec320x240x16_SSD2119, 190, 35, 110, 24,
CANVAS_STYLE_TEXT, 0, 0, ClrSilver, &g_sFontCm20, "Non-auto",
0, 0),
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 8, 0,
&g_sKentec320x240x16_SSD2119, 190, 55, 110, 24,
CANVAS_STYLE_TEXT, 0, 0, ClrSilver, &g_sFontCm20, "repeat",
0, 0),
CanvasStruct(g_psPanels + 5, g_psPushButtonIndicators + 9, 0,
&g_sKentec320x240x16_SSD2119, 190, 115, 110, 24,
CANVAS_STYLE_TEXT, 0, 0, ClrSilver, &g_sFontCm20, "Auto",
0, 0),
CanvasStruct(g_psPanels + 5, 0, 0,
&g_sKentec320x240x16_SSD2119, 190, 135, 110, 24,
0, 0),
tPushButtonWidget g_psPushButtons[] =
RectangularButtonStruct(g_psPanels + 5, g_psPushButtons + 1, 0,
&g_sKentec320x240x16_SSD2119, 30, 35, 40, 40,
PB_STYLE_FILL | PB_STYLE_OUTLINE | PB_STYLE_TEXT,
ClrMidnightBlue, ClrBlack, ClrGray, ClrSilver,
&g_sFontCm22, "1", 0, 0, 0, 0, OnButtonPress),
CircularButtonStruct(g_psPanels + 5, g_psPushButtons + 2, 0,
&g_sKentec320x240x16_SSD2119, 100, 55, 20,
&g_sFontCm22, "3", 0, 0, 0, 0, OnButtonPress),
RectangularButtonStruct(g_psPanels + 5, g_psPushButtons + 3, 0,
&g_sKentec320x240x16_SSD2119, 130, 30, 50, 50,
PB_STYLE_IMG | PB_STYLE_TEXT, 0, 0, 0, ClrSilver,
&g_sFontCm22, "5", g_pucBlue50x50,
g_pucBlue50x50Press, 0, 0, OnButtonPress),
RectangularButtonStruct(g_psPanels + 5, g_psPushButtons + 4, 0,
&g_sKentec320x240x16_SSD2119, 30, 115, 40, 40,
(PB_STYLE_FILL | PB_STYLE_OUTLINE | PB_STYLE_TEXT |
PB_STYLE_AUTO_REPEAT), ClrMidnightBlue, ClrBlack,
ClrGray, ClrSilver, &g_sFontCm22, "2", 0, 0, 125,
25, OnButtonPress),
CircularButtonStruct(g_psPanels + 5, g_psPushButtons + 5, 0,
&g_sKentec320x240x16_SSD2119, 100, 135, 20,
ClrGray, ClrSilver, &g_sFontCm22, "4", 0, 0, 125, 25,
OnButtonPress),
RectangularButtonStruct(g_psPanels + 5, g_psPushButtonIndicators, 0,
&g_sKentec320x240x16_SSD2119, 130, 110, 50, 50,
(PB_STYLE_IMG | PB_STYLE_TEXT |
PB_STYLE_AUTO_REPEAT), 0, 0, 0, ClrSilver,
&g_sFontCm22, "6", g_pucBlue50x50,
g_pucBlue50x50Press, 125, 25, OnButtonPress),
#define NUM_PUSH_BUTTONS (sizeof(g_psPushButtons) / \
sizeof(g_psPushButtons[0]))
unsigned long g_ulButtonState;
// The seventh panel, which contains a selection of radio buttons.
