• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Imaging » Imaging AFEs Forum » VSP3210 impulse spikes with very stable amplitude
Share
Imaging
  • Forum
Options
  • Subscribe via RSS
This question is answered
Alexander Philippovich
Posted by Alexander Philippovich
on Apr 05 2010 10:32 AM
Prodigy20 points
Hi, I am using VSP3210 with Hamamatsu CCD sensor (S8982) . The circuit does not work properly. The circuit assembled on 4 layer PCB with separate DGND and AGND (in one layer) joined at one point under ADC and separated by cutouts,similarly for digital and analog power supply. Analog supply obtained from digital and isolated from digital.
ADCCK  1 Mhz
CK1   rise 300ns after ADCCK rise,  fall 100ns before ADCCK fall
CK2   rise  300 ns after ADCCK fall, fall 100ns before ADCCK rise
ADC used in 1-CCD mode; for signal from CCD used Red channel. Config Reg = 0x88; Red Bias = 0x200;Red Gain = 0x00;
/OE = GND allways; CLP = VCC during unused black pixels; VDRV = +3.3V;
Problem is the next: When I don't connect CCD to my board, and Input signal coupled from DC by 0.1 uF. R = 5.1 kOh  input resistor for emitter follower  for CCD. I see several spikes on my picture (all pixel is a noise near 12 rms). Spikes have constant amplitude max - min codes from ADC (0x4FF(1279) - 0x200 (512)=  0x2FF (767) )  and consist from two pixel  with min code and next with max code. If I change gain to 5 from 0 or change only bias to 0x1FD I see much more spikes on my picture.
I think it may be wrong  ADC convert. What do you suggest me for correct this problem?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Werner Metz
    Posted by Werner Metz
    on May 24 2010 19:32 PM
    Intellectual2175 points
    Alexander,
    Could you please
               send the emitter follower portion of the circuit and a sample of the data.
               The register settings being used for teh VSP3210
    Also, could you please try grounding input to the AFE with 0.1uF cap and taking measurements. You should see a small signal with a standard deviation of approx 10 LSB.
    Werner
    VSP3210 Spikes
    Report Abuse
    • Reply
  • Alexander Philippovich
    on May 25 2010 04:49 AM
    Prodigy20 points
    Werner,
    Problem are solved. It was error in FPGA code which read hi and low bytes from different ADC words.
    When  ADC output code near 0x01FF,0x0200,0x01FF  FPGA captured 0x02FF and 0x0100 codes. That codes I was see as spikes
    with very stable amplitude.
    Alexander
    Report Abuse
    • Reply
  • Werner Metz
    on May 25 2010 19:25 PM
    Verified Answer
    Verified by Werner Metz
    Alexander,
    Glad to hear the byte order issue was resolved. Swapping bytes or swapping big-endian/little-endian bit order is not unusual in fpga interfaces to the AFE.
    One practice is to build in a little test counter in the FPGA that can be mux'ed  into the AFE input path in the FPGA.Then increment the counter and read the FPGA data path to verify the bit order and byte order of the data path. The counter can be removed later in the design cycle.
    Also, some TI AFEs have the ability to generate a digital test ramp on the outputs as part of a test mode. This is also useful for verifying bit and byte orders. Unfortunately, the VSP3xxxx devices do not have this capability.
    I iwll mark this thread as answered unless you have further questions on the topic,
    Werner Metz
    Digital Output bit order byte order
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
