I'm working with TX-SDK-V2/NOPB. At the experiment, unfortunately one of the 50 volt out put of the board got short circuit with ground( I was trying to see the output pulse by osiloscope probe, then the probe connected the ground to one of the output channel. I'm not sure if the board damaged or not. Sub voltage didn't go up after that because the constraint current. Can you guide me what should I do now? How can I understand if the board damaged? how can I fix it? Dp you know any places to fix it?
Thank you
Parisa
