• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » TMP124 consumption in active mode
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is answered
Eduardo Ban
Posted by Eduardo Ban
on Mar 23 2011 08:27 AM
Prodigy30 points
Would need to know what TMP124 consumption in active mode, and the SPI bus turn on and off
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Collin Wells
    Posted by Collin Wells
    on Mar 23 2011 10:52 AM
    Verified Answer
    Verified by Collin Wells
    Genius15530 points
    HI Eduardo,
    We don't have any data to share with you currently.  I will have to connect this in the lab and test for you.
    The current consumption is going to depend heavily on two things:
    1.)  How often are you reading from the TMP124?
    2.)  What is the SPI clock frequency?
    So I make sure I take data that is meaningful to you, please inform me of the conditions above that you are interested in.  My equipment is setup to run at +3.3V so unless you object that is the supply voltage I plan to use for the test.
    Collin Wells
    Collin Wells
    Precision Linear Applications
    Report Abuse
    • Reply
  • Eduardo Ban
    on Mar 23 2011 12:08 PM
    Prodigy30 points
    The TMP124 I read every 1 sec approx.
    SPI frequency is 250 KHz or 400KHz.
    The power is 3 batteries of Li and 3.3 V regulator (REG1117A-3.3)
    This will need to determine an average consumption when this active and reading and when in standby, no shutdown.
    To calculate the measurement time maximums of TMP124, without taking regulatory considering battery power.
    Thank you very much
    EduardoBan
    Report Abuse
    • Reply
  • Collin Wells
    on Mar 25 2011 14:14 PM
    Verified Answer
    Genius15530 points
    Hello Eduardo,
    I was able to perform the testing on the TMP124 today.  Please note that these tests were only performed on one unit and the results across all units will vary, but this should give you a good idea of what to expect.
    I setup the SPI sequence to be as continuous as possible (little delay between /CS periods).  Although this is not a realistic form of operation, I needed to do it to be sure that I wasn't reading an averaged current with the part in standby-mode part of the time and in SPI-operation part of the time.
    Measured Currents:
    Standby - 53uA
    250kHz SPI - 75uA
    400kHz SPI - 87uA
    Please find an image of the 250kHz reads below:
    400kHz reads:
    Collin Wells
    Precision Analog
    Collin Wells
    Report Abuse
    • Reply
  • Collin Wells
    on Mar 25 2011 14:17 PM
    Verified Answer
    Genius15530 points
    I forgot to add that I was using an MSP430FG4618 to generate these signals.
    Collin Wells
    Precision Analog
    Collin Wells
    Report Abuse
    • Reply
  • Eduardo Ban
    on Apr 13 2012 17:13 PM
    Prodigy30 points
    Thank you very much for the reply, I am using a system of measurement for battery-powered and needed to compare with other devices from Analog Device.
    thank you very much
    Eduardo Ban
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