tContainerWidget g_psRadioContainers[];
tCanvasWidget g_psRadioButtonIndicators[] =
CanvasStruct(g_psRadioContainers, g_psRadioButtonIndicators + 1, 0,
&g_sKentec320x240x16_SSD2119, 95, 62, 20, 20,
CanvasStruct(g_psRadioContainers, g_psRadioButtonIndicators + 2, 0,
&g_sKentec320x240x16_SSD2119, 95, 107, 20, 20,
CanvasStruct(g_psRadioContainers, 0, 0,
&g_sKentec320x240x16_SSD2119, 95, 152, 20, 20,
CanvasStruct(g_psRadioContainers + 1, g_psRadioButtonIndicators + 4, 0,
&g_sKentec320x240x16_SSD2119, 260, 62, 20, 20,
CanvasStruct(g_psRadioContainers + 1, g_psRadioButtonIndicators + 5, 0,
&g_sKentec320x240x16_SSD2119, 260, 107, 20, 20,
CanvasStruct(g_psRadioContainers + 1, 0, 0,
&g_sKentec320x240x16_SSD2119, 260, 152, 20, 20,
tRadioButtonWidget g_psRadioButtons1[] =
RadioButtonStruct(g_psRadioContainers, g_psRadioButtons1 + 1, 0,
&g_sKentec320x240x16_SSD2119, 10, 50, 80, 45,
RB_STYLE_TEXT, 16, 0, ClrSilver, ClrSilver, &g_sFontCm20,
"One", 0, OnRadioChange),
RadioButtonStruct(g_psRadioContainers, g_psRadioButtons1 + 2, 0,
&g_sKentec320x240x16_SSD2119, 10, 95, 80, 45,
"Two", 0, OnRadioChange),
RadioButtonStruct(g_psRadioContainers, g_psRadioButtonIndicators, 0,
&g_sKentec320x240x16_SSD2119, 10, 140, 80, 45,
RB_STYLE_TEXT, 24, 0, ClrSilver, ClrSilver, &g_sFontCm20,
"Three", 0, OnRadioChange)
#define NUM_RADIO1_BUTTONS (sizeof(g_psRadioButtons1) / \
sizeof(g_psRadioButtons1[0]))
tRadioButtonWidget g_psRadioButtons2[] =
RadioButtonStruct(g_psRadioContainers + 1, g_psRadioButtons2 + 1, 0,
&g_sKentec320x240x16_SSD2119, 175, 50, 80, 45,
RB_STYLE_IMG, 16, 0, ClrSilver, 0, 0, 0, g_pucLogo,
OnRadioChange),
RadioButtonStruct(g_psRadioContainers + 1, g_psRadioButtons2 + 2, 0,
&g_sKentec320x240x16_SSD2119, 175, 95, 80, 45,
RB_STYLE_IMG, 24, 0, ClrSilver, 0, 0, 0, g_pucLogo,
OnRadioChange),
RadioButtonStruct(g_psRadioContainers + 1, g_psRadioButtonIndicators + 3,
0, &g_sKentec320x240x16_SSD2119, 175, 140, 80, 45,
OnRadioChange)
#define NUM_RADIO2_BUTTONS (sizeof(g_psRadioButtons2) / \
sizeof(g_psRadioButtons2[0]))
tContainerWidget g_psRadioContainers[] =
ContainerStruct(g_psPanels + 6, g_psRadioContainers + 1, g_psRadioButtons1,
&g_sKentec320x240x16_SSD2119, 5, 27, 148, 160,
CTR_STYLE_OUTLINE | CTR_STYLE_TEXT, 0, ClrGray, ClrSilver,
&g_sFontCm20, "Group One"),
ContainerStruct(g_psPanels + 6, 0, g_psRadioButtons2,
&g_sKentec320x240x16_SSD2119, 167, 27, 148, 160,
&g_sFontCm20, "Group Two")
// The eighth panel, which demonstrates the slider widget.
