• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » tmp124 spi
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
tmp124 spi
tmp124 spi
This question is answered
Dan MAz
Posted by Dan MAz
on Jul 15 2011 05:02 AM
Prodigy70 points
Hi! i'm programming cc430f6137 to communicate with tmp124. I need help because i obtain always 0xFF. Probably i wrong configuration of spi.
Code is following:
#include "cc430x613x.h"
volatile unsigned char received= 0;
void main(void)
   WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
  PMAPPWD = 0x02D52;                        // Get write-access to port mapping regs
  P1MAP6 = PM_UCA0SIMO;                     // Map UCA0SIMO output to P2.0
  P1MAP5 = PM_UCA0SOMI;                     // Map UCA0SOMI output to P2.2
  P1MAP7 = PM_UCA0CLK;                      // Map UCA0CLK output to P2.4
  PMAPPWD = 0;                              // Lock port mapping registers
  P4DIR |=0x80;
  P4OUT |=0x80;
  P1DIR |= BIT6 + BIT7;
  P1SEL |= BIT5 + BIT6 + BIT7;
  UCA0CTL1 |= UCSWRST;                                                 // **Put state machine in reset**
  UCA0CTL0 |= UCMST+UCSYNC+UCCKPH+UCMSB;    // 3-pin, 8-bit SPI master
        // Clock polarity high, MSB
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 0x02;                           // /2
  UCA0BR1 = 0;                              //
  UCA0MCTL = 0;                             // No modulation
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  P4OUT &= ~BIT7;                           // Now with SPI signals initialized,
  P4OUT |= BIT7;                            // reset slave
  __delay_cycles(100);                      // Wait for slave to initialize
  while (!(UCA0IFG&UCTXIFG));               // USCI_A0 TX buffer ready?
  P4OUT &= ~BIT7;
  UCA0TXBUF = 0x00;                     // Transmit first character
   __delay_cycles(20);
  __bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
  switch(__even_in_range(UCA0IV,4))
    case 0: break;                          // Vector 0 - no interrupt
    case 2:                                 // Vector 2 - RXIFG
      received= UCA0RXBUF;
  //    P4OUT &= ~0x80;
      break;
    case 4: break;                          // Vector 4 - TXIFG
    default: break;
cc430f6137 spi tmp124
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ian Williams
    Posted by Ian Williams
    on Jan 03 2012 16:12 PM
    Verified Answer
    Verified by Ian Williams
    Genius14235 points
    FG4618 TMP125 SPI Test.zip
    Hello Dan,
    I've attached example code for the TMP125 to help get you started. Unfortunately this is the only example code for temp sensors that we have available. For further assistance, please post on the MSP430 support forum at: http://e2e.ti.com/support/microcontrollers/msp43016-bit_ultra-low_power_mcus/f/166.aspx
    Ian Williams
    Linear Applications Engineer
    Precision Linear and Sensing Products
    tmp124 TMP125 sample code
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
