• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Imaging » Imaging AFEs Forum » LM98725 serial programming
Share
Imaging
  • Forum
Options
  • Subscribe via RSS
This question is answered
karl-ludwig Schinner
Posted by karl-ludwig Schinner
on Apr 11 2012 05:52 AM
Prodigy40 points
Hallo Friends,
I´ve a problem which costs me time.
We try to use a standard spi interface to control a LM98725 and don´t get any answer from him.
Our try was to put out 4 bytes via spi ( under one global select ) with the content 0x00, 0x00,0x80,0x00 and expected the data of control register 0 in the next access.
We got - nothing.
The speed we use is 100 KHz, the clk is 26.6 MHz C-Mos and any trials to reset and so on has been made.
Can anyone help me?
The only remaining idea is that we have to use 25 bit´s for communication ( and not 32 like we do now ).
Best regards
Karl-Ludwig Schinner
lm98725 spi
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jim Brinkhurst84999
    Posted by Jim Brinkhurst84999
    on Apr 11 2012 12:56 PM
    Expert4590 points
    Hello Karl-Ludwig
    Given what you have described, I believe the device should output the contents of Register 0 on the first 8 clocks of the next transaction. One possible problem could be that the CE pin on the LM98725 is not Grounded. Per the datasheet and programming manual it is required that CE is connected to Ground to set the CE1 and CE0 address bits to 00 to match the bits in your SPI command.
    Also, you are using a CMOS clock connected to INCLK+. Can you confirm that INCLK- is connected to ground?
    If you could send a schematic for all LM98725 signal and power connections that would also be helpful.
    Jim B
    Report Abuse
    • Reply
  • Felix Lesser
    Posted by Felix Lesser
    on Apr 12 2012 03:54 AM
    Prodigy10 points
    Hello Jim
    As an employe of Mr Schinner and because Mr Schinner is away from office today, he asked me to send you the schematic.
    I hope it will help.
    Felix Lesser
    Report Abuse
    • Reply
    on Apr 12 2012 19:00 PM
    Verified Answer
    Verified by Jim Brinkhurst84999
    Expert4590 points
    Hi Felix and Karl-Ludwig
    Please confirm the following details:
    R62 = 9.0kohms 1% (It is hard to read and could be 90kohms in the schematic but should be 9000 ohms)
    R57 is not installed
    R55 and R56 are installed and 0 ohms each.
    Confirm amplitude of clock signal at INCLK+ (measured at R55 is good) is normal 3.3V CMOS levels and expected frequency.
    If all these are as expected, the serial interface should be working properly. If it still isn't working then an oscilloscope capture of SEN, SCLK, SDI and SDO would be the next step to debug the interface problems.
    Jim B
    Report Abuse
    • Reply
  • karl-ludwig Schinner
    on Apr 13 2012 06:11 AM
    Verified Answer
    Prodigy40 points
    Hi Jim,
    thank´s to your help it seems now to work.
    The big changes have been
    - we change the 90 K Ohm Resistor agains 9 K.
    - we change our spi program. We use a ioworrior ( he can only output clocks with a multple of 8 bits )
      In this program it was necessary to invert the clock and to move the bit´s 1 position to the left.
    Then we are able  to
    - read and write the register 0x00  ( output for read was 0x00 0x01 0x00 0x00) --> we got 0x40 0x00 back.
    -  we can read the register 1e      ( output was 0x00 0x01 0x3d 0x00 ) --> we got 0x01 0xff ( so 0000 0011 ) if moved correct
    - we can modify the register 2     ( output was 0x00 0x01 0x05 0x80 ; so data was 1100 0000) and we got this back moved 0x60 0x00 )
    For the first step we can now handle the chip by our own, thanks to your help.
    Best regards
    Karl-Ludwig Schinner and Felix Lesser
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