Canvas(g_sSliderValueCanvas, g_psPanels + 7, 0, 0,
&g_sKentec320x240x16_SSD2119, 210, 30, 60, 40,
CANVAS_STYLE_TEXT | CANVAS_STYLE_TEXT_OPAQUE, ClrBlack, 0, ClrSilver,
&g_sFontCm24, "50%",
0, 0);
tSliderWidget g_psSliders[] =
SliderStruct(g_psPanels + 7, g_psSliders + 1, 0,
&g_sKentec320x240x16_SSD2119, 5, 115, 220, 30, 0, 100, 25,
(SL_STYLE_FILL | SL_STYLE_BACKG_FILL | SL_STYLE_OUTLINE |
SL_STYLE_TEXT | SL_STYLE_BACKG_TEXT),
ClrGray, ClrBlack, ClrSilver, ClrWhite, ClrWhite,
&g_sFontCm20, "25%", 0, 0, OnSliderChange),
SliderStruct(g_psPanels + 7, g_psSliders + 2, 0,
&g_sKentec320x240x16_SSD2119, 5, 155, 220, 25, 0, 100, 25,
SL_STYLE_TEXT),
ClrWhite, ClrBlueViolet, ClrSilver, ClrBlack, 0,
&g_sFontCm18, "Foreground Text Only", 0, 0, OnSliderChange),
SliderStruct(g_psPanels + 7, g_psSliders + 3, 0,
&g_sKentec320x240x16_SSD2119, 240, 70, 26, 110, 0, 100, 50,
(SL_STYLE_FILL | SL_STYLE_BACKG_FILL | SL_STYLE_VERTICAL |
SL_STYLE_OUTLINE | SL_STYLE_LOCKED), ClrDarkGreen,
ClrDarkRed, ClrSilver, 0, 0, 0, 0, 0, 0, 0),
SliderStruct(g_psPanels + 7, g_psSliders + 4, 0,
&g_sKentec320x240x16_SSD2119, 280, 30, 30, 150, 0, 100, 75,
(SL_STYLE_IMG | SL_STYLE_BACKG_IMG | SL_STYLE_VERTICAL |
SL_STYLE_OUTLINE), 0, ClrBlack, ClrSilver, 0, 0, 0,
0, g_pucGettingHotter28x148, g_pucGettingHotter28x148Mono,
OnSliderChange),
SliderStruct(g_psPanels + 7, g_psSliders + 5, 0,
&g_sKentec320x240x16_SSD2119, 5, 30, 195, 37, 0, 100, 50,
SL_STYLE_IMG | SL_STYLE_BACKG_IMG, 0, 0, 0, 0, 0, 0,
0, g_pucGreenSlider195x37, g_pucRedSlider195x37,
OnSliderChange),
SliderStruct(g_psPanels + 7, &g_sSliderValueCanvas, 0,
&g_sKentec320x240x16_SSD2119, 5, 80, 220, 25, 0, 100, 50,
(SL_STYLE_FILL | SL_STYLE_BACKG_FILL | SL_STYLE_TEXT |
SL_STYLE_BACKG_TEXT | SL_STYLE_TEXT_OPAQUE |
SL_STYLE_BACKG_TEXT_OPAQUE),
ClrBlue, ClrYellow, ClrSilver, ClrYellow, ClrBlue,
&g_sFontCm18, "Text in both areas", 0, 0,
OnSliderChange),
#define SLIDER_TEXT_VAL_INDEX 0
#define SLIDER_LOCKED_INDEX 2
#define SLIDER_CANVAS_VAL_INDEX 4
#define NUM_SLIDERS (sizeof(g_psSliders) / sizeof(g_psSliders[0]))
// An array of canvas widgets, one per panel. Each canvas is filled with
// black, overwriting the contents of the previous panel.
tCanvasWidget g_psPanels[] =
CanvasStruct(0, 0, &g_sIntroduction, &g_sKentec320x240x16_SSD2119, 0, 24,
320, 166, CANVAS_STYLE_FILL, ClrBlack, 0, 0, 0, 0, 0, 0),
CanvasStruct(0, 0, &g_sPrimitives, &g_sKentec320x240x16_SSD2119, 0, 24,
CanvasStruct(0, 0, &g_sCanvas1, &g_sKentec320x240x16_SSD2119, 0, 24, 320,
CanvasStruct(0, 0, g_psCheckBoxes, &g_sKentec320x240x16_SSD2119, 0, 24,
CanvasStruct(0, 0, &g_sContainer1, &g_sKentec320x240x16_SSD2119, 0, 24,
CanvasStruct(0, 0, g_psPushButtons, &g_sKentec320x240x16_SSD2119, 0, 24,
CanvasStruct(0, 0, g_psRadioContainers, &g_sKentec320x240x16_SSD2119, 0,
24, 320, 166, CANVAS_STYLE_FILL, ClrBlack, 0, 0, 0, 0, 0, 0),
CanvasStruct(0, 0, g_psSliders, &g_sKentec320x240x16_SSD2119, 0,
// The number of panels.
#define NUM_PANELS (sizeof(g_psPanels) / sizeof(g_psPanels[0]))
// The names for each of the panels, which is displayed at the bottom of the
// screen.
char *g_pcPanelNames[] =
" Introduction ",
" Primitives ",
" Canvas ",
" Checkbox ",
" Container ",
" Push Buttons ",
" Radio Buttons ",
" Sliders ",
" S/W Update "
// The buttons and text across the bottom of the screen.
