Hi!
I am having trouble driving two ERM vibration motors:
Overcurrent bit appears to be set.
I am trying to drive them in open-loop mode. Rated voltage and overdrive clamp are correctly set.
Thank you in advance.
Best regards!
Hi!
Best regards!
Well, you are absolutely right. Impedance is slightly lower than 4ohms.
In detail:
Smallest ERM has large resistance, and there is no problem with it. Largest motor has impedance around 4.5ohm, and every once in a while it raises OC bit. Other two motors have impedance below 4ohm, and they won't even start.
I guess we have to choose another ERM with better parameters.
Thank you so much for your help!
Best regards!
