• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Imaging » Imaging AFEs Forum » Timing Generator Configuration for LM98714
Share
Imaging
  • Forum
Options
  • Subscribe via RSS
This question is answered
Jeffrey Yuan
Posted by Jeffrey Yuan
on Feb 26 2012 20:49 PM
Prodigy40 points
I would like to find any information on configuring the timing generators on the LM98714 AFE.  The data sheet does not provide such information.  I would like to use this AFE with the upd3719D trilinear CCD sensor.  I look forward to learning more about programming the timing generators.
Jeff
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jim Brinkhurst84999
    Posted by Jim Brinkhurst84999
    on Mar 05 2012 18:10 PM
    Expert4590 points
    Hi Jeffrey
    The document linked below will provide the additional operational and register programming information you are looking for.
    Please let us know if you need any additional information.
    Jim B
     1452.LM98714_Prog_Man_r9p9.pdf
    Report Abuse
    • Reply
  • Jeffrey Yuan
    on Mar 06 2012 19:27 PM
    Prodigy40 points
    Thank you!
    Report Abuse
    • Reply
  • Jeffrey Yuan
    on Mar 08 2012 06:14 AM
    Prodigy40 points
    Hi Jim, In reviewing the programming and operation manual for LM98714, I noticed there is no obvious method to set an integratiion time to be shorter than the total number of clock cycles needed to read in all the pixels from the Ccd. Is there a possible way to accomplish a short integration time? On a separate issue, if one was to wait for the external stepper motor to finish moving the Ccd and issue a ready flag, what would be the best way accomplish this regarding controller the timing. I assume one would use the timing generator in slave mode. Should one wait until all the pixels area clocked in, move the Ccd, and then issue the SH_R signal or just make the SH period to be long enough to accomplish any external stepper motor driven activity? Is there an alternate way? Many thanks for any guidance on these matters, Jeff Yuan
    Report Abuse
    • Reply
    on Mar 08 2012 21:34 PM
    Verified Answer
    Verified by Jim Brinkhurst84999
    Expert4590 points
    Hi Jeffrey
    For sensors with an external signal that controls an electronic shutter function, it is possible to shorten the integration time. The "Mode" timing generator can be used to generate an On/Off signal that controls the electronic shutter timing. (See Figure 29 on page 24, Figure 34 on page 28 and the the registers described at the bottom of page 68. (Register Page 4, Registers 0-3).
    If sensors do not have an electronic shutter input there is really no way to decouple the integration time from the time required to clock the pixels out. Alternative, if the lamp source can be made dim enough, it is possible to make the integration time requirement always longer than the time for pixel conversion. Then the time can be extended as needed by lengthening the line timing beyond the minimum.
    As far as synchronizing motor stepping to line conversion there are several approaches, with a lot of the detail depending on the necessary scan resolution. For low resolution scans it may be necessary to step multiple times per line to achieve the desired resolution. These steps must either be bunched together during a long SH interval as you say, or done smoothly as the image is integrated. You might want to look at the LM9833 datasheet on-line for some insight into the details of this.
    http://www.ti.com/product/lm9833
    While this device is much too slow (2 MHz pixel clock rate in 3 color mode) for modern applications it does have all of the stepper motor functions integrated, and therefore has a lot of that detail described in the datasheet.
    I hope this is helpful.
    Jim B
    Report Abuse
    • Reply
  • Jeffrey Yuan
    on Mar 14 2012 12:20 PM
    Prodigy40 points
    Thank you Jim.  The reference to using the mode timing generator is very helpful as is the reference to LM9833.
    Jeff
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