RectangularButton(g_sPrevious, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 0, 190,
50, 50, PB_STYLE_FILL, ClrBlack, ClrBlack, 0, ClrSilver,
&g_sFontCm20, "-", g_pucBlue50x50, g_pucBlue50x50Press, 0, 0,
OnPrevious);
Canvas(g_sTitle, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 50, 190, 220, 50,
CANVAS_STYLE_TEXT | CANVAS_STYLE_TEXT_OPAQUE, 0, 0, ClrSilver,
&g_sFontCm20, 0, 0, 0);
RectangularButton(g_sNext, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 270, 190,
50, 50, PB_STYLE_IMG | PB_STYLE_TEXT, ClrBlack, ClrBlack, 0,
ClrSilver, &g_sFontCm20, "+", g_pucBlue50x50,
g_pucBlue50x50Press, 0, 0, OnNext);
// The panel that is currently being displayed.
unsigned long g_ulPanel;
// Handles presses of the previous panel button.
void
// There is nothing to be done if the first panel is already being
// displayed.
if(g_ulPanel == 0)
return;
// Remove the current panel.
WidgetRemove((tWidget *)(g_psPanels + g_ulPanel));
// Decrement the panel index.
g_ulPanel--;
// Add and draw the new panel.
WidgetAdd(WIDGET_ROOT, (tWidget *)(g_psPanels + g_ulPanel));
WidgetPaint((tWidget *)(g_psPanels + g_ulPanel));
// Set the title of this panel.
CanvasTextSet(&g_sTitle, g_pcPanelNames[g_ulPanel]);
WidgetPaint((tWidget *)&g_sTitle);
// See if this is the first panel.
if(g_ulPanel == 0)
// Clear the previous button from the display since the first panel is
// being displayed.
PushButtonImageOff(&g_sPrevious);
PushButtonTextOff(&g_sPrevious);
PushButtonFillOn(&g_sPrevious);
WidgetPaint((tWidget *)&g_sPrevious);
// See if the previous panel was the last panel.
if(g_ulPanel == (NUM_PANELS - 2))
// Display the next button.
PushButtonImageOn(&g_sNext);
PushButtonTextOn(&g_sNext);
PushButtonFillOff(&g_sNext);
WidgetPaint((tWidget *)&g_sNext);
// Handles presses of the next panel button.
void
// There is nothing to be done if the last panel is already being
// displayed.
if(g_ulPanel == (NUM_PANELS - 1))
return;
// Increment the panel index.
g_ulPanel++;
// See if the previous panel was the first panel.
if(g_ulPanel == 1)
// Display the previous button.
PushButtonImageOn(&g_sPrevious);
PushButtonTextOn(&g_sPrevious);
PushButtonFillOff(&g_sPrevious);
// See if this is the last panel.
// Clear the next button from the display since the last panel is being
// displayed.
PushButtonImageOff(&g_sNext);
PushButtonTextOff(&g_sNext);
PushButtonFillOn(&g_sNext);
// Handles paint requests for the introduction canvas widget.
void
// Display the introduction text in the canvas.
GrContextFontSet(pContext, &g_sFontCm18);
GrContextForegroundSet(pContext, ClrSilver);
GrStringDraw(pContext, "This application demonstrates the Stellaris", -1,
0, 32, 0);
GrStringDraw(pContext, "Graphics Library.", -1, 0, 50, 0);
GrStringDraw(pContext, "Each panel shows a different feature of", -1, 0,
74, 0);
GrStringDraw(pContext, "the graphics library. Widgets on the panels", -1, 0,
92, 0);
GrStringDraw(pContext, "are fully operational; pressing them will", -1, 0,
110, 0);
GrStringDraw(pContext, "result in visible feedback of some kind.", -1, 0,
128, 0);
GrStringDraw(pContext, "Press the + and - buttons at the bottom", -1, 0,
146, 0);
GrStringDraw(pContext, "of the screen to move between the panels.", -1, 0,
164, 0);
// Handles paint requests for the primitives canvas widget.
void
unsigned long ulIdx;
tRectangle sRect;
// Draw a vertical sweep of lines from red to green.
for(ulIdx = 0; ulIdx <= 8; ulIdx++)
(((((10 - ulIdx) * 255) / 10) << ClrRedShift) |
(((ulIdx * 255) / 10) << ClrGreenShift)));
GrLineDraw(pContext, 115, 120, 5, 120 - (11 * ulIdx));
// Draw a horizontal sweep of lines from green to blue.
for(ulIdx = 1; ulIdx <= 10; ulIdx++)
ClrGreenShift) |
(((ulIdx * 255) / 10) << ClrBlueShift)));
GrLineDraw(pContext, 115, 120, 5 + (ulIdx * 11), 29);
// Draw a filled circle with an overlapping circle.
