sir:
To adjust the drv2624 vibration range, which specific registers need to be changed?
Our requirement is that the output voltage can be modified through the node。
sir:
Hi Kelly:
The rated voltage register 0x1f adjusts the vibration range from 0 to 255 only in two gears?1.4V,244HZ and 3.9V,220HZ。
Hi Kelly:
I mean myself can change the amplitude by writing registers。
You mean changing the value of 0x1f in open loop mode?