GrContextForegroundSet(pContext, ClrBrown);
GrCircleFill(pContext, 185, 69, 40);
GrContextForegroundSet(pContext, ClrSkyBlue);
GrCircleDraw(pContext, 205, 99, 30);
// Draw a filled rectangle with an overlapping rectangle.
GrContextForegroundSet(pContext, ClrSlateGray);
sRect.sXMin = 20;
sRect.sYMin = 100;
sRect.sXMax = 75;
sRect.sYMax = 160;
GrRectFill(pContext, &sRect);
GrContextForegroundSet(pContext, ClrSlateBlue);
sRect.sXMin += 40;
sRect.sYMin += 40;
sRect.sXMax += 30;
sRect.sYMax += 28;
GrRectDraw(pContext, &sRect);
// Draw a piece of text in fonts of increasing size.
GrContextFontSet(pContext, &g_sFontCm14);
GrStringDraw(pContext, "Strings", -1, 125, 110, 0);
GrStringDraw(pContext, "Strings", -1, 145, 124, 0);
GrContextFontSet(pContext, &g_sFontCm22);
GrStringDraw(pContext, "Strings", -1, 165, 142, 0);
GrContextFontSet(pContext, &g_sFontCm24);
GrStringDraw(pContext, "Strings", -1, 185, 162, 0);
// Draw an image.
GrImageDraw(pContext, g_pucLogo, 270, 80);
// Handles paint requests for the canvas demonstration widget.
void
// Draw a set of radiating lines.
GrContextForegroundSet(pContext, ClrGoldenrod);
for(ulIdx = 50; ulIdx <= 180; ulIdx += 10)
GrLineDraw(pContext, 210, ulIdx, 310, 230 - ulIdx);
// Indicate that the contents of this canvas were drawn by the application.
GrContextFontSet(pContext, &g_sFontCm12);
GrStringDrawCentered(pContext, "App Drawn", -1, 260, 50, 1);
// Handles change notifications for the check box widgets.
void
// Find the index of this check box.
for(ulIdx = 0; ulIdx < NUM_CHECK_BOXES; ulIdx++)
if(pWidget == (tWidget *)(g_psCheckBoxes + ulIdx))
break;
// Return if the check box could not be found.
if(ulIdx == NUM_CHECK_BOXES)
return;
// Set the matching indicator based on the selected state of the check box.
CanvasImageSet(g_psCheckBoxIndicators + ulIdx,
bSelected ? g_pucLightOn : g_pucLightOff);
WidgetPaint((tWidget *)(g_psCheckBoxIndicators + ulIdx));
// Handles press notifications for the push button widgets.
void
// Find the index of this push button.
for(ulIdx = 0; ulIdx < NUM_PUSH_BUTTONS; ulIdx++)
if(pWidget == (tWidget *)(g_psPushButtons + ulIdx))
break;
// Return if the push button could not be found.
if(ulIdx == NUM_PUSH_BUTTONS)
return;
// Toggle the state of this push button indicator.
g_ulButtonState ^= 1 << ulIdx;
CanvasImageSet(g_psPushButtonIndicators + ulIdx,
(g_ulButtonState & (1 << ulIdx)) ? g_pucLightOn :
g_pucLightOff);
WidgetPaint((tWidget *)(g_psPushButtonIndicators + ulIdx));
// Handles notifications from the slider controls.
void
static char pcCanvasText[5];
static char pcSliderText[5];
// Is this the widget whose value we mirror in the canvas widget and the
// locked slider?
if(pWidget == (tWidget *)&g_psSliders[SLIDER_CANVAS_VAL_INDEX])
// Yes - update the canvas to show the slider value.
usprintf(pcCanvasText, "%3d%%", lValue);
CanvasTextSet(&g_sSliderValueCanvas, pcCanvasText);
WidgetPaint((tWidget *)&g_sSliderValueCanvas);
// Also update the value of the locked slider to reflect this one.
SliderValueSet(&g_psSliders[SLIDER_LOCKED_INDEX], lValue);
WidgetPaint((tWidget *)&g_psSliders[SLIDER_LOCKED_INDEX]);
if(pWidget == (tWidget *)&g_psSliders[SLIDER_TEXT_VAL_INDEX])
usprintf(pcSliderText, "%3d%%", lValue);
SliderTextSet(&g_psSliders[SLIDER_TEXT_VAL_INDEX], pcSliderText);
WidgetPaint((tWidget *)&g_psSliders[SLIDER_TEXT_VAL_INDEX]);
// Handles change notifications for the radio button widgets.
void
// Find the index of this radio button in the first group.
for(ulIdx = 0; ulIdx < NUM_RADIO1_BUTTONS; ulIdx++)
if(pWidget == (tWidget *)(g_psRadioButtons1 + ulIdx))
break;
// See if the radio button was found.
if(ulIdx == NUM_RADIO1_BUTTONS)
// Find the index of this radio button in the second group.
for(ulIdx = 0; ulIdx < NUM_RADIO2_BUTTONS; ulIdx++)
if(pWidget == (tWidget *)(g_psRadioButtons2 + ulIdx))
break;
// Return if the radio button could not be found.
if(ulIdx == NUM_RADIO2_BUTTONS)
return;
// Sind the radio button is in the second group, offset the index to
// the indicators associated with the second group.
ulIdx += NUM_RADIO1_BUTTONS;
// Set the matching indicator based on the selected state of the radio
// button.
CanvasImageSet(g_psRadioButtonIndicators + ulIdx,
WidgetPaint((tWidget *)(g_psRadioButtonIndicators + ulIdx));
// A simple demonstration of the features of the Stellaris Graphics Library.
int
main(void)
tContext sContext;
tRectangle sRect;
// The FPU should be enabled because some compilers will use floating-
// point registers, even for non-floating-point code. If the FPU is not
// enabled this will cause a fault. This also ensures that floating-
// point operations could be added to this application and would work
// correctly and use the hardware floating-point unit. Finally, lazy
// stacking is enabled for interrupt handlers. This allows floating-
// point instructions to be used within interrupt handlers, but at the
// expense of extra stack usage.
FPUEnable();
FPULazyStackingEnable();
// Set the clock to 40Mhz derived from the PLL and the external oscillator
ROM_SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |
SYSCTL_OSC_MAIN);
// Initialize the display driver.
Kentec320x240x16_SSD2119Init();
// Initialize the graphics context.
GrContextInit(&sContext, &g_sKentec320x240x16_SSD2119);
// Fill the top 24 rows of the screen with blue to create the banner.
sRect.sXMin = 0;
sRect.sYMin = 0;
sRect.sXMax = GrContextDpyWidthGet(&sContext) - 1;
sRect.sYMax = 23;
GrContextForegroundSet(&sContext, ClrDarkBlue);
GrRectFill(&sContext, &sRect);
// Put a white box around the banner.
GrContextForegroundSet(&sContext, ClrWhite);
GrRectDraw(&sContext, &sRect);
// Put the application name in the middle of the banner.
GrContextFontSet(&sContext, &g_sFontCm20);
GrStringDrawCentered(&sContext, "grlib demo", -1,
GrContextDpyWidthGet(&sContext) / 2, 8, 0);
// Configure and enable uDMA
SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
SysCtlDelay(10);
uDMAControlBaseSet(&sDMAControlTable[0]);
uDMAEnable();
// Initialize the touch screen driver and have it route its messages to the
// widget tree.
TouchScreenInit();
TouchScreenCallbackSet(WidgetPointerMessage);
// Add the title block and the previous and next buttons to the widget
// tree.
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sPrevious);
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sTitle);
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sNext);
g_ulPanel = 0;
// Issue the initial paint request to the widgets.
WidgetPaint(WIDGET_ROOT);
// Loop forever handling widget messages.
while(1)
// Process any messages in the widget message queue.
WidgetMessageQueueProcess();
